My truck has a gooseneck ball setup and we're looking to buy a used older 5th wheel camper and I was looking at the gooseneck to 5th wheel adapters.
Anyone have any brand recommendations on these?
I know I've seen some talk about some new manufacturers voiding warrenties and what not with the things due to all kinds of neat mathematical equations from the extra length supposedly putting more load on the trailer frame, but I really find this hard to believe since a 5th wheel when turning tight while going at a different angle than the trailer would put a heck of a stress on the trailer ( and truck )frame, but the gooseneck is free to pivot in all directions.
Thanks----Robert
'92 F-350 7.3 5 spd, Crew Cab dually,ATS turbo, 4" Exhaust, Air seat, Western Hauler bed. My Gallery
When you, in effect, extend the kingpin by about 16", that adds a heck of a lot of twisting torque to the frame of the trailer around the kingpin area. When you slam on the brakes or jerk the trailer on startup, there's a whole bunch more torque messing with the trailer frame than the frame was engineered to withstand. So if you add one of those extensions, then you also need to beef up the junk iron under the trailer overhang to be sure it will be strong enough to handle that increased torque.
Almost all the trailer manufacturers will void the trailer warranty if you add that converter, because they don't have any control over how good a job you do (or have done) on beefing up the frame around the kingpin. Any good welding shop can do the deed. If your 5er is a fancy one with all the frame covered up under the overhang, then you'll need to remove all that cover so you can weld the additional junkiron directly to the frame of the trailer. My local welding job does that conversion frequently, but it's a lot more involved than simply bolting on that gooseneck extension.
As to which one to buy, the Colibert Fifth Wheel Gooseneck Extension is the most popular, but others are available. Click here for one source for a Colibert.
Thanks----Robert
[/ QUOTE ]Check out PopUp Industries website and the RV1 adapter.
2004 F350 Lariat 4WD SRW CC 6.0 PSD Dark Toreador Red/Arizona Beige, Leather Every option but Moon Roof & Kitchen Sink, Fumoto valve, Wildcat 31QBHS 5th wheel
I know a few people that use these adapters. Nobody has has trouble with their trailers over the time they have used the adapter. Everyone I know use the cody coupler though. I don't know if there are other brands available or not.
Check your PM by the way, I just sent you one.
'03 F150 Supercrew FX4. Little 1/2ton that gets 15 MPG on 23 gallons.
Known a few people who have had the Anderson model shown on the link provided a few posts prior to mine. They loved thiers. I also have heard of a fiver plate that hooks up to the ball in the truck bed. Perhaps this places less stress on trailer. The areas that I like to drag a trailer always bothered me with traditional fiver setup, and I was hoping that down the road, a conversion would get me more articulation between the truck and trailer, now I find there is more to it than that. [img]/ubbthreads/images/graemlins/frown.gif[/img]
2002 PSD 350 CC 4x4; AIS Intake w/ Fender Sleeve; Walker BTM; ISSPRO Tranny, Boost, Pyro; CCV Mod; Zoodad; Blue CPS(in the glovebox); Powerslot Rotors w/ Hawk Pads; Baldwin Fuel Filter; LineX Bedliner; Southwest Fabricators Rear Bumper; 285 Michelline LTX M/S's; and a cracked windshield.
I have seen many and used a few of the different ones. The ranch hitch is by far my favorite. It is plenty stout, yet still easy to install. Here is a link for some information on them.
This one does look nice, but the cody coupler can be installed and removed with only two 3/4" box end wrenchs. No need for pulley puller or hammer wrench or that cheater pipe.
Or you could just get a B&W turnover ball hitch with the 5th wheel companion adapter. Obviously more money than you would want to spend, however it would at least be done the right way.
2004 F250 XLT Sport FX4 Crew Cab SWB, TorqShift, ESOF, 6.0, True Blue, Black Leather Captains Chairs, Moonroof. Built 04-05-04
Mods: ISSPRO gauges in under cubby pod. MBRP Dual exhaust turbo back (straight piped). AFE Stage 2 Intake w/ Dry S filter. Fumoto Valve. Harpooned tank(pics in my gallery). 33X12.50X20 Toyo M/T. 20" XD Monster's (Black). ARP Head Studs Installed on 12-11-07 w/ OEM Heads
That setup would be nice, but two problems. I don't have a standard bed, i've got a western hauler bed and most of thost type of goodies won't fit without surgery, and #2 I don't move around very well anymore and even with a cherry picker on hand, I don't need to be trying to fool with mounting and dismounting all that heavy stuff whenever I need to switch.
First of all, Smokey's right. You'll never find a RV manufacturer that recommends converting a 5ver to G/N.
Will it work. Yep. I'm on my second 5ver and I've never had a 5th wheel hitch mounted in my truck. These are not little trailers, either. The first one was a 32' and this one is a 33'. No problems on either one. I built my own G/N, but a great brand name that's been around for years is Colibert.
