Old 12-30-2005, 07:36 PM   #1 (permalink)
GVWR 250/350
I recently read on the forum that the 2000 SRW F250 & F350 have the same rear suspension/springs it this is true why is the 250 rated at 8800# and the 350 at 9900#. Did I miss something? Is there a way to increase the suspension of the F250 to support 2000# 5th wheel pin weight??? Thanks Monte
2000 250 PSD,CC,LB, Fuel pump mod,Gauges,AIS,BTM, 203 T-stat,DP-Tuner 40hp tow reflash, Air lift air bags.
2005 31RL Colorado 5th wheel
montegill is offline
Old 12-31-2005, 11:08 AM   #2 (permalink)
Re: GVWR 250/350
No the springs are not exactly alike. but if you want to add some carry capacity to the rear add some Ride Right firestone air bags.
you will be able to handle a 2000 pin wieght easy then.
best to check your tire load carry capacity though. make sure they can handle the extra wieght.
Striker
1999 1/2 F350 SUPER cab 8 foot bed with rubber mat. heated dual swing mirror mod. AIS air filter. Rancho 9000x (4)-in cab controller, Firestone air bags all-around. Hellwig rear sway bar. Boost/pyro/tranny temp gauges. Soon 6.0l tranny cooler. Happi-jacs for camper.
Striker101 is offline
Old 12-31-2005, 01:11 PM   #3 (permalink)
Send a message via AIM to ritschner
Re: GVWR 250/350
The easy way to tell is look at the rear axle rating on the door. If it is under 6000lbs then the limit is the springs. If it is 6000lbs or greater then the spring packs are the same as the F350. I have seen rear axle ratings as low as 4750lbs. This was determined by the rear springs. Air bags can be added to increase the load capacity since the axle itself will handle 7200lbs. One advantage with that type of setup would be a better ride when empty. The only question would be the legality of exceeding the GVWR of the truck. The GVWR is there for registration depending on the state of residence. A lot of states base registration fees, safety inspections, and emissions testing on the GVWR of the vehicle.
White 06 F350 Lariet CC 2WD DRW Tow Boss, Timbren SES, Smiths Ultimate Bedliner, RK Tool Box, Reese 20K Hitch, CondensorGuard, IntakeMod, SEIC, Banks 4"TB w/cat, Accufab, Edge Platinum/w Evo Trans Tune, Harpoon Mod, Coolant Filter, CAC Tube Restrainer, Glove Box Light, Hood Insulator, Rewired Mirror Heat, Seat Heater Indicator.
ritschner is offline
Old 12-31-2005, 02:40 PM   #4 (permalink)
My Photos: (20)
Re: GVWR 250/350
In Ford F250 specs the F250 has the same 6,830lb rated rear springs as the SRW F350.
jogiba is offline
Old 12-31-2005, 10:57 PM   #5 (permalink)
Re: GVWR 250/350
Odd since some have a helper spring and added hangers to bounce on.
the F250 didnt have them. I tried to buy those extra items for my F250
and was told to try a junkyard. The extra payload spring came on my
F350 stock. Perhaps the pack itself is the same, but the overload spring isnt.
Striker
Old 01-01-2006, 12:56 AM   #6 (permalink)
Re: GVWR 250/350
My F350 didn't come with the helper springs but I was able to buy the kit from Ford, and the instructions indicated that it would have also fit the F250. So someone gave you incorrect info.
'06 F350 Lariat SRW X-cab,4X4,Torqshift 5-speed Auto,w/23000lb GCVWR and many other options, Vandal Alert Cyclops,Extang Tuff TonnoIII, Duraflap mud flaps and Roadwing mud flap system,towing a Hitchhiker 33' Discover America and a Lund boat. Stock-for now
Traded-99(built6/98), F350 X-cab, SRW, Auto, 4x4, XLE8 code, A-pillar w/ Trans Temp,Boost & EGT guages, WD chip, Pinnacle 4" exhaust, AIS intake,Tricummulator & Sonnax, Lund running boards, D-Celerator exhaust brake, Amsoil in gear boxes,Towed 32'Snowbird 5th wheel & Lund boat
bobsherrie is offline
Old 01-01-2006, 03:57 PM   #7 (permalink)
Re: GVWR 250/350
The F250 will handle that pin weight stock without any issues. My toyhauler 5er is running about 2500lbs pin weight and the truck handles it just fine. The truck sits nice and level when ready to go and it rides well.
2004 Expedition
2003 F250 C/C V10, Banks Power Pack, Transcommand, 4.30LS, MagHytec Diff Cover, B&M Deep Trans Pan, 16K Super Glide Hitch
2006 Thor Vortex 36' 5er Toy Hauler
FastDEW is offline
