Which Hitch is better? - Diesel Forum - TheDieselStop.com
Old 05-02-2008, 12:46 PM   #1 (permalink)
wheelbase's Avatar
Hey guys!
Does anyone know which one of the following two companies make a better adjustable drop hitch? Anyone out there have either one of these hitches.
Company #1
Hitch Solutions The Rapid Hitch
The rapid hitch I'm looking at the 5.25 inch drop with the stainless steel balls. There standard platted steel balls will eventually rust. I'm worried about the webbing / groves breaking if someone were to hit me or if I were to back into something if the slide piece wasn't attached. You can purchase a locking mechanism for the slider.
Company #2
Diversi-Tech Hitch Products
The Diversitech hitch only comes with platted steel balls. I would go with the 6 inch drop with these guys. Their locking mechanism is much better and they have anti-rattle balls for when you're not trailering. There isn't a webbing issue like on the rapid hitch. I believe that they are both rated at the same tongue and trailer weights. They also claim that their hitch machining is much more precision then that of the rapid hitch giving it a cleaner look.
Any input is greatly appreciated.
2005 F350 Superduty 6.0L CrewCab LB 4x4 Black Lariat Loaded w/ S&B Cold Air Intake / 2008 Telescoping Mirrors / Recon Smoked Cab Lights & Side Markers / Toyo Open Country A/Ts / Bilstein Shocks / MBRP Cat Back Exhaust (Downpipe & delete pipe is in the garage until warranty ends) / Edge Insight / Cab off repair replaced every gasket in engine after buyback process ended with a nice big check from Ford (Oil Leaks) / Run Rotella T 15W 40 / Stanadyne Performance Formula in every tank
2005 Denali (Dutchmen) Travel Trailer 29RK-DSL
2003 Black Lab (Magnum) 105 LBs and runs on Pro-Plan
wheelbase is offline
Old 05-02-2008, 01:58 PM   #2 (permalink)
NCheek's Avatar
I would be tempted to say that the rapid hitch is better. The pin going through the slider has more surface area to displace load than the pin on the other hitch. A buddy of mine has the 5 1/4" drop rapid hitch and it looks and feels very solid. I have pulled with it and was very pleased, even on the lowest drop, and in the time he has owned it he hasn't had any problems with it.
That's just my opinion, interpret it however you see fit. These hitches are pretty spendy, so choose wisely.
-Nick
My Daily Driver:
1986 F-250 2WD, Regular Cab, LWB, 6.9, T-19, Sterling 10.25", open 3.55's, XLT Lariat, Texas Sesquicentennial Limited Edition, No Restrictor Plate, manually switched high idle/advanced timing, and an awesome custom shift knob thanks to Bruce Roosa / Koolknobs.
279,000 miles and counting, hoping for a US Gear OD and a Hypermax Turbocharger one day.
My first truck:
1982 F-250 4WD, Extended Cab, LWB, 5.8, C6 to T-19 swap, BW 1345, Dana 44 TTB/Dana 60 Semi Floater, open 3.55's. About four different colors (not counting rust), currently on loan to my little brother. Maybe one day it can be home to a 6.9L too.
Work Truck:
1992 F-700 Flatbed w/ dump, 7.0L BIG BLOCK GASSER, 5-speed trans (Clark?), 26,000 lb GVWR. Rides like a tank
NCheek is offline
Old 05-05-2008, 05:28 PM   #3 (permalink)
rcd
Hitch
B&W also offers a "stow & go". I have one and love it. I also use the B&W turnover ball goose neck and the Companion 5th wheel. B&W makes a great product and is worth checking out before you spend the money.
Good luck!
2005 F350 CC Lariat FX4. B&W gooseneck w/Companion 5th wheel hitch. Reflex spray in liner. Husky splash guards, Husky floor liners, WeatherTech floorliners. B&W Stow & go.
rcd is offline
Old 05-06-2008, 02:20 PM   #4 (permalink)
i second the b&w tow and stow. i love mine and it is plenty beefy for any bumper pull application i can think of.
1996 F-350/4X4/Reg. Cab/LWB/7.3L Powerstroke/Auto Trans./Dual tanks/226K/No mods/4.10 gear/slight susp. lift./33X12.50X16.5 BFG-AT 8 on 6.5/Recent brake rebuild/recent tranny rebuild./Camo seat covers(Mossy Oak-Old School)/Camo Wheel cover (Mossy Oak).
marv0723 is offline
Old 05-07-2008, 12:21 PM   #5 (permalink)
wheelbase's Avatar
Thanks for all the responses. I'll go check out this stow and go solution.
Randall.
Old 05-16-2008, 06:25 PM   #6 (permalink)
FWIW, I have the 10" drop Rapid Hitch. I've had it for about 3 years and it's still working good for me. I tow my boat (roughly 5K) and some flatbed trailers with it.
07 CC LB FX4 TS 6.0 Oxford White, 4.5" DR lift, 315/70/17 BFG on 17x8 American Racing Mojave
Nubbs is offline
