Old 05-05-2006, 09:29 AM   #1 (permalink)
My Photos: (5)
How much grease should I put on the ball hitch
I heard that i should grease the hitch. How much?
2002 F-250, PSD 6-speed, CC, short bed, 4X4, Toreador Red w/ Silver accent, A.R.E mx cap, Weld Super Single II and 33s in the summer, x-springs, F-350 blocks and badges, AIC, proflaps, ITP intank mod, AirDog with 3 micron filter, isspro guages and TTM, husky liners, alarm, xm stereo,stull 5399-p grille, centramatics, ccv mod, AIS Air Filter, Southbend CON O, Detroit Truetrac LSD, coolant filter, 203 stat with billet housing, blackcloud intake heater plug/boost fitting, reese titan hitch, fabcraft PTO cover/temp sender port, prodigy brake controller, ITP Boost Annihalator, oilguard bypass filter, Mag-Hytec rear dif, bilsteins, hellwig rear stabilizer bar, DP Tuner F5 - no start, stock, 40t, 60t, 80e and 80t, ATS housing, non-ebpv pedistal and exhaust flange, magnaflow 3.5dp exhaust, ITP reg return, turbomaster wastegate controller, and ceramic coated bellowed up pipes, currently 80,100 miles. truck Pictures
clydesdale is offline
Old 05-05-2006, 10:11 AM   #2 (permalink)
Re: How much grease should I put on the ball hitch
The ball doesn't need much grease. Be sure to use high pressure waterproof grease and clean ball and hitch socket well before applying.
TerryP
2000 F250 PSD 4X4 ext cab short bed, gauges, AIS, coolant filter, tranny cooler, Transferflow 46 gal tank, Walker BTM, SCT XCAL-2 tunes by Tadd at Elite Diesel.
TerryP is offline
Old 05-05-2006, 11:18 AM   #3 (permalink)
" A little dab 'l do ya! "
reyjay is offline
Old 05-05-2006, 03:50 PM   #4 (permalink)
When was the last time someone here "wore out" a hitch ball or reciever ?
Who here actually knows someone that did ?
97 F250 SC LB 4X4 PSD TDE0, E4OD,3.55's, 285/70/16"s ,Modified fuel tank vents, 375+k headed for 500k
Leader is offline
Old 05-05-2006, 03:54 PM   #5 (permalink)
towing with the same 2" ball for years never had a problem with it and i don't grease mine
2001 F350 SuperCrew Long Bed Dually.
7.3L turbo Diesel, automatic transmission, goose neck hitch, fifth wheel hitch, stainless steel back rack, 315/75-16 BFG A/T's, AUX back up lights, euro-lite driving lights, upgraded fog lights, dp-tuner, auto-meter ultra-lites, 5in stacks no muffler, whelen towmans light bar, DIY tymar intake, DIY coolant filter, 2M ham rig, DIY AIC,
( egauges )
My truck pic's
cdacaraudio is offline
Old 05-05-2006, 04:11 PM   #6 (permalink)
Black05's Avatar
I have never greased a trailer ball, with no adverse effects. This is particularly true if you are using the hitch/trailer in any kind of dusty conditions; never use grease as the grease attracts the dirt and then you have sandpaper working on your ball and coupler.
Black/05/F350/XLT/CC/LWB/FX4/SRW/3.73/6.0L PSD/ TorqShift/Updated TBC/Upfitter Switches/SEIC Mod/Diesel Site Coolant Filter/Fumoto Valve/ITEC HFCM Drain Plug/Bilstein Shocks/BFG A/T 28565R18/Built September of 2004
Texas Proud.
God Bless our Armed Forces.
Black05 is offline
Old 05-05-2006, 07:05 PM   #7 (permalink)
It's fifth wheel type hitches that you need to grease. They carry more weight than a ball hitch.
It isn't a bad idea to shoot a little white grease up inside the trailer coupler, to keep the mechanism lubed up. The ball doesn't need lubed, although a little wouldn't hurt anything.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 05-05-2006, 07:34 PM   #8 (permalink)
I have never greased my 5th wheel hitch. I use a teflon plate and that is it. Grease collects dirt, which will grind away the hitch faster than nothing IMHO. Also grase gets on everything when not hooked up.
jgr
Y2K F350, Ecab, LWB, SRW, 4X2, ZF6, Full Gauges, Ebrake, Chipped 271rwhp/584tq, Coolantfilter, fumoto valve, oil by-pass filter, CCV mod with return to intake, dahl 100, straight piped, PML cover, 203 stat and billet, AIS, Zoodad
pristine is offline
Old 05-05-2006, 09:57 PM   #9 (permalink)
Well yea, "lube" of some kind is needed... which the teflon plate is. Without the lube a fifth wheel can bind in a turn and keep the truck from turning.
When I drove Big Trucks the fifth wheel plate got greased at every oil change, and the terminals had air operated grease hoses if you wanted to do it yourself in between.
Old 05-06-2006, 12:01 AM   #10 (permalink)
Probably depends on how much tongue weight you carry and how much turning you do. Right after we got our trailer and before I greased it I noticed fine metal shavings after a particular trip that had me backing into all kinds of strange spots.
Trinity
Early 99 6spd (Eaton Fuller Knob), 285x75 MTR's, DI 4 POS Chip, Walker BTM, listening to XM Delphi skyfi, pulling 24 ft full of Mechanical Bull, heading to a bar near you!
