Re: fwd mod
2 wd low range
There are two easy ways to do this. If you don't want to cut wires, (and you won't use it very often) you can just unplug the 3 wire connecter on the Pulse Vacuum Hublock solenoid that is located on the passenger side wheel well. If you are going to use it often, or don't want to pop the hood and unplug and then have to replug, you can run a switch into the cab. On the same 3 wire plug you will cut the center wire and tie an off/on switch in the cab into it. Leave the switch on for normal operation and cut it off to keep the 4wd from engaging. The only thing to remember is to cut the switch off BEFORE you start switching the ESOF on the dash. These instructions are on a 2002.
If you need help let us know, Joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
