I have to keep changing my tires on my SRW SuperDuty because of towing heavy. The truck either pulls a 36 foot 5er or a 28 foot car hauler. I rarely drive the truck when not towing. So what tire will last. I realize that it is a SRW, but it is paid for, so I am not looking for a new DRW with a payment. Hoping to find a tire that will hold up a while on the SRW while towing heavy.
I am looking at the BFG Commercial T/A but I am not sure. People also talk highly about the AT Revo but, again, nobody seems to talk much about tire life under heavy loads.
Actually the stock Steeltex lasted the longest and handled the best out of all that I have tried. I am thinking about the Transforce replacement but not sure of the changes.
Any advice?
Thanks!
2004 Expedition
2003 F250 C/C V10, Banks Power Pack, Transcommand, 4.30LS, MagHytec Diff Cover, B&M Deep Trans Pan, 16K Super Glide Hitch
2006 Thor Vortex 36' 5er Toy Hauler
I tow a reasonable amount and have been using Michelin LTX m/s. I get about 50K and they handle well. I live in an area where snow is not a problem so that is why I chose these tires. They also are very quiet on the highway. I have found that when towing the key is to set the tire pressure to the amount needed for tongue weight. Most of the time that is 65- 70 PSI for me.As this is my daily driver also, I drive with 60psi when I'm not towing.
'99 F350 SRW.3:73 Gears TTS CHIP,SPDIESEL EXHAUST BRAKE,AFE MAGNUM FORCE AIR INTAKE,FORD REPLACEMENT TORQUE CONVERTOR,DIESEL INNOVATIONS FUEL REGULATOR SHIM KIT, REMOTE START, NEW FORD CPS, BLUE IH CPS as SPARE ,BLACKCLOUD DIESEL HX OIL LINE.
I have the Firestone Transforce A/T 265/75/16 and love them. They have 15,000 miles on them and still look new. They are somewhat aggressive, but not too much road noise. I pull a Keystone Cougar 314EFS, 34' fifth wheel, and 16' bumper pull loaded heavy quite frequently.
My SRW 2wd was very easy to get "stuck" with Michelin LTX M/S. I couldn't even pull a trailer of hay into the pasture. With the Firestone Transforce A/T I have had much less troubles getting "stuck" and can now pull a trailer into the pasture w/o getting "stuck" on wet grass. JMHO [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Firefighter9208
Early 99 (3/98) Extended Cab F 250 XLT 4X2, PSD, 6 Speed, LWB, SRW. 140,000 miles. LUK Clutch, C-BETR Tow Mirrors, Muffler Delete Pipe, Removed Catalytic Converter, Autometer Dual A Pillar Guages with pre-turbo Pyro and Boost, SCMT 1705 Max Tuner, Tymar Intake from Airflo.com. 265/75/16 Firestone Transforce A/T's. Fumoto Drain Valve.
Ditto on the 'E' rated Michelin LTX. I use them much as does sailboatin. I'm over 50k on them, most unloaded but regular towing of 7500-10k added trailer/load. I inflate to 55-75k, following the load table. Good on dry or wet pavement, but slick on the drive wheels on wet grass/pastures. No snow/ice experience to speak of. These are not, by any means, for a/t or off road use, but a long wearing, stable, fine handling and riding tire for on road use and loads. I have found the Michelin/Bilstein shock combination [on a 2wd] a great improvement over stock, loaded or not. Smokey vouches for the Michelin highway ribs as well.
What did you guys pay for the Michelin LTX? Is there a good place to get them?
I have been running E rated tires but I always set mine at 80 PSI because the truck is loaded >90% of the time. I am not sure of my pin weight but he GCW of the truck and 5er is at 21,000 lbs.
The worst tire I have tried is the Dunlop Rover Radial AT. That tire makes the truck feel squirly and the thing wears out fast. I was using mostly AT's but maybe I should use the highway rib or All Seasons. I am on highway most of the time, but I do venture into dirt occasionaly and I have pulled many times in light snow. If the snow is too deep, I don't go that direction [img]/ubbthreads/images/graemlins/smile.gif[/img]
Thanks!
