Old 04-26-2005, 02:29 AM   #1 (permalink)
SteveHeywood's Avatar
Freeway Hop
Towing a travel trailer on concrete freeways, ESPECIALLY those in the LA Basin can range from a minor problem to a VERY PAINFUL experience.
My 2005 F250 towing my 30' Airstream is PAINFUL on concrete freeways. The suspension on my truck is still factory stock. Normally I would replace my OEM shocks with a set of Bilsteins but wonder if that will make my problem better.
Has anyone used a set of Rancho adjustable (either RS900 or RS9000) shocks with the in-cab control while towing a trailer? Were you able to adjust the shocks to the point the hop either went away or was at least bearable?
Thanks,
Steve Heywood
2005 F250 Crewcab Shortbed 2WD 6.0L
Ferndale, WA
SteveHeywood is offline
Old 04-26-2005, 04:28 AM   #2 (permalink)
Re: Freeway Hop
Steve ...
I just replaced my stock shocks last month with a set of Bilsteins. They have made a big difference in the ride when towing.
When I removed the stock units ... I could move them in and out like a squeeze box. Not so with the Bilsteins! [img]/ubbthreads/images/graemlins/cool.gif[/img]
TrailerGypsies.com
<font color="9D21AF"> '04 F-350 Lariat, Ordered: 10/17/03. Engine: 11/13/03, Born: 11/17/03, Delivered: 12/04/03.</font>
<font color="blue">Husky Liners, Cyclops, Fumoto, Line-X, BrakeSmart, Bilsteins, Hensley Arrow, ITC/AIC Bracket,[/b] X-Monitor[/b], C-Bet'r Mirrors, SnugLid.</font>
2004 Airstream 34 ft. Classic
Diesel_Danny is offline
Old 04-26-2005, 10:22 AM   #3 (permalink)
Re: Freeway Hop
Yes i just put the new 9 position rancho's on my truck with the incab adjustable remote.Makes towing a trailer much more enjoyable and when i crank um up to setting 9 my truck corners in the hills like a sports car.It does help with the hop,you just have to find the right setting for the wheelbase/freeway you are on but easy to do with the incab remote.
http://community.webshots.com/user/moooboy
69 Dodge Super Bee,383HP,4 speed,#'s match
70 Barracuda Gran Coupe,383hp,#'s Match
95 F250xlt,PSD,SC,LB,4X4OR,Evo,4"ex,800 watt CD,Homemade Tymar,Rancho 9000's W/ Remote,MM 12k Winch/Cradle,F@R Recievers
Suzuki Vinson 4x4 ATV
Ford 1510 Diesel tractor,4x4,loader
2006 Dodge Magnum SXT
2006 Honda VTX 1800S spec 3
AQHA QuarterHorse,1HP,Very Fast
moooboy is offline
Old 04-26-2005, 10:38 AM   #4 (permalink)
Re: Freeway Hop
No flaming intended, but you'd think for $40K the truck would come with decent shocks.
FWIW, I tow almost every day and haven't noticed anything out of the ordinary or been displeased in any way with the ride of my particular truck. Perhaps Ford switched to different shocks post-2003 or went to a different vendor?
2003 F-350 SRW XLT 7.3L 4R100 PSD 4x4 Supercab SB 3.73
1985 Chevy K20 6.2L Turbo-400 3spd auto 4x4 4.10
2003 Ford Explorer XLT 4.0L V-6 5-spd auto 4wd 3.55
16' American Hauler tandem axle cargo trailer
NRA Life member
Wobblin-Goblin is offline
Old 04-26-2005, 11:09 AM   #5 (permalink)
Re: Freeway Hop
I don't think the problem is with the shocks on the truck. I recently put on new Monroes and the ride is much better loaded or pulling my tag along car trailer. When I hook up the 5th Wheel the bounce is still there. If you will look in the rear view mirror the problem is the 5th wheel bouncing. This causes a jerking condition between the 5th wheel (11,000#) and the truck (8,000#). Most of the heavier (top of the line) 5th wheels and toy haulers come equipped with shocks.
I have spoken with several people on the trailerlife (www.trailerlife.com) forum and they swear by Monroe's add on shock kit for 5th wheels. They say that once you make the bounce go away in the 5th wheel you will have no problem with the bounce in the truck. I plan to add this kit to my 5th wheel this summer.
Go to http://www.monroeheavyduty.com and click on Trailer retrofit kit. You can order the kit and shocks for around $250.00. It's supposed to be a do-it-yourself kit.
Firefighter9208
Early 99 (3/98) Extended Cab F 250 XLT 4X2, PSD, 6 Speed, LWB, SRW. 140,000 miles. LUK Clutch, C-BETR Tow Mirrors, Muffler Delete Pipe, Removed Catalytic Converter, Autometer Dual A Pillar Guages with pre-turbo Pyro and Boost, SCMT 1705 Max Tuner, Tymar Intake from Airflo.com. 265/75/16 Firestone Transforce A/T's. Fumoto Drain Valve.
