Hitch or 5th wheel trailer/toyhauler - Diesel Forum - TheDieselStop.com
Old 04-26-2006, 03:20 PM   #1 (permalink)
I am looking at getting a toy hauler for the dirtbikes. I have never towed anything really big except for a bobcat not and again and not for any real distance.
Can someone clue me into the way a 5th wheel/gooseneck deal will feel and handel when being pulled vs a regular hitch type trailer?
The ones I am looking at getting are between 20-30 feet long. Again don’t assume I know anything so any info you have would be most gratefully received.
Dave
'02 f350 Crew LB 4x4 Lariat with Intermittent wipers. All paid for and coverd in mud. 4" lift, on 35's BFG muds. DP-Tuner chip.http://community.webshots.com/user/tooofast
tooofast is offline
Old 04-26-2006, 04:26 PM   #2 (permalink)
Re: Hitch or 5th wheel trailer/toyhauler
We've had a 22' toyhauler (hitch) and currently have a 38' toyhauler (5'ver). Pulling the 5'ver is so much more comfortable than the hitch hook-up. I don't feel the sway from the trailer and hardly any rebound feel from it. I recommend a fifth wheel. Just my 2cents!
TeamFeaster is offline
Old 04-26-2006, 05:23 PM   #3 (permalink)
hitch,
we tow a 5'r and there is no place for any dirt bikes in the bed due to hitch, you may someday want to put a buddies quad in your truck bed or extra crap that you could not do with a huge hitch there. also the tuggable should be cheaper, no $1200 hitch, also hitch remval and storage is an issue as they weigh200+ pounds. I use a foldable engine hoist to get it in and out, others use block and tackle, few just grunt it out...
All things in Moderation accept ACCELERATION!!!!
Zip ties... the duct tape of the new milenia!
truckosaurus
2001 F250 Crew, 25,000+ miles, PSD, 4X2, ProComp 6" lift, Short Bed, SCMT, Tymar set up, BTM, ISSPRO Pyro, boost, and Trans Gauges, in tank mods and harpooned, 28" air horn w/ on board air and tank also full set of train horns! 6 gallons of 150 PSI air. Prodigy, Draw tite Signature series 18K 5'r hitch. TTM
2005 wildcat 29RLBS 5'r, parallel EU2000i's
2003 Explorer, EddieBower, V8 4X4
2003 Explorer XLT, V8 4X4
2002 XR50
2001 PW50
taxgod4u is offline
Old 04-26-2006, 06:52 PM   #4 (permalink)
I just bought a 29' toyhauler, and it seems pretty big for a bumper pull trailer. A smaller one would undoubtedly pull better. Next time, I will get a 5th wheel.
Dennis
'99.5 F250 4x4 SC 6 speed 3.73 LS, Magnaflow 4" exhaust, South Bend con-o clutch.
The_Dude is offline
Old 04-26-2006, 08:14 PM   #5 (permalink)
A 5th wheel is better the bigger you go. I don't think they start making them until around 25'long. They are easier to hook up and as far as towing, its like it's not even there. No sway, and for the most part your truck is level as the weight is over the rear axle and transfered throughout the entire truck. A hitch can have the weight distribution bars added which helps but is no where near a 5th wheel. A 5th wheel and truck length is shorter than the hitch because 4 ft or so is over the bed. I tow a 35ft 5er and it is just as long as my buddys 28ft hitch trailer.
jlesniak is offline
Old 04-26-2006, 09:55 PM   #6 (permalink)
KentuckyDiesel's Avatar
My Photos: (63)
5th wheels are nice, but as mentioned, are not fun to remove and take up too much space. I highly reccomend a gooseneck trailer. The ball is easy to deal with, and goosenecks will handle uneven terreign better than 5th wheels. -phillip
My truck pictures
1995 CC DRW XLT, Converted to 4x4 with D60 front, Disk Brake Dana 80 Rear, Powertrax No-spin locker, Alcoa Classics, Large syncro ZF5 tranny with fluid cooler and pump, LUK Cerrametallic clutch, Big bumpers, Gooseneck hitch, Cobra 148, Alpine CD player/SPS speakers, SuperDuty electric fuel pump, Aeromotive fuel pressure regulator, Davco/Detroit Diesel fuel filter assembly with twin 10 micron Cummins OTR style filters, Stanadyne Fuel heater, Superduty VC harnesses, Tymar intake, Isspro EV Pyro and boost gauges, Autometer pod, Ford AIC, Techonsha Hydraulic brake control, TS 6position chip, JD coolant eye, 4" DP with 5" Auto-Jet muffler and exhaust out the back, SWAMPED.
