High Capacity Trailer Towing Specs - Diesel Forum - TheDieselStop.com
Old 11-03-2009, 10:23 PM   #1 (permalink)
Question High Capacity Trailer Towing Specs
Ok guys, I've got a tech question for you...
When a 2005-2007 F-550 with an automatic transmission is equipped with the High Capacity Trailer Towing Package, what mechanical changes set the package apart from an F-550 without this option? I know the GCWR jumps from 26,000 lbs. to 33,000 lbs. and the axle ratio is a 4.88:1 limited slip ratio, but what else is there? Springs, shocks, tranny cooler, engine tuning?
I have found a truck that may suit my needs but it lacks this option and I'm curious if I can add the components to equip the truck as if it left the factory that way.
Any help is much appreciated. Thanks in advance.
Patrick
ponyexpress94 is offline
Old 11-04-2009, 09:41 AM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Not much info available. The order guide for a 2005 and 2006 F-550 said only that diesel engine and 4.88 limited-slip axle was required, and that the pkg included an "upgraded" rear axle. The axle is a Dana/Spicer 110, but somehow the one with the high capacity towing pkg is different than the standard Dana S-110 limited slip 4.88 that is optional in the F-550 without the high capacity towing pkg.
The 2006 Ford Truck Source Book says the F-550 has a Dana S-110 rear axle rated 13,600 pounds, and a footnote says that with the high capacity towing pkg the axle is a Dana S-110 "with a unique 4.88 axle ratio gear set". That doesn't mean that the 4.88 ratio is unique, because all 2005 and 2006 F-550s with diesel engine had a 4.88 ratio. Nothing else was optional.
I know zippo about differentials, but apparently the "unique" S-110 limited slip diff 4.88 with the high capacity towing pkg is somehow beefed up compared to the normal S-110 limited slip 4.88.
One guy that can probably explain the subtleties of the difference is member username Robyn. Robyn is his wife's name, but he's a big ugly dude so don't let the username confuse you.
SmokeyWren is offline
Old 11-04-2009, 09:57 PM   #3 (permalink)
Thanks Smokey, that helps me alot.
Old 11-05-2009, 01:14 PM   #4 (permalink)
Not real sure about that year, but my 03 F450 has a Dana 135 rear axle, 4.30 gears, square axle tubes, not normal for the F450, but it being a construction company truck I figure they upgraded to the heaviest package they could get and still be classified as a 450...
Mike Strickland
Web Master
BigCountryOff-Road.com
2003 F-450 4x4, 6.0 PSD, 4.30 Gears, Western Hauler, 19.5 Wheels/Tires; EGR Delete, ARP studs, HPOP, bypass fuel system, cold air intake, EGT gage(more to come), SCT tuner
RajinCajun is offline
