Bought a new, enclosed Haulmark trailer that continuously leaks from doors and roof. Has been fixed at dealer but is only 6 months since purchase and the problems continue. Haulmark is no help with the so-sad too-bad attitude. Anybody know a good dealer in Fl. to fix my problems once and for all?
Also, anyone else have a problem with Haulmark? In the market for another trailer and really don't want a repeat mistake. Is this dumb luck or are all enclosed Haulmarks junk?
Opinions please...
2008 SD 250 PSD King Ranch 4X4, SWB, CC, Auto 3.73
Viper 791 XV alarm with remote start. FS2500 bypass filter. Edge Insight multi gauge. Line-X. Retrax.
The original dealer should fix the thing right if it is only 6 months old. I had a Haulmark for a few years and wasn't toppled over by its quality, but it never did anything too bad. You might be in the case, if you want something done right you've got to do it yourself. Most likely to fix the roof, it should be removed and resealed. With the doors, either the weather stripping is not working or the door is warped so the weather stripping can't work. Both should be pretty easy fixes.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 235k miles and thousands of $$$$ in maintenance and repairs.
I agree take it back to dealer and demand they fix it. If a NEW car/trailer/etc is not right and they don't fix it raise cane.
Heck tell them to give you another trailer that is right or your money back. Start off reasonable (which it sounds like) and work up to making noise) POLITELY. Keep in mind the dealer is (likely) NOT the enemy. So don't take it out on them.
Thanks for the input guys. I have had it back to the dealer for fixes but might either have to fix it myself or ask for a replacement as you have suggested. Contacted Haulmark directly and while sympathetic, would do nothing. Have not asked the dealer for anything more than a fix, but it might be time to ask for a bit more. Not bowled over by their repair skills to say the least.
I've had my 40ft'r for 10 yrs. Nary a problem, but did start to leak in the front corner couple years back. Way outta warranty, so did it myself. It's sat outside since day one.
These are NOT built by "highly skilled craftsmen", so the quality changes with the day. It's sad that they won't stand behind their product, but seems it's getting to the be the norm.
Which model doyou have? One pc roof?
__________________ THE ORIGINAL "FREIGHTRAIN" 1959 B61 Mack...15 gears of twin stick, black smoke huffin' fun 1967 F100 LB....352 ci/4 spd, nice daily runner 1969 F100 SB.....428 cubic inches of dual quad, 4 speed terror. 1964 Galaxie......390 cubic inches of blown big block...with a 4 speed 1964 Galaxie Country Sedan Wagon.....428 ci and 5 speeds of wheelstanding race car 40ft Haulmark trailer..for the car, quad, AND kitchen sink FOKISD MEMBER ATHS MEMBER....old trucks RULE!
Sorry, but no way I'm going to buy another one of their trailers when they won't even fix the leak on this one. I don't have a suggested brand for you but it sure wouldn't be one they built.
Just my .02,
Joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
Check on a Pace trailer. I have a 24' car hauler and a few buddies also had car haulers. You are going smaller but we have all had very good service. I believe the warranty was also for 1 year.
Tom
02 CC XLT Dually 4x2, PSD w/6 spd, White w/Med Flint 40/20/40, TTT Mirrors, 4.10 L/S, PCM=AEB4, Receiver, Cab Steps, Homelink X Visor, Husky F&R Mud Flaps, AIS Ford Filter, WD Pyro & Boost in A-pillar, Line-X, Hutch Tank Mod, Pre-Pump Racor 645R30, 4" Banks Monster Exhaust, Mag-Hytec Diff Cover, Amsoil in Tranny & Diff.
Bye-bye 99 diesel-sucking automatic!!!
First enclosed trailer so undershot the size I needed.
[img]/ubbthreads/images/graemlins/grin.gif[/img] Ya, I did that and I got a 40 ft'r [img]/ubbthreads/images/graemlins/blush.gif[/img]
Didn't have anymore room for something longer back then, now I wish I did as I have much more property. Oh well.
Good luck with whatever you choose. Like anything else, you'll get a bum wrap on any brand sooner or later.
I have a 6X12 with a one piece aluminum roof and don't have any problems with leaks. As a matter of fact, the only problem I did have was the plastic cap cracked up front. I went to the dealer five or six years after I had the trailer and it was fixed at no charge. Haulmark knew there was a problem and everyone stood behind it. I will admit the quality isn't as great as some other trailers I have looked at, but it works and tows great. I think my next trailer will be all aluminum. Take a look at a Legend trailer. www.legendmfginc.com
Pete
y2k f-250, sc, 6 sp, 4x4, banks stinger and brake, bores rookie sticks, pace edwards roll top bed cover
Thanks for all the responeses. I am currently looking at Pace, and Legend. ONE thing for sure, it won't be a Haulmark. Like I said, maybe bad luck but this thing is falling apart! Sheesh.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Sequoia</div><div class="ubbcode-body">Thanks for all the responeses. I am currently looking at Pace, and Legend. ONE thing for sure, it won't be a Haulmark. Like I said, maybe bad luck but this thing is falling apart! Sheesh. </div></div>
Don't forget Classic, one of the better brands on the market as far as I'm concerned.
__________________ TurboDave, EWCS(SW)USN Ret H&N Turbo 6 Racing
Seviervile TN A MAN AND HIS TRUCK, IT'S A BEATUFUL THING 01 Excursion LTD (EBM3) 7.3L, PSD, Turbo, 4X2, TTS Race Magnum (original owner) 86 GN (original owner) 87 GN (second owner) 08 Honda Accord EX-L
Featherlites are top notch too...have owned Wells Cargo, Haulmark and now Featherlite. Haulmark was the lowest quality of the three, with Wells Cargo in the middle. Of course the Featherlites are top dollar.
