GVWR with a camper - Diesel Forum - TheDieselStop.com
Old 11-13-2009, 01:19 PM   #1 (permalink)
GVWR with a camper
I was of the impression that GVWR of (say for conversation) an 2001 F250 diesel is 8800#.
Does this rating apply for a camper as well as pin weight if a 5th wheel is towed? I didnt think the rating changed just because of what you tow or haul.
What is the actual wording from a vehicle mfg regarding GVWR?
Bruce & Carolyn Wittmeier
2001 Ford F250 PSD, Ext cab, Shortbed, Island Blue/Silver, 4X4 Off-road, SOF Auto, Alum Wheels, DP-Tuner 40/80/120HP, Chrome Step, Line-X bedliner, Jordan Ultima 2020, AirLift 5000 Airbags, DiPricol gauges
wittmeba is offline
Old 11-13-2009, 01:57 PM   #2 (permalink)
fordsforever73's Avatar
My Photos: (21)
Feedback Score: 2 reviews
The GVWR apllies to whatever weight you have on the truck itself. So, whether it's a camper or trailer you are hauling, you can only have as much weight on the truck as what the truck is rated for. If you know how much the truck weighs, you then add weight of gear, fuel and persons in it, then you subtract that from the GVWR, that will give you the amount remaining that you can legally add to the truck. Also, that weight could be the weight of a camper, pin weight on a 5-er or hitch weight on a tag-along trailer. Hope this helps.
05 F-350 Crewcab 4x4, 6.0, Auto, Dually, My new Tow Rig
95 F-350 Crewcab 4x4, 7.3, Auto, Awesome Tow Rig...Sold on May 17/09 (went to a good home)
80 F-250 4X4, 429, 4 Speed, Lifted, Solid Axles, Boggers, 450,000km and going strong...Gonna Go
90 Bronco, Work in Progress
fordsforever73 is offline
Old 11-13-2009, 05:48 PM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (44)
The GVWR is the max weight you can have on the truck tires. So for an F-250 with 8,800 pounds GVWR, the GVW is the weight on the two truck axles when you are wet and loaded and sitting on the CAT scale. Add the front and rear axle weights to get GVW. If your GVW is more than 8,800 pounds, you're overloaded.
It doesn't matter whether the weight on the truck tires is from a tag trailer hitch weight, or a fifth-wheel hitch weight, a slide-in camper weight, or a load of something heavy in the bed. If the CAT scale says you have more than your GVWR on the two truck axles, you're overloaded.
SmokeyWren is offline
Old 11-14-2009, 12:51 PM   #4 (permalink)
Thanks, guys. You have confirmed what I thought.
wittmeba is offline
