Old 08-11-2007, 12:58 AM   #1 (permalink)
Gooseneck towing
I'm looking at gooseneck trailers to haul my trucks around. The GCVWR is 20,000lbs of both the F350 & F250. Either truck with me in it is 8,000lbs. As long as I find a trailer that weighs a maximum of 4,000lbs with a gross capacity of 12,000lbs. I'd still be legal to haul as long as everything is under 20,000.
BTW, I've been looking at trailers which can handle 10,000 load & gross with trailer would be 14,000lbs. so the trailer wouldn't be at the max with the situation I'm looking to do either.
The other option would be a flatbed trailer bumper pull setup with a Hensley Arrow hitch on the trailer & a heavier Class V hitch on the towing vehicle.
When traveling out of state, do I need any special permits, DOT weigh station stops, anything being this is for personal use & not a business of any kind.
Thanks Dennis
My Photos----- BTS BUBBA "Life Member"
2002 7.3L Excursion 4x4, FTVB, MBRP 4" SS Exhaust, Rancho 9000X shocks, "V" code Front Springs & "B" Code Rear Springs, Ride Rite AirBags, Rear Hellwig Swaybar, Cut Front BumpStops, DieselSite Ext Trans Filter Kit - Coolant Filter Kit & 203 stat, "Scotpart" mod, "Hutched & Pooned", "LandYot" Radius Rods US Gear Overdrive 75mph @ 1750rpm's
2001 7.3L F350 CC LB 4x4 5" Exhaust, pillar guages, BTS Trans, US Gear Underdrive, DP 6 pos chip, V10 Trans Cooler, DieselSite - Coolant Filter Kit, Evans Coolant, 203 stat, DI reg Fuel Return, GT38R BB Turbo, AFE 2 Intake, Banks Intercooler, Air Rite Bags,
2000 Excursion Limited V10 4x4 7" Lift
"Family of 5 saved by Grace"
Snowman269 is offline
Old 08-11-2007, 01:29 AM   #2 (permalink)
Re: Gooseneck towing
I run a gooseneck with a 14k gvw and pull it with my F350 all over the country and have had no problems whatsoever. YOU don't need any permits or anything just register it for the weight you want and go. Bypass the weigh stations unless they specify that you come in. I think there are a few states now that are weighing everything pulling a trailer. But for the most part just go as usual.
The goose definitely pulls better than a bumper I would not even think of getting a big bumper pull like that. Plus if you are trying to stay within Ford's weights then I believe they say a bumper pull trailer can't weigh over 10K total. Definitely go with the goose.
1997 F350 supercab dually auto powerstroke 109K, no mods yet
1993 Dodge 250 quadcab cummins 5spd 3.54LS
1986 F250 ex-cab 6.9, 4spd conversion with US Gear Overdrive, xlt lariat, All power 133K, turbo, homebuilt propane (awesome power from propane
1960 F100 223 inline six 4 on the floor, all original
NateHolmes is offline
Old 08-11-2007, 01:50 AM   #3 (permalink)
DOT doesn't go off of Ford's guidelines. They look at the GVWR (truck + trailer) to determine what they are going to do.
2006 Job 2 F-350 Crew cab King Ranch single wheel 4x4 92k
2007 Dodge 3500 6.7 4x4 14k
Former diesels: 91 D250, 93 D350, 95 F350 PSD, 96 Dodge 3500, 2000 F350, 05 D-max: Fire, 2004.5 Dodge 3500, 2005 Dodge 3500
TXGooseneck is offline
Old 08-11-2007, 09:00 AM   #4 (permalink)
My Photos: (27)
Can't say for back east, but in the far western states the weigh stations and ports of entry couldn't care less about anything behind a pickup truck except livestock of any kind and that's due to brand and/or health inspection papers only.
Mine and DieselGuyNate's are a common weight rating, two 7K pound axles which sounds like what you want. Mines a PJ brand (in my photos) and came with dual landing gear, hand hold and step, lot's of extras at a real reasonable price compared to some other brands.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 08-11-2007, 04:49 PM   #5 (permalink)
I have the PJ as well with the dual jacks, toolbox, triple ramps, very very nicely built trailer. Very reasonably priced too. I've pulled it back east and haven't had any trouble.
