Old 10-27-2007, 11:42 PM   #1 (permalink)
Going to be needing tires soon......
Im going to be needing new tires for my 96 f350 4x4 crew cab with an 8ft bed soon, it has 285/75/16's on it now.
It has negotiator radial A/T's I wish I could find them but i have no idea where to find them.
I want to get either D or E load range tires.
I have a few tires in mind that a am looking at if i cant find the negotiator radial a/t's.
The ones I like the most are the BFG A/T KO's with the E load rating.
I found a set of tires on ebay that had the same tread pattern as the BFG's but for $200 cheaper and there only a D range tire tho.
Click here to see them....
Also, I like the looks of the Nitto Terra Grappler click to see
What do you have on your trucks? How many miles do you have on them? how many hiway miles??
thanks
1996 Ford F350, 7.3 PSD, crew cab, 8ft bed, 4x4, 5 speed manual, 4.11 gears. 184,000 miles. 3x4" down pipe, 4" exhaust with 5" polished SS tip, gutted EBPV, chrome nerf bars, autometer ultra lite pyro and boost gauges, alpine cd player, alpine speakers,garmin GPS.
"Real trucks have 3 Pedals, 2 Sticks, and No Spark Plugs"
gilroyracing is offline
Old 10-28-2007, 01:14 AM   #2 (permalink)
Re: Going to be needing tires soon......
I have 285/75/16 Nitto Terra Grappler E load. I only have 1,200 miles on them so far, but my truck has never road this good. You will defintley find excellent traction with them.
01' F250 PSD CC 4x4, Autometer 3 pod, AFE PG7 Stage II ,TN BB, non-EBV, DI bellow up-pipe, ITP Annilator, HP X-Over, Silverline 4in T-Back, 6.0 Trans Cooler, Dp Tuner F5, BTS VB, Detroit True-Trac 3.73, Powerslot Cryo/ Hawk LTS, Rotella ELC, Nitto Terra 285/75/16E on Alcoa 16x8.
Torque37 is offline
Old 10-28-2007, 10:07 AM   #3 (permalink)
Whatever you do stick with the E load range
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 235k miles and thousands of $$$$ in maintenance and repairs.
NickKent is offline
Old 10-28-2007, 12:50 PM   #4 (permalink)
Where did you get your Nittos with a E load rating?
Old 10-28-2007, 11:19 PM   #5 (permalink)
Discount Tire.com they even have the BFG in E load rating.
Torque37 is offline
Old 10-31-2007, 01:32 AM   #6 (permalink)
Cooper Discoverer ATR's. Love them and wear great, got them in the load range E.
92 f250 4wd supercab 7.3, e4od, 4" piped and 5" tip, Autometer pyro, boost and trans temp., 3.55 gears, oxford white, tint, uniden w/ 3' Firestick, Carr steps, Hypermax turbo, love that whistle, G code injectors and turned up pump. She's a runner!!
More to come...(just don't know what yet! Cummins?!)
jkeller3 is offline
Old 10-31-2007, 11:17 AM   #7 (permalink)
I know this is apples to oranges but I have 35 x 17 Nitto Mud Grapplers Load Range E on my Jeep. The side wall on these tires is great! I have not cut one yet!! And my Jeep rides nice but they are a bit loud on the road. Love these tires!!
2008 F450 4X4
ridge123 is offline
Old 11-01-2007, 01:31 AM   #8 (permalink)
I bought the F250 with 40K miles it had bald Good Year Wrangler 285/75/16's on it. Shortly there after put 295/75/16 BFG ATKO's on it for $860. At 120K miles I put a second set of 295/75/16 BFG ATKO's on it this time they were $810. I swapped the tires back and forth between the F250 and X and at 35K miles I had a blow out at 80mph in the X. At 55K miles another one had a side wall puncture after my wife hit the plow. The two originals were put out of commision at 70K miles. The truck now has Nitto Grap's 295/75/16 at a cost of $705. They don't spit rocks like the BFG's and have better traction. Actually they've been on the truck for a few months and it's stayed in two wheel drive since.
Bought the X with 104K miles with brand new Good Year Wranglers and couln't wait for the day they were to be replaced since they were stock size, don't think they got even 50K miles on them. Now the X wears a set of 265/75/16 Ravo E loads and there nice.
The F350 has 255/85/16 which is the largest that will fit and I can't wait to remove them in favor of 22.5's.
