Old 08-09-2006, 10:02 PM   #1 (permalink)
My Photos: (12)
Fuel mileage comparisons between 5er and travel trailer
Do any of you have any hard data on the difference in fuel mileage to expect when dropping from a 32 ft 12K loaded weight 5er to a 30 ft travel trailer that should gross arond 8500 lb loaded? I am considering giving up the 5th wheel to make hauling my cycles in the back of the truck (wife won't go for a toyhauler) and was wondering if I would gain any fuel mileage.
2003 F250CC shorty Lariat 7.3 PSD, Jody Tipton Flash, Autometer boost and EGT gauges, Nordskog trans temp, fuel press, voltmeter. Banks exhaust, Precision TC, Transgo tugger, Hyd oil filter on trans return line, custom HD y-pipe boot clamps, Take 3 5er hitch, PML pans, Manual TC lock and indicator, No-Start switch (anti-theft). -- 89 F250 7.3 IDI 4X4 tuff truck--92 Jetta eco-diesel, 425,000 miles and still going strong--Honda CRF250, Suzuki DRZ400 SUPERMOTO.
dieseldrive is offline
Old 08-09-2006, 10:05 PM   #2 (permalink)
Re: Fuel mileage comparisons between 5er and travel trailer
[img]/ubbthreads/images/graemlins/shrug.gif[/img] I doubt there would be too much difference. Maybe some fuel savings, but probably not enough to make a difference.
2005 Arizona Beige F350 XLT FX4 6.0 CC shortbed, 3.73 ls rear, 18" wheels, Tow Command. Additions: Vent Visors, bug guard, Fumoto Valve, Timbrens. Traded for...
Current Truck -- 2008 Black F350 XLT 4x4, 6.8 V10, CC Long Bed, 4.10 rear, 18" wheels, IBC. Additions: Chrome Step Bars, Chrome door handles, Silver barbed-wire pin stripe, B&W Turnover GN ball
barrelhorses is offline
Old 08-09-2006, 10:59 PM   #3 (permalink)
I wouldn't anticipate any real change in fuel mileage. The lighter TT is going to hit just as much wind as your fifth-wheel, so the change in weight isn't likely to make much of a difference. You'd likely see a significant mileage gain if you pulled a pop-up, but I don't think they make a pop-up that will compare with your current 32 foot fifth wheel.
2002 F250 4x4
T-444E 6-speed
Alan_Hicks is offline
Old 08-10-2006, 10:19 AM   #4 (permalink)
Our fiver has a stand-up bedroom so it is 12 feet tall which translates into a big wind load. I have seen basically three heights of fivers ...those where you have to crawl into the front bed, those where you have to bend over next to the bed, and those where you can stand up next to the bed. A bumper pull trailer is shorter than most fivers so I would think wind load would be lower for it than a fiver giving better fuel mileage at highway speed.
2002 F350 4x4 CC DRW Lariat 7.3 auto 4.10 LS diff.(bought 5-05 @ 76,000 miles) Pyro, Boost, and Trans gauges. AIH delete. Tru-Cool Max trans cooler. Magnafine filter. Royal Purple MAX synthetic ATF. 55 gallon aux bed tank. 2LO Mod.
2002 Holiday Rambler 30-SKS Alumascape fifth wheel
24 foot gooseneck livestock trailer
1940 McCormick Deering restored Farmall H, used weekly (the grand-daddy of International)
Used goats for rent
twobit is offline
Old 08-10-2006, 11:58 PM   #5 (permalink)
Cool_Canuck's Avatar
My Photos: (12)
Drag has more effect than weight on fuel milage. Just guessing, but I'd bet you see more than 20% improvement in milage from a high fiver to a TT.
Here is most of what you need to know on getting your 7.3L started and how to operate it in the cold winter months. These posts use to readily available, but they've been hid in a subforum top of the 7.3 Power Stroke Engine and Drivetrain forum.
