Old 04-11-2006, 04:29 PM   #16 (permalink)
Re: Good tow tires for SRW?
Good choice. I use the LTX M/S from COSTCO. Great all around tire. I have the LT265/75/R16 in load range E tires.
John
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
JADFPE is offline
Old 04-12-2006, 09:49 AM   #17 (permalink)
Don't think you'll be disappointed. and they do come in the 'E' load rating; mine are 235/85-16s. These tires, slightly 'skinnier' than the 265s, are stock on some F250s [maybe some Xs, too?], might give marginally better fuel mileage and traction [on wet roads]. Little cheaper, too, maybe?
2000 F250 4x2 Supercab XLT; Detroit Truetrac ltd slip diff. w/PML aluminum cover; FTVB; BTM; PF pads in the front. DP Tuner stock/60tow/80econ. 203 'stat, Cat ELC coolant, Gauges, Ford AIS, Bilsteins, Michelin LTX M/S, B&W gooseneck in a Line-X sprayed bed; UWS low profile tool box. Towing a 2004 CM Winstar 4 horse trailer loaded with quarterhorses, whenever possible ....
Wife's New Ride: 1999 Mercedes Benz E300 Turbo Diesel Sedan
Riggodeaux is offline
Old 04-14-2006, 09:31 AM   #18 (permalink)
Toyo has a commercial tire, called the M55 I think? E-rated and used on a lot of commercial delivery trucks that was on the short list when i was looking at new tires. If you can find them have heard nothing but good about them and have good traction in all types of weather. I could not find them so went with the open country AT's in stock size for towing.
Edit: M55 is the tire I am thinking of .
reyjay is offline
Old 04-14-2006, 10:03 AM   #19 (permalink)
kfjensen's Avatar
I like cooper discoverer AT's. Make sure that you rotate your tires alot. that will help. The Cooper C140 is pricey, but it can be retreaded. That might work for you.
I've been running the Cooper Discoverer ATRs now for around 4k miles and really like them so far, but can't comment much on the traction etc., but they have gotten good reveiws from other TDS owners and are considerably cheaper than the Michelins.
Larry
They have done great in the snow/ice for me, I do not tow alot but I had heard from others and my dad runs them on his Superduty towing all the time they are a great tire and will hold up.
Kevin
94.5, PSD, F-250, 4x4, Handshaker, Couple Do-Dads
kfjensen is offline
Old 04-16-2006, 03:49 PM   #20 (permalink)
They recently have been filling the tires with Nitrogen as apposed to regular air. The theory is that there is virtually no change in pressure w/te,p changes.
Any confined gas is affected directly and in direct proportion by temperature increases or decreases. Just costs more. This does make a difference in aircraft tires because it is an inert gas and will not support combustion during blowouts in tires running at 400 to 600 + tire pressures.
datkinsonsr is offline
Old 04-16-2006, 06:16 PM   #21 (permalink)
Dick Cutting's Avatar
My Photos: (18)
Actually the stock Steeltex lasted the longest and handled the best out of all that I have tried. I am thinking about the Transforce replacement but not sure of the changes.
I second that. I got 71,300 on my OEM's and 69,000 on the second set. I just put on a new set of the Transforce's that replaced the Steeltex's. I do some towing but probably not nearly as much as you. The Steeltex's were the R4S tread and the Transforce is basically the same. They are highway rib tires not an AT style tread.
Dick
TheDieselStop.Com Photo Editor/Moderator
May '02 F-350 7.3L SC Lariat 4x4 Auto SRW LWB, XM Satellite Radio
June '97 F-350 7.3L Reg Cab XLT 4x4 Auto SRW, CD and XM Satellite Radio
Dick Cutting is offline
Old 04-18-2006, 11:00 PM   #22 (permalink)
I have a 2001 F-250 six speed manual with 178,000 miles on it.I tow my own Everest fifth wheel and also deliver used travel trailers to wholesalers we use in NC and MASS.The stock steeltex got 86,000 and the second set of steeltexs are on the truck yet with 92,000 on them.I'm going to put another new set on next week.Believe me the tires still have quite a bit of tread and passed State Inspection last month.I run 80 lbs. in the rear tires and 70 lbs.in the front.I have never got such good wear out of tires before.I'll stick with the Steeltex's. Take care Ed from South Jersey
Ed_Hepburn is offline
Old 04-20-2006, 04:16 AM   #23 (permalink)
I have to keep changing my tires on my SRW SuperDuty because of towing heavy. The truck either pulls a 36 foot 5er or a 28 foot car hauler. I rarely drive the truck when not towing. So what tire will last. I realize that it is a SRW, but it is paid for, so I am not looking for a new DRW with a payment. Hoping to find a tire that will hold up a while on the SRW while towing heavy.