Truck pics
tsaelens is offline
Old 05-06-2006, 03:00 AM   #11 (permalink)
I've actually seen several balls that have been worn down pretty good. Before I switched trailers, I ran a gooseneck that worked for a living and that one along with several others I saw regularly had worn enough that when you hit a bump you would hear the trailer receiver bounce on the ball.
Mine got lubed regularly, you just had to make sure you cleaned the dirt or anything else out of the grease so the ball wasn't ground down too quickly.
Mike
<font color="red">FIRST PICS OF MY WRECK,</font><font color="brown"> THE DESTRUCTION OF A FORD DUALLY,</font><font color="red">[img]/ubbthreads/images/graemlins/frown.gif[/img] ARE BELOW IN "My Pics"</font>
1996 F350 XLT crewcab dually, pullin a 50+3' step deck
1996 F250 XLT crewcab (wife's), pullin a bed full of milk meters and a 27' 5th wheel
<font color="aquamarine">My Pics</font>
<font color="blue"> I PREFER DANGEROUS FREEDOM TO PEACEFUL SLAVERY</font>-Thomas Jefferson
<font color="blue"> Remainder of signature deleted for political correctness violations</font>
RopinandRidin is offline
Old 05-06-2006, 10:09 AM   #12 (permalink)
My Photos: (27)
Me too, I smear a bit on about every 10 or so times I pull a trailer. Plenty enough stays up inside the ball socket in between to provide a little lube. I've seen some worn down also, some of the sockets are manufactured far from smooth inside.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 05-08-2006, 11:45 PM   #13 (permalink)
ADStryker's Avatar
I wore the chrome off a ball, pulling without lubing it. I tried wax paper on the ball for a while, but wasn't convinced it actually worked, so I lube mine with moly grease now. I wipe the ball clean when the hitch isn't sitting on it, so attracting dust doesn't seem to be a problem.
'90 F350 4x4 CC, 7.3 IDI, Factory Turbo, ZF-5, 3.55 SRW, 237kmi. (Sold)
'02 F350 4x4 CC, PSD, VDH2 PCM, SCT Xcal2 (DPTuner 60t, 80e, 100p), DIY Tymar (50kmi), Walker BTM (55kmi), 3.73 SRW, 6½" Pro-comp lift, Dynatrac Free-Spin Kit (65kmi), Toyo MT 315/75-16 (64kmi), C-BETR Mirrors, rebuilt Motorcraft 4R100 (43kmi), new CPS (46kmi), 70kmi
ADStryker is offline
Old 05-10-2006, 10:17 AM   #14 (permalink)
At the expense of a few laughs, I use vaseline [img]/ubbthreads/images/graemlins/shocked.gif[/img].....The cheap stuff from Walmart. It comes in a good container, doesn't leak like a grease gun or tube with a bad cap and doesn't stink. [img]/ubbthreads/images/graemlins/frown.gif[/img] I keep a container of it in the truck toolbox and apply a two finger dab on a GN hookup. I wipe it off with a paper towel when I unhook and clean out the socket every other time or so. I used to use wheel bearing grease but tried the vaseline when on the road without anything and have used it ever since. (10k or so towing miles) It's not the most high tech approach but it seems to be working fine so far.
I almost bought a good looking GN cattle trailer at an auction until I checked the socket and found a dime sized hole worn into the upper area. I hope to avoid this on my stuff.
Let the jokes begin..... [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
99 F-250, (6/98), Lariat CC, SRW, 4x4, SB, 4r100, 3.73, 3 1/2" x 4" DP, 4" magnaflo, PMT1 Pcm W/ Tipton 80hp econo tune, Isspro EV guages, gutted EPV, in tank fuel mods, Harpooned tank, regulated fuel return, Dahl prefilter, Precision TC, Transgo Tugger shift kit, Transgo T/C lockup valve, T/C lockup switch w/LED, updated solenoid, Magnafines, Hayden 679 trans cooler, filter, CCV mod, Riley coolant filter & 203* thermostat, Cryo'd powerslots and Hawk pads, DI H/X mod, Ford AIS, Rancho 9000s, Velvet rides, LL#8, C-Betr mirrors, Drawtight 10k receiver & removable gooseneck ball, Michelins, Jordan 2020 brake controller
nacep is offline
Old 05-10-2006, 11:12 AM   #15 (permalink)
Hi Leader,
Now you can say you met someone who has worn out both, non-commerical usage.
On my 8k TT with grease I've been thru two balls.
On my 28ft flatbed equipment trailer I've worn out 3 balls and if I was going to put the trailer on the road again, I'd need to change the coupler before doing so. This one has been ran dry alot of it's life.
Without a dab of grease a ball will gaull the first time out at about 15kGVW plus. That wears both the ball and coupler out.
I just accquired a 97 32ft 5'r RV where the previous owner didn't grease the king pin, about 25k road miles. The back side of the pin is gaulled up pretty bad where the pin rides against the lock jaws. I'll need to change it with-in the next couple years. The only reason why I don't have to change this year is my lock jaws are new and still tight.
[img]/ubbthreads/images/graemlins/smokin.gif[/img]
T_Bone
02 F350, 4X6, Crew, DRW, LWB, PSD, 6spd, 3:73, Island Blue, Stock, AEB2, Phoenix Az
Buy UNION work UNION. It pays off in the long run
Define Union:
A labor Union is nothing more than united workers with a common goal for better working conditions.
We all are in some sort of labor Union, some are just larger than others with better working conditions!
T_Bone is offline