2006 Volkswagen Jetta TDI (wifes car)
2004 Keystone Cougar 314EFS
2004 Kubota M4800 W/Bushog Loader
1969 Mustang Mach 1 351W
1990 Jeep Wrangler
firefighter9208 is offline
Old 04-26-2005, 01:34 PM   #6 (permalink)
johnm's Avatar
My Photos: (138)
Re: Freeway Hop
I believe the truck does come with decent shocks. unfortunatly, LA basin does not come with good roads. considering that they are always working on them, they are about the worse ive seen anywhere in the USA.
i put the rancho adjustables on mine so i could go to LA to visit my kids. didn't need them any where else that i drove the truck before going to LA.
Sorry, it takes me so long to respond. I have difficulty typing and seeing small type. I can read better if it is in caps, so I'm not shouting, just trying to see what I type.
2004 VW Golf TDI - Automatic, 100 HP Diesel gets 42 MPG around town. XM Satellite Radio
2001 Monaco Knight - 265 HP Cummins gets 12.5 MPG towing the TDI
click on or cut & paste for forum rules
http://www.thedieselstop.com/faq/forumrules.php3
johnm is offline
Old 04-26-2005, 02:57 PM   #7 (permalink)
Re: Freeway Hop
Not having driven on Your roads it's tough to be sure but since You mention Concrete roads specifically, I think the problems are the ROADS. The slabs between expansion joints are angled like wash boards, and sets up a oscillation or bucking motion in the truck/trailer combination. Used to be REAL bad in the semi-tractor/trailer I drove 20 yrs ago especially when pulling 40 ft trailers. 45's &amp; 48's were smooth but 40's almost seemed to bounce Me right out of the seat. The harmonics of the wheelbase amplified the bucking. Longer wheel base canceled the bucking out. Shocks may help some but Your State's DOT needs to grind the pavement smooth! Even brand new concrete in WI has to be ground sometimes.
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
294,000 mi & NO Problems, LUK Clutch, and the Cat is buried in the back yard!
Dr.Evil is offline
Old 04-27-2005, 10:50 AM   #8 (permalink)
Teebird's Avatar
Re: Freeway Hop
Steve, my 96 Chevy and my Ford both did/do it. It is the roads in combination with the wheelbase and suspension on the trucks. I replaced the shocks on my Chevy that came stock with Bilsteins, Z71, at 60k miles with Rancho's because of this same issue and noticed no difference. I'm sure the Bilsteins were fine on my old truck. However, I did get the super duty valved Bilsteins on my F250 when I got the lift and the truck rides better than stock.
Yeah, would think in Kalifornia after paying over $500 this year for my registration that they could fix the roads. RIP OFF!!
2003 F250 XLT 4x4 Sport Crew Cab,
Built May '03, Bright Red, 6.0 Auto, ESOF 4x4, 3.73LS, 4.5" Edge Lift, 315/75-16 BFG KO A/T's, Polished/Clear Powder Coated Diff Covers, Weld Cheyenne 8 Wheels, Line X, Overhead DVD, Torza Tonneau Cover, 30' Fleetwood Gearbox Travel Trailer
Teebird is offline
Old 04-27-2005, 06:20 PM   #9 (permalink)
My Photos: (6)
Re: Freeway Hop
I changed mine to Bilsteins and it helped, but then added Velvet Rides and that helped even more. Bottom line is that I still have some hop, but not nearly as bad. Little hop, not big hop. Now the wife will ride with me, if that tells you anything.
2002 F-350 SRW Lariat,4X4, PSD with too many goodies to list. 182k and a very strong 7.3. SOLD
2008 F-250, SC Lariat, 4X4,Shortbed, Pueblo Gold/black, V-10, 4.10, auto, Delivered on 9/7/07, great looking rig. South Texas bumpers front/rear, Air Raid Intake System, Diablosport Predator, Husky's, JJ's, Ford alarm/remote start, Marathon seat covers, Sirius, PIAA, Access cover, Weatherguard tool box, Rhino liner, Michelins, Duraflap mud flaps, Escort 9500i.
2007 Lincoln LT (wifer's grocery getter)
1996 Ford Bronco EB; almost stock
2007 Kubota 900 RTV diesel with goodies.
pappy's truck
Pappy19 is offline
Old 04-27-2005, 10:09 PM   #10 (permalink)
Re: Freeway Hop
Thanks to all who have replied. Looks like I'll end up trying Bilsteins and will investigate Velvet Rides. Until then I'll avoid SoCal freeways.
Steve Heywood
Ferndale, WA
Old 04-27-2005, 10:51 PM   #11 (permalink)
Re: Freeway Hop
I dunno if you're talking about Los Angeles or Louisiana. If the latter, then I feel ya... if the former, well, I stay outta big cities in Kalifornia.
Southern Louisiana on I-10 is a teeth-chattering experience for many!!
That's TOOTH-chattering for others.
My truck did well on I-20 through LA. I don't remember 20 being as bad as 10 in most places, but it does have its rough spots.
Mississippi was the hardest part of our trip last summer from Macon, GA to Monterey, CA. TERRIBLE roads going through Jackson, I believe.
Best I can suggest is to slow down on the rough spots.
- SOLD: 1991 F-350 XLT crewcab, dually. BTS E4OD. My favorite truck.
- NEW DAILY DRIVER: 2006 Ram 3500 SLT quad cab. 5.9L Cummins, 6-speed manual transmission, nav system, Jake brake. No mods, now or ever. 100% satisfied.
Mike Lewis is offline
