Old 01-06-2008, 10:32 PM   #1 (permalink)
frame hitch OK to tow 12000 lbs?
I have an '07 Chevy 3500, which came w/ a "12000 lb w/ weight distrib bar" hitch on it. I now need to tow a 10,000 lb loader and its, what?, 2,000 lb trailer? Is it intelligent and safe to tow this w/out a 5th wheel? I will absolutely get a weight distribution/anti-sway device; no idea which, but I have been reading about them here and another $500 or so into the truck is nothing to worry about. Should I go "big time" and get a $2000 weight distrib? I have no real interest in a 5th wheel, if I can avoid it. I may be hauling this unit up the Alcan, btw. Thanks for opinions. john
Life is a grizzly experience.
jklingel is offline
Old 01-06-2008, 11:26 PM   #2 (permalink)
Re: frame hitch OK to tow 12000 lbs?
I have an 06 gmc and can't stand that reciever. It is rated for it, but I believe you will want to upgrade to another hitch. THere are a lot of pictures of broken hitches on the chevy forums, and mine drops when a good load is applied to it, a whole lot more than it should.
a weight distributing hitch is a must.
2006 GMC K3500 CC DRW 4x4
1994 F-350 DRW PS w/ zf5
1996 Town Car
mgraveman is offline
Old 01-06-2008, 11:50 PM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Be prepared for sticker shock. A new Hensley Arrow hitch is about $3,000. Hensley Arrow - Trailer Towing Safety
A new PullRite is over $2,500. PullRite has a SAFER, STRONGER, BETTER designed hitch for you
If I could not afford a Hensley Arrow hitch, or as a minimum a Pullrite, then I would refuse to tow a 12,000 pound tag trailer up the AlCal highway. End of discussion.
But for the cost of the Hensley Arrow, you could almost pay for a good used gooseneck or 5er trailer in excellent shape with tandam 5,000 or 6,000-pound axles. The Hensley Arrow will tow as good as a 5er or goose, but not better. The purpose of the Hensley Arrow is to use an Excursion or similar SUV as your tow vehicle, when 5er or goose is not an option. But with a pickup for a tow vehicle, you have the option of a 5er or goose.
SmokeyWren is online now
Old 01-07-2008, 02:18 AM   #4 (permalink)
Shock, yes. Maybe I better put the $2,500 toward getting it shipped up the Alcan, then tow it around here w/ an upgraded receiver hitch. Now, what the hey is a 5er? Fifth wheel? And am I right that a goose neck and a 5th wheel act similarly, just have different ways of attaching to the truck "bed". At any rate, thank you for the info. I realized when I read the reply about "on the Chevy forum" that I posted on a Ford forum. Sorry about that; I posted questions here before about my Ford, and automatically dialed y'all in. I'll read on the Chevy forum. Broken towing stuff is scary. I hope GM recalls them.... ha ha. Not holding my breath.
jklingel is offline
Old 01-07-2008, 08:47 AM   #5 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: jklingel</div><div class="ubbcode-body">I have an '07 Chevy 3500, which came w/ a "12000 lb w/ weight distrib bar" hitch on it. I now need to tow a 10,000 lb loader and its, what?, 2,000 lb trailer? Is it intelligent and safe to tow this w/out a 5th wheel? I will absolutely get a weight distribution/anti-sway device; no idea which, but I have been reading about them here and another $500 or so into the truck is nothing to worry about. Should I go "big time" and get a $2000 weight distrib? I have no real interest in a 5th wheel, if I can avoid it. I may be hauling this unit up the Alcan, btw. Thanks for opinions. john </div></div>
I don't want this to sound like a Chevy bashing response, but a buddy of mine had a 2500 HD that he was regularly towing 8500# and the frame where the hitch was attached broke; I mean just flat cracked and the one side of the hitch came undone from the frame. Granted, his was an '03, but still, I would be weary.
2004 F350 Crew XLT 4x4 long box, SRW, 3.73 Gears
Bone Stock
newtodieseling is offline
Old 01-07-2008, 08:55 AM   #6 (permalink)
I think you'll be fine. You could get a true class V hitch that was rated at 14k+. I think they have weight distributing for them that are rated at 14k.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 235k miles and thousands of $$$$ in maintenance and repairs.
