Gear Vendor or US Gear Over/Under drive units. - Diesel Forum - TheDieselStop.com
Old 08-16-2007, 01:32 PM   #1 (permalink)
For those of you who have either the Gear Vendor or US Gear Over/Under drive units I would like to hear your comments. How long have you had it...any problems with the units...advantages of either unit...positive and negative comments welcome.
Thanks,
Griz
02 F250, 4X4, 4R100, 3.73, Amsoil Air Filter, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug and Intercooler boots, 6.0 Transmission Cooler.
Griz is offline
Old 08-16-2007, 05:28 PM   #2 (permalink)
STurbo90's Avatar
My Photos: (9)
Re: Gear Vendor or US Gear Over/Under drive units.
http://forums.thedieselstop.com/ubbthrea...rue#Post3416621
Might want to search under this users name, he has a lot of posts about auxillary trans.
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 08-20-2007, 11:51 PM   #3 (permalink)
You want the one that bolts between the trans and tansfer case, forget which one.
Wayne B
2000 F-250 XLT PSD 4X4 ESOF Auto, SC, LB, Gauges, Mag-HyTech Trans Pan & Rear End Cover, <font color="red"> (((XM))) Inside</font>, ATV Racks w/ Two Kawasaki Prairie 400 4X4's sitting on them, 25' Rockwood TT. Ashburn, Va. Member # 103 Pictures
www.CarpathiaHost.com
Wayne B is offline
Old 08-25-2007, 01:26 PM   #4 (permalink)
Wayne B
[/ QUOTE ] Wayne...why do you say that?
Griz
Griz is offline
Old 08-27-2007, 01:10 AM   #5 (permalink)
Griz,
I ran a US Gear under drive for twelve years with no problems. It was mounted between the transmission and the transfer case. I loved that truck and hated selling it. Gear Vendor is sold only as an overdrive and it replaces the tail cone on the transfer case or transmission.
Wonderer
Wonderer54 is offline
Old 08-27-2007, 01:42 PM   #6 (permalink)
Wonderer54...what type of transmission were you using with the US Gear Over/Under drive unit? Who did the install for you? Did you notice any mileage gains or just made it easier when towing to have more gears available?
Griz
Griz is offline
Old 06-07-2010, 06:34 PM   #7 (permalink)
US Gear Dual Range transmissions
Griz,Wonderer54,or ?
Who now handles used US Gear Dual range transmissions I guess made by Doug Nash or And also Mile Marker? US gear got bought out and had no info when I called.I would like to put one in my 1934 Packard. The 2 speed box seems like the simple way of going .I may also want one for my dodge truck .
Packard1
Packard1
Packard1 is offline
Old 06-14-2010, 12:25 AM   #8 (permalink)
the gear venders works as an under and an over drive, i had one installed on my 63 fairlane becase it has a 3 speed in it with 4.10s...not good on freeways, ill soon buy one for my 97 f350 too, it has the ability to split gears which is mainly why i want it. Example with out gear vendors: your half way up a big nasty hill and are losing momentum, so you drop a gear, now your either stuck babying that gear or puting it back into drive (in which you will probably lose momentum again) orrrrrrrrrrr with the gear vendors when you drop a gear and get back up to a nice speed hit the gear vendors switch and its like a over drive for that gear! i love it for my car and would its even better while towing and on a diesel engine..... my car also runs cooler now when its in the overdrive funtion...big plus for me
zappattack1800 is offline
Old 06-14-2010, 12:28 AM   #9 (permalink)
forgot to add that mine was installed by mustangs and fast fords oc, in santa ana california. the shop does mostly mustang things but i talked to the owner and they are licened to do gear vendors installs on all cars and trucks so he told me when ever i want it, he would order it for me and do that install too....i got some pics i can post if you want....just dont flame me for a gasser car on a diesel truck forum
Old 07-01-2010, 10:34 AM   #10 (permalink)
Window&Door's Avatar
I have a Gear Vendors unit out of a motorhome that I want to put on my truck. Not sure if it can be done though... I mainly want it for double overdrive on the freeway. I talked to Unitrax and Gear Vendors yesterday and found that this will cost close to $2,000 to make it work with my truck... Even though I have a complete, near new unit with electronics.
1996 PSD supercab longbed 4x4 XLT white/grey int. TS 6 position chip, New turbo w/1.00 Turbine housing 3" dp 5" exh. no cat, no muff 6" stainless slash tip. DIY Napa intake Sony Xplod stereo, door speaks, amps and subs. Autometer gauges and pod E4OD 150k miles. GEAR VENDORS! One piece rear drive shaft, two piece front shaft 4" Superlift on Weld wheels wrapped with Pro-Comp Xtremes. Clean. All rebuilt fuel system/new pump, new SD Intercooler, Modified Banks Pipe kit. **********SOLD**********
2002 Silverado 5.3 1500 2wd stock Pioneer Navi 1 daily driver 110k miles
1996 Kawasaki SXI750 twin big Mikunis factory pipe R&D head/rideplate kustom kut solas impeller ported/polished big power, little ski 58mph w/235lb rider on VP-C14
1988 Suzuki LT500 Quadzilla
1978 Suzuki FZ50
1977 Suzuki FZ50
1978 Motobecane 50V
Window&Door is offline