1993 Shoop Gooseneck, Steel/Aluminum, 4 Horse Head-to-Head
2001 Land Rover Discovery SE
KentuckyDiesel is offline
Old 04-26-2006, 10:23 PM   #7 (permalink)
lincster's Avatar
My Photos: (22)
A 5th wheel makes for a nice towing experience. I have had both, a 30' bumper pull toyhauler and I now have a 40' 5th wheel toyhauler. I will take the 5th wheel any day of the week.
As far as gooseneck, if you get a toyhauler, manufactures will void your warranty if you use a gooseneck adapter. You have to use a 5th wheel hitch.
Goosenecks don't allow the pin to pivot in 4 directions like a 5th wheel hitch does, i.e. puts more stress on the pin box.
2006 F350 4X4 Dually, Tow Boss, Crew Cab, Lariat... Inyati Spray In Bedliner, Autometer Z Series Gauges towing a 2006 LE3905 Weekend Warrior
On order: 2012 F350 4X4 Dually, Oxford White, Black Leather, Ultimate Lariat Package
lincster is offline
Old 04-27-2006, 12:37 AM   #8 (permalink)
I have a 37' weekend warrior 5er and absolutely love it.... once you go 5er, you don't go back to bumper pull!
2008, F-250, FX4, Crew Cab, Short Bed, Oxford White w/ black interior, Dual Alternators, Sat. Navigation & Radio, Overhead DVD System, ESOF, Solid Rear Window, 3.73 Limited Slip, Upfitter Switches, Tow Command System w/ Power Scope Mirrors, Power Seats, and the Reverse Aid Sensor - Edge Insight Monitor, 2.5" Donahoe Racing Lift Kit, Fox 2.0" Piggy-Back Shocks, KMC Beadlocks w/ 35" Toyo M/T's, MBRP DPF back exhaust, Recon mirror lights, Fitch Fuel Catalyst, Randy Ellis Design Light Bar, Line-X, MotoBar, Gentex Temp/Direction Mirror
RRose is offline
Old 04-27-2006, 08:43 AM   #9 (permalink)
My Photos: (63)
Manufacturers will void warranties if gooseneck adapters are used, that is correct. I said nothing about adapters though. Furthermore, the real reason for voided warranties is the leverage the gooseneck coupler puts on the pin box. Pivoting has nothing to do with it. A gooseneck coupler pivots much farther than a 5th wheel does, and being a ball and socket joint, they pivot in all directions, that's why I said they are better on uneven ground.
Anyhow, What I was trying to say in my previous post is that it would be best to buy a toyhauler that is gooseneck from the factory.
-Phillip
My truck pictures
Old 04-27-2006, 09:43 AM   #10 (permalink)
I have looked for a gooseneck model. Do you know [img]/ubbthreads/images/graemlins/shrug.gif[/img]of anyone who makes the gooseneck toyhauler besides Featherlight trailers? They are very expensive.
2008 F350, 6.4, XLT, Forest Green, SRW, CC, 4x4, Longbed, 6-speed, Manual 4x4, Camper Package, Plow Option, SIRIUS Sat Radio, Lance 835 Slide-In Camper.
SOLD: Early 99, F250, 7.3, XLT, White, CC, 4x4, Short Bed, 285x75x16 BFG AT, Manual 4x4, Ford AIS air filter, Warn Transformer Grill Guard, BTS Transmission by Brian T. 216,017 miles and still going.
1abnengr2 is offline
Old 04-27-2006, 01:28 PM   #11 (permalink)
I'm looking at the work -n- play by Forest River and their trailers can be ordered with either 5th wheels or goosenecks. I'm going with a gooseneck due to the simplicity of just a ball in bed.
EARLY 03 7.3L F350 Lariat CC SRW SWB FX4 Every Option, AFE S1, 4" Bully Dog,DP-chip HiI/STK/40/60/80/120, 2" DR lift, Bilsteins,"POONed", remote start w/turbo timer, Sony CD, speakers & amp, Polk sub, XM & SIRIUS. Toyo 285's. 135K Miles & Counting FOR SALE!!!
EARLY 99 F-350 XLT Sport CC SRW SWB 4X4, 16X10 MT Classic 2's, 305/70/16 BFG MT's, N-Fab Nerfs, APC Projectors w/Silverstars, Viper Alarm & Starter, SP Diesel Air Intake, 10K Clamp Mod, Straight Piped, AM/FM/XM/CD/TV/DVD 10" Kicker SOLD
ATVer is offline
Old 04-27-2006, 03:31 PM   #12 (permalink)
My Photos: (13)
Huh??
A fiver can move 4 ways but a goose can move an infinate number of ways because it's a ball joint connecting the trailer and truck.
Ag__Teacher is offline
