Recently bought a new 20' Hillsboro 12.5K equipment hauler and pulled it a thousand miles on I'state and winding hilly back roads with sig truck with absolutely no issues, driveability or otherwise. Load was tractor and implements, probably about 12K total, trailer and load.
Questions are: Factory receiver would seem to be rated a bit light without WD, but frankly comparing design, metal thicknesses, attachment, etc. with a true class V there just isn't much difference. In some cases( 2" class V's)none. I do have a 15K shank and ball (2 5/16). Am I missing something here, or is this combination okay?
Second, do I really need WD for this? Based on initial experience I just didn't see the need. Again, am I missing something that's just waiting to jump out and bite me you know where? I want to do this right, but without buying stuff I don't really need. I'm a bit confused about all this.
'05 F-350 PSD 4x4 CC SB SRW Manual
I am also confused about this, but getting opinions. Did you see my post below, about towing 12K lbs w/ a frame hitch? I am also looking on the Chevy forum; seems most use the safest method and go w/ over-kill. Probably a good idea; life is worth the extra $$$ sometimes. j
I think you answered your own question. You just spent 15 hours driving your rig in a variety of conditions and it handled well and felt great with no issues. Your truck is designed to handle a Class 5 load, and it did.
Visual comparison of hitches aside, as long as you are not exceeding the rated capacity labeled on the hitch without utilizing a WD set-up, then you are good to go, if not, install a true class V hitch. The rating of the ball mount is just one component of the whole assembly of course, and that rating alone is not the deciding factor but I am sure you already knew that as an obvious point.
As I am sure you have noticed there are varying opinions on the need and use of such. Some swear by the additional comfort and control of a WD set-up and never tow without one regardless of how small the load. IMO, WD set-up was initially designed to compensate for too much being pulled by too little. While this addition could very well compliment your ride, this is far from the case with your rig and that load.
Do you need this to safely pull your described loaded trailer with the truck in your sig.? No. Could you benefit with having this set-up? According to some, yes. If your going to exceed 12K with a TAG behind your F350 then WD it is, regardless of the higher rating on your receiver hitch.
jklingel,I have been reading your thread with interest, just didn't want to hijack it with a similar question.
Hook-em-Horns, Thanks for the sensible reply. The voice of experience is what I'm looking for. I know how to load the trailer, and I know how to drive the truck, but serious long hauling on the road is new to me. The weight seems reasonable for the truck, and the results do seem to confirm that. I guess what I'm wondering is do I really need to replace the factory receiver with a class V? As I said, comparing actual construction and mounting, there just isn't any real difference. has me wondering if this is another paperwork anomoly more than a real difference.
About the WD, as you said I've kind of answered my own question in a way. Except, if things get out of shape in a panic stop or radical maneuver, could things go sour that would be avoided with WD? Thanks for your interest.
Some say yes in certain scenarios, others it wouldn't have mattered. But, it is extra protection and could very well improve your ride on long runs. As to changing what you have, your existing hitch will be labeled for rated capacity both with and without WD. Don't push/exceed the ratings, it's too inexpensive to make changes. Go from there.