I have noticed some states in the midwest are starting to require smaller trucks to pull in and weigh. I believe Illiois is requiring anything over 8tons to weigh. I think it's Illinois but not sure. I have never pulled in though and haven't had any problems with it.
Old 08-13-2007, 04:22 AM   #6 (permalink)
Would that be commercial vehicles over 8 tons or any vehicles over 8 tons?
-----Robert
'92 F-350 7.3 5 spd, Crew Cab dually,ATS turbo, 4" Exhaust, Air seat, Western Hauler bed. My Gallery
RLDSL is offline
Old 08-13-2007, 06:47 PM   #7 (permalink)
I don't remember it saying commercial or just vehicles over 8 tons.
Old 08-13-2007, 10:39 PM   #8 (permalink)
My Photos: (33)
Now is it 8 tons GVW (gross vehicle) or GCVW (gross combined vehicle) weights?
here in CA most all scale houses say that All vehicles over 10 tons must exit and use scale. most also say ALL rental / delivery trucks must exit.
but also says NO PICKUPS!
and now people are saying that new towboss F-350's must scale and display MCP CA#'s?
so who the heck knows
1994 7.3 I.D.I. Navistar 444 CI
ATS Factory TURBO E4OD Red On white Crew Cab DRW 4:10 w/ AUBURN LIMITED SLIP
3" ATS Exhaust and turbo housing, Banks Trans Command, calibrated pump, K&N filter, Gruss style coolant filter, 203K+MI not a lick of trouble with the motor. now on 16th trans. 10 under factory 100K mile warranty
Alpine CVA-7878 XM radio 6cd changer 3 8" phoenix gold subs 75x4 Sony mobile ES gold 4ch amp, Sony 500W 1ch amp MB quart components in Q forms kick panels. 1 farad cap.
Pro car parts jewel cut headlamps and turn signals
APC clear cab markers, suvlights.com harness silverstar bulbs and L.E.D.'s in the fenders. IT's paid for and its MINE!
Family Toys and tools,
00'F350 psd CC Drw 2wd Bright Amber Western Hauler
SOLD 01' Peterbilt 330 4Dr. Texas trucks conversion cAt 350hp
02' Psd Excursion Limited ultimate Estate Green helliwig swaybar 101K miles
1996 fetherlite 4 horse GN, 2003 sooner 6 horse GN with midtack
Dualie is offline
Old 08-14-2007, 02:37 PM   #9 (permalink)
I believe it said all vehicles weighing over 8 tons must scale, Didn't make any referance to CGVW or pickups.
Old 08-14-2007, 03:11 PM   #10 (permalink)
It is generally commercial. They couldn't handle the farmers, RV'ers, and so on.
Each state is different. NM and AZ are the worst because they simply want their money. So you pay through the nose to drive through their states or run the risk of getting a stern talking to by their respective DOT officers, Not fun.
If you think the PJ is nice, you should see one of my trailers
Old 08-14-2007, 04:50 PM   #11 (permalink)
My Photos: (33)
The only trouble I have had with AZ has been with there Department of Agriculture inspectors at the port of entry. Health cert's were expired by 1 Hour [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] I had to roll over the scale platform with an 2000 F-350 6 horse sooner that was 27,975 combined they didn't say a word about weight ever. Must have over 150 trips through there different ports of entry on 10 and 40.
Dualie is offline
Old 08-14-2007, 10:37 PM   #12 (permalink)
I believe Nebraska requires everything pulling a trailer to weigh in. A friend of mine went through there last year and had to pull in with his F350. He said they didn't look twice at him and they told him they were trying to get the farmers who thought their pickups could handle anything. I think for the most part though, you can safely overload with a pickup and not worry about getting hassled by DOT.
What kind of trailer do you have? I really do like my PJ and I spent a lot of time looking at different brands.
