Old 03-09-2005, 11:03 AM   #1 (permalink)
How to keep your B&W from freezing
OK, all you guys that have B&W turnover balls in your trucks. This is my first winter with mine in the 2000 dually. Went out to move the trailer and it had rained and snowed. The ball was turned over and I could not get it out so that I could hook up the trailer. Finally I poured hot water on it and it let go, but when I turned it up guess what happed to my hot water--- yup it froze the ball in the up position, so when I got done with the trailer it is now frozen up.
So how do you guys that have been running these balls keep them from freezing in the winter??? Maybe you dont and I just have to run with it up all winter. Or, maybe I could convince the wife that I need a new heated shop to keep the dually in [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2000 F-350 ext cab XLT 4x4 dually PSD 6 speed, EBPV as an exhaust brake, In tank and pre pump mods, harpooned tank, heater control mod, cup thrower mod, zoodad cold air intake, Crankcase Vent Mod, B&W turnover goosneck ball, Walker Big truck muffler, TS 50/75/100/Fuel 7 power chip, Banks 3 gauge pod on the dash, pyro, boost, engine temp.
1995 F-350 reg cab XL 4x4 SRW PSD 5 speed, stock
1991 F-250 ext cab Larit 4x4 IDI diesel, 5 speed, 33x 16.5 BFG Mud tires, 2 inch trailmaster suspension lift, lost the first engine with a Banks turbo to the big "C" at 155K and have an engine out of a wrecked truck in her now with no turbo, dual straight exhaust, and a turned up pump- let her scream and smoke!!
2000 Ford Expedition 5.4L Triton- wifes hauler
ShepVA is offline
Old 03-09-2005, 11:38 AM   #2 (permalink)
Re: How to keep your B&W from freezing
Shep,
Next time you go to thaw it out, try using windshield washer fluid- shouldn't re-freeze. Best answer is heated garage- I'll never be without again [img]/ubbthreads/images/graemlins/biggrin.gif[/img].
Keith
93 F350 CC Dually 7.3 Hypermax turbo 4:10 gears, ZF rower, K&N filter, home made ram-air, Hypermax 3.5" exhaust, LUK clutch, 150,000 mi.
Weezer is offline
Old 03-09-2005, 11:42 AM   #3 (permalink)
Try coating the outside of the ball with grease. B&W recommends that you coat the four corners of the ball with grease. This should shed away the water and keep it from freezing.
When I bought my truck the ball hadn't been removed in a while and it was rusted in place. I had to get under the truck and beat it out of the hole with a ballpean hammer. I have applied wheel bearing grease to the four corners of the ball and haven't had a problem since.
Firefighter9208
Early 99 (3/98) Extended Cab F 250 XLT 4X2, PSD, 6 Speed, LWB, SRW. 140,000 miles. LUK Clutch, C-BETR Tow Mirrors, Muffler Delete Pipe, Removed Catalytic Converter, Autometer Dual A Pillar Guages with pre-turbo Pyro and Boost, SCMT 1705 Max Tuner, Tymar Intake from Airflo.com. 265/75/16 Firestone Transforce A/T's. Fumoto Drain Valve.
2006 Volkswagen Jetta TDI (wifes car)
2004 Keystone Cougar 314EFS
2004 Kubota M4800 W/Bushog Loader
1969 Mustang Mach 1 351W
1990 Jeep Wrangler
firefighter9208 is offline
Old 03-09-2005, 11:52 AM   #4 (permalink)
I use antisieze on both my b&w`s.
05 f350 lariat arizona beige 6.0 c/c dually 4x4 auto-/04.5 ctd 5.9 Durdge quad cab 6spd 4x4 dually silver
allentaylor is offline
Old 03-09-2005, 02:08 PM   #5 (permalink)
Good ideas, I will try putting some grease on the corners and see what happens. Do you get grease on things in the bed when the ball is flipped over? Also do you put grease on the four corners on both ends of the ball or just the bottom??
I still think this is grounds for a heated building to put the truck in [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]
ShepVA is offline
Old 03-09-2005, 03:18 PM   #6 (permalink)
I really just smear the hole full in the hitch. It will get on the sides of the ball.
Firefighter9208
1990 Jeep Wrangler
Old 03-09-2005, 03:19 PM   #7 (permalink)
I really just smear grease on the sides of the hitch hole in the bed. It will get on the sides of the ball.
Firefighter9208
1990 Jeep Wrangler
Old 03-10-2005, 09:28 AM   #8 (permalink)
Personally I never run with my hitch balls hanging upside down. I always removed the ball put it in a HD Zip Lock bag and store in my toolbox. I grease the ball before hitching up and it still looks like new.
My thought was the chance of introducing grit, grime and corrosion into the hitch of your trailer if stored upside down in the hitch, turned over and go.
I know many people who do this, many who do not grease there balls and they appear rusted and galled!!!
2007 Dodge 2500 Quad Cab 4x4 SLT Cummins 6spd, Silver
SOLD 01-27-07, 2003 F-250 XLT 7.3, VDH5 PSD, Auto, 4x4 ESOFly, SC, SB, 3.73 LS, True Blue/Silver. Towing package, Camper package, adjustable pedals, etc... B&W 1198R gooseneck, Lund Hood Scoops, Ex-Tang ToolBox Tonneau Cover, DP Tuner F5 (NS/ST/40T/60T/80Econo), Autometer Z series tranny gauge, ISSPRO pyrometer pre-turbo, Walker BTM 21470, AIH delete option, Sonnax™ Valve/Tricumulator™ Springs.
http://community.webshots.com/user/oliverpuller-date
2001 Honda Shadow A.C.E.
2005 Honda Rebel
2001 Pontiac Grand Prix, GT
1998 Ford Taurus SE
2001 C&W 24' Gooseneck deckover
Many other toys!!!
[color:"red"] WALMART SUCKS!!! [/color]
Jim Filges is offline
Old 03-10-2005, 01:28 PM   #9 (permalink)
Send a message via ICQ to MudHog
I don't have a problem with freezing, but I do have a prob with crud and mud causing the ball to stick. I put grease on the whole base and hasn't stuck since.
For the freezing part, maybe move father south? [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
'03 F150 Supercrew FX4. Little 1/2ton that gets 15 MPG on 23 gallons.
'06 F250 FX4 CC SWB
MudHog is offline
Old 03-10-2005, 09:54 PM   #10 (permalink)
I keep my ball in a box and have B&W's little cover in the hitch. Never had any trouble with it freezing.
1996 ext. cab, long bed, 4x4, 5spd. PSD, 3.55LS, Ford AIC, drainplugged Dana 50, EBPV brake, tranny cooler and gauge, Tymar intake, Tymar 4" downpipe and 4" exhaust. No kitty.
Nick_Kent is offline
Old 03-10-2005, 10:41 PM   #11 (permalink)
Good to know I am not the only one mine froze up yesterday had to use some windshield de-icer to get it free. Worked good though. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2004 XLT FX4 SRW LONGBOX F350 6.0 STROKE
Clear Lenses,SilverStars, LED I.D. Bar, EXCURSION Grille,XM RADIO,BW Flip-Ball, Straight Piped
74 Bronco 307,C4,33 swampers
firemanbuttsy is offline