NickKent is offline
Old 01-07-2008, 03:44 PM   #7 (permalink)
Hook'em Horns!'s Avatar
Never understood why GM puts a receiver hitch for a ½ ton up under a 3500 as part of a tow package. Jklingel, looking closer you will see that hitch is only rated for 7500 lbs. I would not trust that hitch, when for less than $200 you can put 15,000 lbs of hitch (16kWD) instead. Moreover, that loader/trailer is probably closer to 13-14k lbs. The GN would ride far better.
2005 Chev Duramax/Allison 3500LS DRW Crew Cab
B&W 30K-Turnover GN, Putnam XDR 15K, A/T Revos
2006 Chev 6.0L/4L80e 3500WT DRW Ex-Cab 9'Flat-GN
A/T Revos
DON'T STEAL! The Government Hates Competition
Hook'em Horns! is offline
Old 01-07-2008, 04:35 PM   #8 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Hook_em_Horns</div><div class="ubbcode-body">Never understood why GM puts a receiver hitch for a ½ ton up under a 3500 as part of a tow package. Jklingel, looking closer you will see that hitch is only rated for 7500 lbs. I would not trust that hitch, when for less than $200 you can put 15,000 lbs of hitch (16kWD) instead. Moreover, that loader/trailer is probably closer to 13-14k lbs. The GN would ride far better. </div></div>
X2
1996 CC F350XLT SRW auto, 4.10, 2WD. Original owner. 274,000 miles. Tymar intake, BTS @240,000 miles. Cat is taking some time off for testing.
mlcowden is offline
Old 01-07-2008, 06:51 PM   #9 (permalink)
Chitina! I just looked at my hitch; 7500/12000 lb, but it is one sad looking hitch. FAR lighter than the similarly rated Reese I had on my Ford; it had square tubing instead of round, and weighed 40 lbs more. This one is toast; EOS. Six Robblee's, here I come. I also looked at local equipment trailers: they range from under 3K lbs to 4.5K, at 14K GVW, so I will be towing 13,000 to 14,000 lbs. Oh, sigh.... making a GN look more suitable all the time.... carp. Thanks LOADS for all the info and opinions.
jklingel is offline
Old 01-08-2008, 12:10 AM   #10 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Yes
Yes. They tow about the same as far as safety and no worry about sway - provided the hitch is installed in front of the rear axle. But they are quite different. Notice that all the big boys at the truckstop have 5er hitches. Almost all RV trailers have a 5er hitch. Some of the horse, livestock, and equipment trailer have a 5er hitch. Only some of the smaller trucks with horse trailers or equipment trailers have gooseneck hitches.
Old 01-08-2008, 06:44 PM   #11 (permalink)
Here's my opinion:
If it's rated for 12,000 then it can handle 12,000 safely. The trick is to make sure you've got load distribution bars that are adequately sized for the tongue weight of the trailer. My suggestion would be something like the Reese Titan 1700lb bars with the Reese Titan hitch head. You can get the hitch head fastened to a solid 2" draw bar to fit into your receiver. As for sway control, the Reese dual cam works perfectly with the Titan 1700 lb bars. I had this set up on a 12,000 lb toy hauler with 1850 lbs tongue weight. It worked very well. You can also get a Tork-Lift "Super Hitch" or Reese 2.5" Hitch that are rated for something like 15K or 17K if you think your trailer will be more than 12K.
good luck.
2002 F350 XLT Supercab 8' Bed, Single Rear Wheel, 6 Speed Trans, Firestone Ride Rites, Superhitch, Tork Lift Camper Tie-Downs, Custom Built Aluminum Headache Rack, Pro-Tech Tool Box, 295/70R17 Toyos on Allieds, Bilsteins, Tuff Country 3.5" Kit, Gauges, Banks PowerPack, AFE intake w/ ProGuard 7
Wiley75 is offline
Old 01-09-2008, 12:25 AM   #12 (permalink)
My Photos: (13)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SmokeyWren</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: jklingel</div><div class="ubbcode-body"> Now, what the hey is a 5er? Fifth wheel? </div></div>
Yes.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body"> And am I right that a goose neck and a 5th wheel act similarly, just have different ways of attaching to the truck "bed". </div></div>
</div></div>
I thought the towing capacity of both a good quality gooseneck and a fifth wheel hitch were comparable...the difference was mainly that goosenecks lived in the world of construction and agriculture....being better offroad and the fifth wheels lived in the world of RV's as they were more tow and truck friendly.
