How much lift do you have and still get under 5er?
How much lift do you guys have on your trucks and still fit under your 5er?
The trailer is a 37' Sierra with the axles flipped. (In my pics)
My 2001 has a 4" lift with 35" tires and it fits just fine.
I just bought a 2007 yesterday and I want to put 35's on it, but the guy at Offroad Parts said that with the new front end that I would have to go with a 6" lift??? (Is that true)
If I do the 6" lift will I still be able to get under my trailer?
I would like to hear from the guys that have done it, Thanks!
While your at it, I'd like to know if anyone has recomendations for lift on this new truck.
Re: How much lift do you have and still get under 5er?
I can't answer all of your questions but, I don't think you need 6" of lift to fit 35's. Maybe a 2-1/2" leveling kit. Eric. By the way sweet rig hooked up.
2008 Chev 2500HD CC SB LTZ 4X4 Duramax/Allison, dual alternators, B&W Turnover ball w/ Companion, 8'2" Boss V-plow, Timbrens
SOLD----2002 F350 CC SB, 4x4, Lariat, leveling kit, 285 BFG's, AIS w/ fender sleeve, AIC, A-pillar Pyro, Boost, Trans, SCMT, 4" Magnaflow turbo-back, AIH delete, Weatherguard toolbox, 8'2" Boss V-plow, Hide-a-way strobes, B & W Turnover Ball and Fifth Wheel Companion, Fumoto, 203* Stat, Bilsteins, XM, C-Betrs, 136,000 miles,Hella 500's up front, Hella flush mount back-up lights, Speed Bleeders, Air Lift rear bags w/ inside controller
Pulling this:
2005 Alumascape 35 FLQ by Holiday Rambler w/ 5 slides
2007 F550 4x4 XLT, 11' contractor dump box, dual alternators, Tow Command, Upfitters, C-Betrs, #19000 GVW, Fumoto, 9'2" Boss V-Plow, 8' V-box salt/sander, LED flashers
Thanks for the feedback...i thought the guy at Four Wheel Parts was full of it.
i really like the way my 01 sits with the 4" lift and the 35s compared to my buddies trucks that have a leveling lit amd 35s, I would really like tl know how high I can go and still fit under my fifth wheel. I haven't seen too many new trucks running around lifted so I thought maybe you guys have already done it or seen some around.
thanks!
Yes 35's should fit just fine. If you have any rubbage...just saw off part of the plastic on the bottom part of the bumper...or add a shim. Then you should not have any problems.
Good luck,
Steven
01 F350 CC LB 4x4 SRW,(w/forged rods), 6" Lift, 37"ToyoMT, 22"MKW M19's, Mini Mes, GTP38R, BTS Chip, Spearco, Headstuds, 910 Springs, 4" exhaust, Coolingmist Water Injection, BTS Tranny, 6.0 Trans cooler, 05' Conv. w/ Mirrors, AFE2, Truspeed, Isspro Guages, ORU Diff Covers, Hella 500s, Transfer Tank, ITP Boost fooler, AMP powerstep, Heat Extractor Hood, custom paint, billet badges, Train horns, Recon lights, strobes!
4/8/08 402hp, 824 ft-lbs Mustang Dyno
8/2/08 14.39 in the 1/4 @ 93.5mph on 37's @ 8950 lbs
You can lift your truck as high as you want, you will just have to lift the trailer more to match. I personaly wouldn't go over 4", but I see tons of trucks with 6" lift and 5ths.
'01 F350 Lariat PSD 4X4 CC SWR LB auto
Superchip 60hp, 4" cat back, A-pillar w/auto meter gages, Firestone Air bags, Bilsteins, Radio Speed Volume Mod, XM Roady Photos
I don't see how anyone is doing a lift and towing a 5er. I couldn't lift mine one inch and still get under my 5er without risking my bedrails and I've already flipped the axles!!
__________________ 2003 Toreador Red/Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03, (still running the original flash!), AIC, MBRP turbo-back exhaust, Tuning by Total Diesel Performance, AFE PG7, Fumoto valve, B&W hitch, Di-Pricol gauges, Voyager brake controller, DIESELSITE Coolant filter, Timbrens, Rancho RSXs, Michelin XPS Traction's, a whole bunch of "bling", Connex 4300hp, JL Audio 275w amp w/ 12" sub, Alpine door and rear seat speakers. 376hp
i pull a 35' weekeend warrior 5th wheel, and you can see my truck specs in the auto-sig...
all trailers are set up differently, so you really need to measure the height of your bed rails, and then go from there. the WW fits no problem, but i know of other toyhaulers that i could not have fit under.
would i recommend going up to 6"? probably not again, but next rig is a diesel pusher...
2003 Ford F350 Crew Cab Long Bed 4x4, 6" Edge all spring lift with Adjustable Panrod Bar and Dual Steering Stabilizers, 37" BFG Mud Terrains, 4.56 Richmond Gears, DPPI Turbo Back Dual Exhaust, Autometer C2 Gauges on A Pillar, aFe Proguard 7 Intake, Reese Titan V Hitch, B&W Turnover Hitch, BrakeSmart controller, ORU Air Overload System My truck pictures