Winter Operation (How I Do It)
Hard/No Start? Check here first
2001 F250 XLT 7.3L SC/SB 4x4 (ESOF) - Tranny Upgrades; SCMT 1705; AIS Intake w/trimmed Snorkel; ZooDad; Turbo back 4" Exhaust; Issopro Pillar Mount Gauges; TC lockup LED; Auto Magic Heater Bypass; 2W Low Switch.
Cool_Canuck is offline
Old 08-11-2006, 12:32 AM   #6 (permalink)
I'll take that bet.
What you guys aren't putting into the equation is that the nose of a 5er in the bed changes the aeros of the entire vehicle. A truck pulling a tt still has the wind of the truck coming down over the tailgate heading down hitting the trailer. So a TT has what about 7 feet of surface height in front, and a High profile 5er can be as tall as 13.5. And I don't know about you guys but my truck cab is almost 7 ft high, 13.5 minus 7 is 6.5 ft of surface height. Pretty close to a wash in my book.
Main reason I can't see 20% improvement is this.... Let's say he's getting 9-10 mpg pulling the 5er. Add 20% and you are almost 11-12 mpg. I barely get 12 with a dinky little 7x14 cargo trailer that weighs 6K lbs. And he's gonna get that with a TT that's taller and wider and outweighs me by 2500 lbs? In addition I get about 10 mpg with the 24 ft enclosed trailer at 10K lbs.
Trinity
Early 99 6spd (Eaton Fuller Knob), 285x75 MTR's, DI 4 POS Chip, Walker BTM, listening to XM Delphi skyfi, pulling 24 ft full of Mechanical Bull, heading to a bar near you!
Truck pics
tsaelens is offline
Old 08-11-2006, 03:57 PM   #7 (permalink)
I went the other way
We had a 27ft TT grossed around 8500
Went to a 35 ft fiver grossing 12k +
noticed maybe .5 mpg loss now that was with my 7.3 .... just got an06 6.0 haven't towed with it yet
2006 F250SD 4X4 Extended cab short bed 6.0 Lariat 6 speed manual
all stock for now
DA28 is offline
Old 08-14-2006, 12:19 AM   #8 (permalink)
teamroper60's Avatar
Not really a good comparison, but two weekends ago, I towed a 23ft TT and got 12mpg. This past week, I bought a 29ft mid profile (the stand up, but duck height) 5er. With the 5er in tow, I got 11.5 but I was in far hillier terrain. Looks to me like the two were a wash mpg wise and the dry weight of the 5er is more than the wet weight of the TT....
2003 Toreador Red/Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03, (still running the original flash!), AIC, MBRP turbo-back exhaust, Tuning by Total Diesel Performance, AFE PG7, Fumoto valve, B&W hitch, Di-Pricol gauges, Voyager brake controller, DIESELSITE Coolant filter, Timbrens, Rancho RSXs, Michelin XPS Traction's, a whole bunch of "bling", Connex 4300hp, JL Audio 275w amp w/ 12" sub, Alpine door and rear seat speakers. 376hp
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 08-14-2006, 10:58 AM   #9 (permalink)
I pull a 30'TT with my truck. It's an older trailer (2000) and more boxey looking, about 9k lbs loaded up. I do have a cover on the bed of my truck. Milage is between 10 - 12 mpg and I'm usually doing close to 68mph.
Lately I've been out looking at some of the new TT's and noticed some of the new shapes the manufactors are doing to the fronts of these trailers. One is a wedge and the other is very curved back. Both of these look like they would move the air flow out around the trailer much better than my box is doing and that should cause increased milage numbers.
2k F250 XLT CC 6sp PSD, 3.73 LS axle, Superchip, W-D Turbo Brake, Memphis speakers & 5ch amp, WD-Pyro & Boost gauges, Rechargable MagLite, quick disconnect jumper cables, CAT batteries, ARE tonneau,
"unaable" on the tailgate!! New door actuators!!
T-304 Stainless exhaust turbo back, Southbend clutch
Tina is offline