If I am wrong how so?
Can't you not tow 30K+ on a gooseneck?
Smokey I trust your opinions what's up?
Dave
Current Diesels
2008 F-550 CrewCab 4WD...being upfit currently
2006 John Deere 244J Wheel Loader
2006 John Deere 4720 Cab Tractor 4x4
2003 Frieghtliner Sprinter Van MB power
Past Diesels
2006 F-350 Lariat CrewCab-LB Dually 4X4 PSD Tow Boss Pack Chrome Pack,Loaded...Black Tan
Fuso FG Cabover truck
2002 New Holland TN-75 Full Cab 4x4 Tractor
2000 F-450 Reg.Cab 4x4 StakeBody Plow beast
2004 John Deere 3800 Articulated Telehandler
2005 F-350 CrewCab 4x4 sb/srw PSD Dark Stone
2002 Excursion PSD
2000 Excursion PSD
2002 F-350 XLT CrewCab 4x4 PSD sb/srw
2000 F-350 XLT CrewCab 4x4 PSD lb/srw
1999 F-250 XLT SuperCab 4x4 sb/srw V-10 (oops)
1999 GMC Kodiak Flatbed Car Hauler, Cat Diesel pwr
SuperDutyDave is offline
Old 01-09-2008, 04:14 AM   #13 (permalink)
Bill1013's Avatar
There are several GN hitches rated at 25,000 GVW 6,000 tongue for around $400, not installed. Bed rails or flip up styles. Reese - Hidden Hitch - Super Glide and others. If you would go with bed rails for the GN you can also fit the regular 5th wheel hitch on them. Go GN as they can swivel a lot more than a 5er hitch.
If jklingel lives in Fairbanks, he should know that the Alcan is really one rough road in spots. He would do well with a GN.
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo Radio SD & Tape 126,700 03/08 Build date 03/99
Rebuilding engine. 92 F350 7.3 IDI CC LB dually Banks turbo US Gear O/U ENGINE IS SHOT !
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
Reman IP - New Delphi Injectors Beru GP's New radiator & hoses New WP
Dual Exhaust 3"X18" resonators
Soup bowl gone, 4" intake W/AZ filter
Cobra CB W/Weather Interrupt - Dual Trucker Antenna's
Blk. Grill W/Brush Guards - Fog lights - Rally driving Lights. GN 20K & Reese 16K 5er hitch
http://community.webshots.com/user/oldbull8?
Formally OLDBULL
Toys: 1984 Coachmen Leprechaun F350 Chassis 460CID 92K miles.
30 ft. Jayco Jay Designer 5th wheel.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One flash and it's gone.
Bill1013 is offline
Old 01-09-2008, 05:37 AM   #14 (permalink)
Before you plan on a gooseneck/fifth wheel,you should realise that they typically increase the weight at the front of the trailer from 10% trailer tow to 20 percent. I dont know any of the specs for your truck...you might want to check it out for yourself.A 14000 pound gooseneck would be 2800??? pounds added to your rear axle at full load.
MrNECSteve
mrnecsteve is offline
Old 01-20-2008, 07:01 PM   #15 (permalink)
bier-man's Avatar
Listed rating?
I would assume that any listed rating would have some margin built in for safety.
I've been pulling a travel trailer that has a GVW rated at just over 10000 lbs. My hitch is rated to 10000. I am using a 12000 lb rated Equal-i-zer for load distributing and sway control. Our previous TT was rated about the same as this one, but did not produce as much squat in the Ex as our Coachmen. It must be a little heavier tongue weight.
If this thinking is wrong, what are my chances of having a problem with my hitch? The longest trips we've been on were like 150 miles one way and I have not seen any issues when I have inspected the hitch mounting.
2000 Excursion 7.3L, Severe Duty AIS, 4" Exhaust, 'A' Pillar ISSPRO EGT-Boost-Trans Temp, Diablo Sport Predator Tuner.
2006 Coachmen 31DSB TT
bier-man is offline
» Site Navigation</
