Help me decide - '00 F-250 or '06 F-350 - Diesel Forum - TheDieselStop.com
Old 05-04-2009, 01:59 PM   #1 (permalink)
I have a choice between 2 trucks and I’m looking for your opinions on which truck will better suit my needs.
The truck will be used for pulling a camper (me, wife & 3 children). I would like to be able to pull a trailer with a skid steer, boat, car/pickup hauler, dump trailer hauling and any other type of hauling needs. I don’t have a camper or the trailers mentioned here and I’m starting with the truck.
Truck choices:
1. 2000 F-250 7.3L diesel, 324,000KM (202,000 miles), 4x4, super cab, long box, single rear wheel
2. 2006 F-350 6.0L diesel, 225,000KM (140,000 miles), 4x4, crew cab, short box, single rear wheel
Which one should I pick and why? Which one is a more capable hauling rig?
SnoSheriff is offline
Old 05-04-2009, 02:53 PM   #2 (permalink)
'IF' you put aside the 7.3 vs 6.0 maintenance issues, the 2006 is the obvious choice.
02 SWB CC 4x4 auto, AIS, DPTunerF5, FTVB, 4" Banks Monster SS Exhaust, HPOXover, AirDog, Amsoil ByPass, Centramatics
blackout is offline
Old 05-04-2009, 03:08 PM   #3 (permalink)
Please expand on the maintenance issues.
Not so obvious for a newbie like me . Why?
Old 05-04-2009, 04:09 PM   #4 (permalink)
search 6.0 problems, head gaskets, studs, spend a few days researching.
I defer to someone who has owned one.
I'm happy with my 7.3.
blackout is offline
Old 05-04-2009, 05:41 PM   #5 (permalink)
MarkEkberg's Avatar
My Photos: (13)
By 2006 they worked out most of the problems. With the kids you will like the crew better.
If money were not an issue that would be the seller to me.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
Old 05-04-2009, 06:33 PM   #6 (permalink)
bogg's Avatar
My Photos: (5)
I pick #2. Have had both, and #2 is the hands down winner for everything I could think of to type. Good luck
07(built 06/06) 6.0 Lariat/Moonroof/Camper Pkg/ FX4/DRW/5spd TS/13K GVWR/4.10LS/CC/LB/F350: Accufab Elbow/Mag-Hytec/AutoMeter Tripod(EGT/Trans/Diff)/PIE-Sirius-IPOD/Infinity Speakers/Zoodad/Fumoto/IH-HFCM/Precision Grill/Special Edition UT Weatherguard Crossbox/Coolant flush@25k/Coolant in-line Filter/MBRP 4" Duals/Coil-Rite 4160 Frontend My Truck Pics:
http://good-times.webshots.com/album...ost=good-times
bogg is offline
Old 05-04-2009, 07:17 PM   #7 (permalink)
RatherBNtheWoods's Avatar
A 7.3 with 200K is still a young engine. A 6oh with 140K ain't so young. If it hasn't had major work done yet, it soon will. No warranty on either? I say go with the 7.3 and save the headaches!
Our Raptor RV
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear, Built May05. 4" turbo back, 55 gal aux fuel tank. A real pig from a stop, give me 15' and she'll slowly come to life, then watch out!
165K miles, 12 injectors, EGR cooler, Fuel pump, 8 glow plugs, GPCM, FICM rebuilt FoMoCo engine at 150K under 7/200 warranty.
RatherBNtheWoods is offline
Old 05-04-2009, 10:51 PM   #8 (permalink)
My Photos: (60)
I bought an old (95) F250 in 2000 (still have it) and several times have wished I had the F350 SRW for the increase in GVWR (in 1995 the F350 SRW was 9900, the F250 was 8800). I bought an extended cab F250 in 2000 and almost daily have wished I had a full crew cab. My son cannot fit in the back seat even with nobody and nothing else in the truck. He was 12 years old when when we bought it, is now 6'4" and the back seat is not even an option.\
I would have no use for a short bed (I haul way too much stuff way too often) but the other advantages of the 2006 far outweigh that one issue and that is also for my needs, not yours.
My choice would be the F350.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
Old 05-05-2009, 12:37 AM   #9 (permalink)
Since you mentioned being able to haul as your priority, I would say the 06 for the increased GVWR.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 2.5" axle drop bracket, F350 springs up front, and F350 rear axle blocks. 260k miles. RETIRED.
NEW (to me) 2005 F350 FX4 Crewcab shortbed, SRW, Lariat, auto, V10. 5600 lbs front end.
NickKent is offline
Old 05-06-2009, 08:09 AM   #10 (permalink)
Here's another option, go find a F350 7.3 CC and buy that. Why are you limited to these two choices?
blackout is offline
Old 05-06-2009, 09:19 AM   #11 (permalink)
I agree with Blackout. Find a crew cab LONGbox 7.3 F350 and go that route. I have the extended cab shortbox and would kill to find a clean 7.3 like I described.
2002 F250 7.3 PSD XLT 4x4 EXT Cab Shortbox - EVO2, AIS w/Zoodad, MBRP 4" 409SS, 08 rear diff cover, 6.0 Trans cooler, Heated tow mirrors w/signals
1988 Mustang GT 9.71 @ 143 (1.43 60ft)
2008 H+H 24' CL series V Nose Car Hauler
Blk88GT is offline
Old 05-06-2009, 11:35 AM   #12 (permalink)
My Photos: (28)
There is a reason that the 6.0 is an *orphan* engine no longer produced by Ford. Its run only lasted 3 1/2 years. I personally would not even consider one. Jury is still out on the 6.4 liter. OTOH, the 7.3 ran from 1994 to mid 2003 and has a proven track record...
'97 F250 XLT, PSD, Ext Cab, E4OD, 4.10, TYMAR 4 position flip CHIP,
Roger45 is offline
Old 05-06-2009, 11:57 AM   #13 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Actually the 7.3 went longer than that. It was used as a non turbo for a while too.
Old 05-07-2009, 03:44 PM   #14 (permalink)
I purchased these for a flip and I already have them. I'm planning on keeping one of them for now . I will probably keep the 06.
Old 05-07-2009, 07:05 PM   #15 (permalink)
Yeah,
It's because the EPA changed the regs & the 7.3 couldn't meet them, and then the EPA changed them again & the 6.0 couldn't meet THEM. Now the 6.4 is due for retirement due to (you guessed it) new EPS regs for 2011.
OMC
OMCUSNR is offline