99(4/99)F350 PSD 4X4 crew cab long bed dually lariat isspro triple pod air bags with compressor
99(6/99)F250 PSD 4X4 X-cab short bed xlt 5in str8 piped air bags autometer ultra light triple pod junk yard pcm running 22 psi 250k miles bought 8/15/01 w/40k miles first diesel
00(12/99)Excursion PSD 4X4 limited
65 Mustang 289 V8 4brl 69 GTO 400 4spd 99 Neon R/T
04 and 09 PJ 15k dump trailer 04 H&H 9K tilt bed 98 Haulmark 7x14 enclosed
86GLHS is offline
Old 11-01-2007, 10:32 PM   #9 (permalink)
I think im going to go with the nittos
Old 11-21-2007, 10:37 PM   #10 (permalink)
bersa45's Avatar
I have Pirelli scorpion str 265/70r17 original tires with 96500 miles on them. I wanted to get 100,000 on them but ran over some screws and developed some air leaks. They have 6/32 left. I am buying the exact same tire again and hope to get another 96,500 on these also.
2005 F250 CC 6.0 3.73 rear end white/silver short bed 4x4 lariat loaded, Sirius radio,cb,locking glove box,Ruger SR9,harpooned fuel tank pulling 33' Rockwood TT, with 105,001 comfortable miles!!
bersa45 is offline
Old 11-22-2007, 08:17 PM   #11 (permalink)
Lightningfast01's Avatar
My Scorpions were gone at 52K. BFG Rugged Trails made 64K, Nitto's are wearing a little faster.
2005 F250 FX4 SuperCab SWB in DSG
Buckstop rear bumper American steel!
Daystar baja bar with PIAA Racing 80's
Quad pillar Air, trans temp, pyro, boost
Magnaflow 15954, ATS studs
Transfer Flow 46gal midship tank
Firestone Airbags 2400 kit ViAir 250C compressor
Eaton TruTrac, Rancho 9000's, Skyjacker 1.5" rings
ViAir 380C@200psi, 5gal tank, Siege Anvil train horns say move *****!
Lightningfast01 is offline
Old 11-28-2007, 08:39 PM   #12 (permalink)
Michelin LTX mud/snow in load range E...can't beat em
2002 7.3L PSD F-250; 4x2; Crew Cab; Short bed; 3.73; Autometer Pyro, Trans Temp, Boost; Tekonsha P3; CCV Mod; New Ball Joints, Tie Rod Ends, and Drag links at 126k Miles; Dieselsite Coolant Filter, billet thermostat housing, 203* thermostat; Fleetrite ELC; Bilsteins from CaryT; 126k on the clock
Now using Autoenginuity, if you are in the KC area and need to check out some codes on any Ford, shoot me a PM.
rosspulliam is offline
Old 12-06-2007, 10:23 AM   #13 (permalink)
96STROKE's Avatar
My Photos: (6)
My vote is for the BFG AT range E. I have had a set of D's on the truck til it hit 50k then when the range Es came out, went with a set of them. You can't beat them for all around driving, quiet on the road. The range E tire has worked out very well for towing the 5th.
'01 F350 Lariat PSD 4X4 CC SWR LB auto
Superchip 60hp, 4" cat back, A-pillar w/auto meter gages, Firestone Air bags, Bilsteins, Radio Speed Volume Mod, XM Roady
Photos
96STROKE is offline
Old 12-06-2007, 10:55 AM   #14 (permalink)
88beast's Avatar
i forget what i have now but they have a good 30k on them with minimal wear
but id say get a good steering tire not a drive tire
most on here use drive tires (wider)
a steering tire is narrower usualy the side wall bulges out past the rim but tread is within the size of the rim
they also have 2 weight ratings for 2 pressures if you buy a good set
mine are rated at 45psi 2800 per tire and at 65 psi around 3500 per tire if i rember correct
they are almost 200 each though for my little known brand that idr what its name is
ive seen a psd with all four tires steering go through snow up to mid grill at 30 mph (like 6 blocks) no wheel spin
and then he broke through a snow bank 8ft tall with his truck
this snow had the newer (99) stock psd they used to plow stuck in place
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
http://youtube.com/watch?v=ILAQuHNAGE0
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
88beast is offline
Old 12-07-2007, 12:48 AM   #15 (permalink)
+1 for the Nitto Terra Grappler!
'97 350 CC 4x4, 240k miles, ORIGINAL TRANS, tow up to 17k in Los Angeles area for work, 90 Gal Transfer tank, DIY intake with NAPA 6637 filter, ALL STOCK motor and exhaust, NO chip or programer...ALL that is about to change.
Local399 is offline
