You've got a D3, all I've got is the spec sheet weight for a D3B with OROPS, bareback (no ripper), and 6 way blade at 14,650# which included fuel and operator. The differences between a D3 and a D3B were very minor, it was essentially the same tractor. If you're packing a little material in the undercarriage, and perhaps had a slightly wider track shoe than standard (12" IIRC) you will still end up under 15,000#. Sorry this took so long, I started a new job . . .
2006 F350 Lariat, 6.0L Diesel
Super Cab, Long Bed, 20" Factory Rims
Fx4 with Camper Package
AIC, 2WD Low, Chimes OFF, Shaker 500, Upgraded Headlight Harness with XtraVisions
Thanks a bunch! I was wondering what happened to you.
I will be hauling it fourty miles or so this weekend so I'll see how my dually truck handles it. I had a fella already move it for me with his SRW F350 and he says it pulled just fine, lighter than fifteen round bales that he usually hauls on this trailer so we shall see. Pulling heavy for farm use and being out on the freeways are two completely different scenarios. I was hoping it was a bit closer to 12,000 lbs but do intend to get it across the scales before heading out for a long trip for sure.
I do have a question as to what era of D3 you found the weights on ?
From To
Estimated Year
00269 00639 1973
00640 02102 1974
02103 03012 1975
03013 03666 1976
03667 04315 1977
04316 05414 1978
05415 06101 1979
go to ironrecord.com and you can see your unit was a 1975 as shown above. The D3B's would have come on after the D3's were discontinued. Some people will call your unit a D3A but there was no such thing, it was just a D3. You'll be glad you weight as much as you do when you're up against something that pushes back. I've never ever seen Cat introduce a new model such as a D3B that weighs less than it's predecessor, and they almost always will pop up the HP just a bit to set the hook. Watch out for the Cat Performance Handbook "Former Models" weights . . . the edition I looked at said your unit weighed far less than it really does . . . oddly, Cat dozers are often shown in their PHB Former Models sections without the weight of their C-Frame and blade included. Good luck!
i recently hauled a cat D6R XL from houston to college station (about 90 miles) with my 08 F550, on a dual tridem trailer. truck pulled it just fine at 55-60mph, albeit sucking up fuel at the amazing rate of 4-5mpg! the cat and trailer weighed in at 36,400lb so it's quite a bit over what ford says i can tow...
a d3 is a lightweight and your f350 should have no trouble pulling it. just make sure your trailer brakes are up to par.
08 Ford F550 Lariat CC 4x4, pickup bed
I CALL Bravo Sierra (B.S.) A cat D6R XL has a curb weight of 42,000 LBS. theres no way in heck any DPS officer would let that go un noticed.
1994 7.3 I.D.I. Navistar 444 CI
ATS Factory TURBO E4OD Red On white Crew Cab DRW 4:10 w/ AUBURN LIMITED SLIP
3" ATS Exhaust and turbo housing, Banks Trans Command, calibrated pump, K&N filter, Gruss style coolant filter, 203K+MI not a lick of trouble with the motor. now on 16th trans. 10 under factory 100K mile warranty
Alpine CVA-7878 XM radio 6cd changer 3 8" phoenix gold subs 75x4 Sony mobile ES gold 4ch amp, Sony 500W 1ch amp MB quart components in Q forms kick panels. 1 farad cap.
Pro car parts jewel cut headlamps and turn signals
APC clear cab markers, suvlights.com harness silverstar bulbs and L.E.D.'s in the fenders. IT's paid for and its MINE!
Family Toys and tools,
00'F350 psd CC Drw 2wd Bright Amber Western Hauler
SOLD 01' Peterbilt 330 4Dr. Texas trucks conversion cAt 350hp
02' Psd Excursion Limited ultimate Estate Green helliwig swaybar 101K miles
1996 fetherlite 4 horse GN, 2003 sooner 6 horse GN with midtack
15k you should easily be able to pull just load it right put the majority of the weight on the axles i've heard of guys pulling such loads with 3/4ton trucks. But can your hitch and/or trailer take that weight?
__________________ 2000 Ford F-250 (4x2) XLT extended cab long bed, TS Performance 6 pos. Chip (Stock, High Idle, 50, 75, 100, 140 extreme), Turbo Master Wastegate Controller, ATS Housing, AEM Brute Force dry filter, MBRP Stainless Trubo Back exhaust 4in., Gauges (EGT, Air Tank P.S.I, Boost), High Pressure Oil Crossover, 60gal. aux. tank/toolbox combo, bedliner, Uniden CB w/ 15 watt PA, ViaAir air compressor and 1.5 gal tank, train horn, Pioneer head unit w/ jensen speakers, after market stock ford running lights, 33in. Nitto tires
heh. with no blade or ripper it fit nice and neat on the trailer with minimal overhang. and it certainly did not weigh in at over 40klb. regardless, if a DPS officer never sees you, then they never pull you over.
i'll be hauling a New Holland DC150 LGP later this month. perhaps i'll snap a few photos...
Well I picked it up and brought it into my shop in town last weekend. I had to buy a set of stock wheels and tires though as the KD rockstars and 315 Dunlop Mud Terrains combined with the 3:73 gears would have made it real pig for towing. Once I had all that straightened out the truck pulled fine, a bit slow on takeoff but I was able to run 65 mph no problem out on the road but stopped that soon as I figured out the trailer brakes weren't working. I smoked some lance armstrong wannabees real good on a few hills and that my friends was awesome fun. The red lights were a bit unnerving though, kinda sweated thru a few of them but thabkfully it was sunday morning so traffic was light. Yeah I know, this post sounds like I am a teenager, young dumb and full of it but at 40 something years old it felt good to pull some serious steel for once.
As far as a D6 I think I would maybe kick it up to at least an F650 but I am amazed Alexrex. You must have been running farm plates??