2004 Expedition
Got mine through tirerack.com, around $145 plus shipping/install in '03. Last year, had a valve stem crack at highway speed, tearing up a sidewall. I replaced the tire with one from a local Discount Tire; they gave me a warranty tire wear credit and I believe I paid around $150, balanced and installed. Check with them. I seem to recall that some have gotten them at Costco, too. You'll appreciate the LTX m/s on dry and wet pavement - a very good handling, smooth riding tire in those conditions. I've had bad luck with wear on Dunlops, too, on cars.
I've shopped around and the best price has been Costco. My store has to order them as they do not carry in stock. I've recently learned that you can order online w/Costco and have them delivered to the store of your choice and when they arrive you can schedule an installation. I've used Tirerack for tires for my Car but have not found their prices competitive for the LTX's. The other problem I have is where I am located There is no Tirerack installer so the shop I have to use zing's me for installation. All in all, I keep going back to Costco. They recently have been filling the tires with Nitrogen as apposed to regular air. The theory is that there is virtually no change in pressure w/te,p changes. This I find is true. However, when I told them about adjusting the pressure for different loads and possibly having to add pressure and then remove later, they just stared at me like I was looney. Anyway, That is one drawback w/nitrogen unless you want to set it and forget it.
I like cooper discoverer AT's. Make sure that you rotate your tires alot. that will help. The Cooper C140 is pricey, but it can be retreaded. That might work for you.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 2.5" axle drop bracket, F350 springs up front, and F350 rear axle blocks. 260k miles. RETIRED.
NEW (to me) 2005 F350 FX4 Crewcab shortbed, SRW, Lariat, auto, V10. 5600 lbs front end.
I've been running the Cooper Discoverer ATRs now for around 4k miles and really like them so far, but can't comment much on the traction etc., but they have gotten good reveiws from other TDS owners and are considerably cheaper than the Michelins.
Larry
__________________ <font color="green">MY PICTURES - Look around ... lots of good stuff </font>
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, <font color="blue">Mustang dyno - 183.9/400.4 stock</font> [img]/ubbthreads/images/graemlins/smile.gif[/img], BTS w/Schaeffer's ATF[img]/ubbthreads/images/graemlins/biggrin.gif[/img] , ITP 3.5"/4" exhaust w/Magnaflow & Aeroturbine,Dieselsite 203* T-stat/Zerex G-05,F.Pwr, Ext/Int. Upgd. pkg,R. Bds,AIC,Tow Pkg, Rear & Slider windows,<font color="red">AMSOIL air, oil-bypass & rear end 75w-140 fluid ,<font color="blue">3/8" fuel sys w/10µ Dieselsite DAHL100 & fuel manifold/sight glass</font>,6 way dr. pwr. seat, Magnefine trans/P.S. filters</font>, husky mats,<font color="red">5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges</font>,Dieselsite coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets" [img]/ubbthreads/images/graemlins/smile.gif[/img], & a 1981 26' Prowler TT(26Y)
Michelin LTX is mentioned several times on this thread. The only "E" rated tire is the LTX A/S.
Note that Michelin has several other "LTX" versions, so make sure you get the right one.
We don't have a Costco around here but Sam's will also order your tires for you at a reasonable price, best in these parts anyway...
Truck Build Date: 03/05 Kentucky
Engine Build Date: 02/28/05 Indianopolis
Purchase Date: 8/05 Sold date: 01/31/07
MPG: 16.08 2007 ytd average; 29k miles
2005 F 250 PSD Crew Cab Long Bed XL Auto
Completely Stock Truck: No Modifications
15 days in shop; a factor in deciding to sell.
I'm running the Cooper ATR's now for about 6000 miles and they do well in rain and snow. So far I'm really impressed. They were $140/tire compared to the Revo's at $180/tire. I liked the Revo's but they are pricey!
New truck: 2009 F-250 4x4 6.4 Torxshift Crew Cab Short Bed Lariat Black w/ Black leather every option
F & A.M. Lodge 266
GeorgeC
"I will own a fleet of Dodges first."
Guys, thanks for all of the input. I will try a set of LTX E rated. Looks like I am headed for Costco! Just gotta keep my wife from buying everything in the store [img]/ubbthreads/images/graemlins/smile.gif[/img]
Thanks!
2004 Expedition
