I'm considering a Flex-a-lite 45951 remote trans cooler for my truck. I'm currently running an E40D with BadBoy converter, shift kit & Mag-Hytec pan. I also have 40k GVW cooler installed up front (behind the intercooler & condensor). Temp on AZ highway with no load is hitting 220*. Want to know if anyone has had good/bad experience with this cooler or suggests another remote cooler. I don't have room for a cooler w/fan in front so a fan cooler needs to be installed under bed of truck. Thx
1997 F350 7.3L PSD; LB; SRW; Crew cab; RSK with dual front Bilstein shocks; Banks PowerPack; E40D with BadBoy converter & shift kit; 3" DP with 3.5" back; Airlift air bags; Mag-Hytec diff/trans covers; Power Slot rotors; Flex-a-Lite remote trans cooler; Tymar intake & CCV mod; SPDiesel SSEBTC controller; B&W turn-over ball & Companion 5th wheel hitch.
Homepage: http://community.webshots.com/user/rmrusten1
Re: Flex-a-lite 45951 remote trans cooler worth it?
I ahev not ever dealt with that setup. I am running the Trucool 45K (I think - it's the biggest one...) behind the grill and have no problems. If you are seeing that high of temps with the aux cooler, you may want to check some other things, fluid level, flowrates, etc. If they all check out, then it definitely won't hurt to have air flowing constantly over a cooler. Are your temps while driving highway or in stop and go traffic?
2000 F250 PSD, 4x4, Red
Banks 4" Exhaust, Big-head Wastegate, DP tuner Chip (80econ, 60 tow, 100 race...), AFE Stage II, TN .84, Spearco 6.0 retro-IC, EBPV removed, Ram-air Mod, BWD bellowed up-pipes, Trans rebuild with upgraded steels, low-stall TC and Tugger shift-kit
Mag-Hytec trans and diff covers, full gauges
If you are seeing that kind of temperature at No Load I would suspect you have flow problem. Have your system flow rate checked before you spend anymore money on a new cooler. From what you already have I don't think you should be seeing that kind of temperature. Just my two cents.
Griz
95 F250, 4X4, E4OD, 4.10, Hypermax DP and Tymar 4" Exhaust System, Tymar Air & Coolant Filters and HPX Kit, Tymar fuel fill mod, External Transmission Filter, Schaeffer's ATF. Add-a-leaf, Redline Differential gear oil and Redline ATF in Transfer Case. OilGuard By-pass oil filter. Schaeffer's 5W-40 in the engine. A-Pillar...Autometer Boost, Pyrometer and Trans. Temp. Gages, Under dash...Oil Pressure and Water Temperature gages, 1705 Superchip Tuner, Stancor GPR, Factory Tech Valve Body, Evans Waterless Coolant, Two 4590 Tru-Cool Transmission Cooler in series, Explorer Overhead Console, Diesel Turbo Lifesaver, Tymar Fuel Filler Mod.
I see 220* on highway unloaded. Trans was just serviced so fluid level / quality is good. Did not ask about flow rate. I'll ask trans guy what he thinks.
I assume you are talking highway speeds...right? If so, then I believe you should have your flow rate checked. With the cooler you already have I don't think you should be seeing that kind of temperatures running unloaded. Just my opinion mind you.
Griz
I added a second cooler in series and was disappointed to see that the AT temperature mirrored the engine temperature. The engine's mass, plus its position in the airstream makes it difficult to reduce the transmission's temperature.
'93 F-250, - most original at 252K miles, rebuilt E4OD 220K miles
Maybe I'm being too picky. I noticed that my license plate is bolted to my front bumper directly in front of my trans cooler. I'm thinkin' about lowering the bracket so there's full flow. Whadya' think?
'04 Excursion EB, 6.0 PS, 4X4, Magnaflow Performance exhaust, Isspro gauges (boost, pyro and tranny), Bilsteins, aFe intake, front and rear leaf spring upgrade w/ bags, 30mm rear sway bar, SCT Xcal2, Red-Head box, Jordan brake controller, Arctic Fox 29V - 20,420# GCW, Everything haulin' me, the wife, the 5 Amigos, Millie and Yogi (our 2 Berners).
My tans guy says having 2 coolers in series can cause flow restriction & actually cause increased temp's. My original thought was to put the remote cooler in series with the radiator & 40k cooler I already have; not I'm not so sure. Talked to trans guy today & he's going to increase the cooler fitting size to 3/8 from 5/16 to see if that helps before I invest in another cooler.
It's still not clear to me if it's because of the hot temp in AZ or that my 40k cooler is behind the intercooler & condensor or both. Trans guy has same setup except his cooler is up front & he's running 190*. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Has your transmission guy tested your flow rate? You could have a blockage in the oil cooler that is inside the radiator...unless you bypassed it when you hooked up your 40K cooler. Yes going to bigger transmission lines will help. But I still feel with your current setup you shouldn't be see those kind of temperatures unloaded. Just my two cents.
You might want to try mounting it in front of the i/c and condensor... I tow about 8K in 90 degrees and never see over 175 on the highway, up to 190 going through town. BP.
that is the powersteering cooler. the trans cooler is between the inter cooler and rad. (i think) and it is MASSIVE!!! i dont think any 6.0 guys are having any trouble with trans temp. jmho
kevin
(mine) 94 7.3 IDI non-turbo XL 350 super cab long bed
autojet y pipe and a used p-stroke exhaust on the end of it 24xxxx miles, amsoil bypass, coolant filter
(dads) 02 350 7.3 powerstroke crew cab 4x4 ESOF
mods: itp in tank/prepump, 4 inch exhaust, ats housing, western diesel gauges, 6.0 transmission cooler, 6.0 Banks "technicooler" intercooler 150 bucks , coolant filter, "OEIS", b&w 5th wheel companion
18xxxx miles my gallery
WHY THE HELL SHOULD I HAVE TO PUSH 1 FOR ENGLISH? H O N D A - How Odd No Damn Acceleration
Bingo! You're cooling the trans fluid with hot air. Try moving it all the way out front, or at least in front of the condensor. I guarantee you it will make a difference.
His test was that it should flow one gallon in 60 seconds. I don't know if that's normal, good or bad. I'll try the larger fittings but I'm not sure that means larger oil lines. Anyone know the proper flow?
I 'believe' the proper flow rate is a quart in 15 seconds. So your flow rate seems okay. Changing the transmission lines from 5/16" to 3/8" should help. Moving the cooler to in front of the inter-cooler should also help. But I don't think you want to add more coolers to your current setup. I would either move the cooler or do the lines or both before doing anything else. Just my opinion.
Griz