I am looking at the BFG Commercial T/A but I am not sure. People also talk highly about the AT Revo but, again, nobody seems to talk much about tire life under heavy loads.
Any advice?
Thanks!
The Bridgestone A/T Revo is the best all around tire for a SRW truck, best traction (especially wet) long wearing (80,000+) and durable casings (I've run obscenely heavy on them) Firebombs should be avoided at all cost when running heavy. I'm not a big fan of Michelins for heavy hauling either, although my experience with them has been on semi tractor/trailers, their light truck tires may be better.
This space intentionally left blank.
444turbodiesel is offline
Old 04-20-2006, 10:05 PM   #24 (permalink)
96STROKE's Avatar
My Photos: (6)
If your after a AT tire for your SRW, IMHO, the BFG AT KO 10ply E range is the tire to get. [img]/ubbthreads/images/graemlins/cool.gif[/img]
I tow fairly heavy, (13,000 lbs) and I get over 50,000 miles out of a set and get the best AT tire money can buy. Great rain, snow, and off road boondocking tire.
If your after a road tire and max milage, [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
'01 F350 Lariat PSD 4X4 CC SWR LB auto
Superchip 60hp, 4" cat back, A-pillar w/auto meter gages, Firestone Air bags, Bilsteins, Radio Speed Volume Mod, XM Roady
Photos
96STROKE is offline
Old 04-22-2006, 08:26 AM   #25 (permalink)
Who makes the Steeltex's that were said to be good?
Also, does anyone have long term experience with Pirelli Scorpions?
Truck Build Date: 03/05 Kentucky
Engine Build Date: 02/28/05 Indianopolis
Purchase Date: 8/05 Sold date: 01/31/07
MPG: 16.08 2007 ytd average; 29k miles
2005 F 250 PSD Crew Cab Long Bed XL Auto
Completely Stock Truck: No Modifications
15 days in shop; a factor in deciding to sell.
05F250PS is offline
Old 04-22-2006, 10:29 PM   #26 (permalink)
Steeltex's are Firebombs.
The only opinions I've heard on the Pirelli's is how lousy the traction is with them off pavement.
Old 04-23-2006, 09:14 AM   #27 (permalink)
As it has been raining around here lately, I can verify that Pirelli's are lousy off pavement. Then, I don't take them to be an off road tire.
I am looking for a long lasting, safe, reliable, low rolling resistance highway tire.
Could you elaborate on Steeltex's being "Firebombs?"
05F250PS is offline
Old 04-23-2006, 09:31 AM   #28 (permalink)
I have a set of XPS Rib on order in size 235/85/16 for my summer driving.
2005 Ford Excursion 6.0 PSD, Rancho 9000 Shocks Timbrens
2003 Ford Expedition
Sunnybrook 3310 Bunkhouse Hensley Hitch Yamaha YG2800i
Clevelandjim is offline
Old 04-23-2006, 09:47 AM   #29 (permalink)
If you are really serious about towing heavy loads with a SRW truck go to www.ricksontruck.com and get a set of comercial rated 19.5's wheels and tires. I pull a 15,500 lbs 5th wheel almost everyday and after having this combo no way would I ever go back to the "litle" tires and wheels. They have much higher ratings and last twice as long. I currently have over 30,000 towing miles on mine and they still have 90% tread. Yeh they'er expensive up front, but they last longer so you're not buying tires all the time and your alot safer because you've got a tire that will actually do the job. Besides,they look cool(no charge bonus) Barney
usandthreedogs is offline
Old 04-23-2006, 09:52 AM   #30 (permalink)
JimTJr's Avatar
My Photos: (6)
Well, I like the Firestone Destinations,,and they are E rated. However if your towing very heavy alot of miles I would defintately consider www.ricksontruck.com
Look at their wheels and tires. 19.5" tires commercial grade. I have heard they last 100k plus miles on light trucks like ours.... you would get your money back in a couple sets of tires like your using now....
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now a full time Technician in the MOANG 12/10/07 My pics! and my New'03 Dually pics!, Charcoal Grey, Black and Grey interior, Black leather seats, Van Turbo/ATS ported housing/WW, Quad "A" pillar pod with Carbon Fiber series AUTO METER Gauges, FUMOTO Valve. BTS BUBBA" /TS 4pos chip, 4" Turbo back straight pipe/stainless 5" tip 131st F/W St.Louis MoAirNatlGuard We're losing the F-15s. BUT BEING HANDED THE KEYS TO THE B-2 BOMBERS at WHITMAN AFB, Near Kansas City, MO.!! We are Lindburghs OWN! Suffering from *PMS,, "Powerstroke mod syndrome"
JimTJr is offline
