How much weight can we pull? - Diesel Forum - TheDieselStop.com
Old 08-26-2007, 02:31 PM   #1 (permalink)
A friend of mine had a 1997 4 door long bed PSD with a in the bed ball hitch. He wants to make a 1200 mile round trip to pick up a non working Grunman step van and load it onto my 30FT. gooseneck trailer. What he is wondering is just how much weight his truck can pull? He looked in the manual and it said 10K pounds. From what I have read that is just for the underbody reese style hitches right? that 5th wheel hitches up your rating when you pull ? The grunman truck is roughly 6-7K pounds.
2000 Ranger V-6 115K miles
2001 F-350 Fummins
1998 Dodge 2500 SC SB
Lee Haenschen is offline
Old 08-26-2007, 07:24 PM   #2 (permalink)
Re: How much weight can we pull?
I wouldn't think twice about it. The truck will handle it fine.
97 F250 SC LB 4X4 PSD TDE0, E4OD,3.55's, 285/70/16"s ,Modified fuel tank vents, 375+k headed for 500k
Leader is offline
Old 08-26-2007, 08:05 PM   #3 (permalink)
Yeah you should be fine with that weight ecspecialy with a gooseneck
1999 F350 PSD S/C 6spd Dually 150,000 and counting
AIS, 4" straight pipe,
Boost and Pyro guages,
Exhaust brake, IC foil delete,
DP tunes, Stock, 20T, 80E, 120R
4.10 LS rear axle, F550 rear suspension,
B&W turnover gooseneck hitch
TrailerHauler is offline
Old 08-26-2007, 09:38 PM   #4 (permalink)
He'll know the weight is back there, but it should pull it.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 2.5" axle drop bracket, F350 springs up front, and F350 rear axle blocks. 260k miles. RETIRED.
NEW (to me) 2005 F350 FX4 Crewcab shortbed, SRW, Lariat, auto, V10. 5600 lbs front end.
NickKent is offline
Old 08-26-2007, 09:59 PM   #5 (permalink)
SmokeyWren's Avatar
My Photos: (44)
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body"> 1997 4 door long bed PSD ... </div></div>
With 4.10 rear axle, his GCWR is 20k. But with 3.55 rear axle his GCWR is only 16k.
With the 4.10 rear axle and stock size tires, that trip with that load will be a walk in the park. But if he has the 3.55 axle, or tall tires, then probably the truck will struggle, especially if there are any hills or mountains involved.
SmokeyWren is offline
Old 08-26-2007, 10:47 PM   #6 (permalink)
" He looked in the manual and it said 10K pounds. "
I see that you're in NC. In MI this amount of weight is
a walk in the park. I tow a scaled 12.5K with no issues.
I see that you're in NC. If you stay in the Eastern part
you'll be OK. If you head into the mountains you're looking
for trouble. BTS told me with a little more power the 3.55
gears work fine with that amount of weight. If you were looking
for a truck, I'd suggest the 4.10 gears. If you already have
a 3.55 gear truck, more power and a trans upgrade might be in
order. I would also suggest loading the trailer and put it
on a set of truck scales. I was told that my boat/trailer
was "under 10K" by someone who owned one. The truck scales
proved that he was WAY off. I had already bought the truck
though. It works fine in MI. But, probably wouldn't in NC.
1997 F250 HD PSD 4x4 OR Auto 3.55LS CC SRW SWB 265x75x16 Michelin LTX DP 211K mi.; Ford AIC; Fuel milege; 20.3 mpg @ 70 mph. 12.5 mpg pulling my boat,12.5K, along two lane rural roads. A number of mods ordered from DaleI. Nice round replacement DP. FS2500 by-pass oil filter installed. Fumoto drain valve. Tymar Intake installed! HX mod from Tymar installed. TFI fillneck kits installed. Auto-Rx cleaner in engine & transmission done. Switched from Rotella dino to Rotella synthetic. Amsoil 5W-30 Series 3000 installed!
FS-2500 Bypass filter installed.
Velvet rides installed. Joe Servo IDM mod installed. Rear air lift springs.
Sparkydm is offline
Old 08-26-2007, 11:58 PM   #7 (permalink)
Send a message via AIM to taylortrans
i used to have a 1997 crew 4x4 and hauled a 8k# horse trailer with 4 horses making is about a 12000lb load. did that from md to south of atlanta georgia. and she is still kicking hard
2002 ford f-350, crew cab, 4x4, dually, 5 inch turn out stacks (Blackclouddiesel.com), Diablo Sport programer, ISSPRO gauge's (dieselmanor.com), reece removaball gooseneck hitch.
taylortrans is offline
Old 08-27-2007, 07:26 AM   #8 (permalink)
PSDStu's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SmokeyWren</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body"> 1997 4 door long bed PSD ... </div></div>
With the 4.10 rear axle and stock size tires, that trip with that load will be a walk in the park. But if he has the 3.55 axle, or tall tires, then probably the truck will struggle, especially if there are any hills or mountains involved. </div></div>
What is it that happens when you go to tall tires on a 4.10 rear end that causes the truck to struggle? Just trying to get smart.
97 F-250 XLT, Super Duty, PSD, Super Cab, 4x4, Long Bed, Wildman Tow Chip, Tymar Intake and 3" Downpipe, Autometer C2 Boost, Tranny, and EGT gages, towing my 20' + 5' Goose Neck Deckover trailer.
PSDStu is offline
Old 08-27-2007, 07:37 AM   #9 (permalink)
Everything on the truck is stock so stock tires...
not to sure of the rear end ratio though.
2001 F-350 Fummins
Old 08-27-2007, 07:39 AM   #10 (permalink)
Old_Machinist's Avatar
The taller tires have the effect of lowering the ratio. A 4.10 with TALLER tires will move the ratio down to something under 4.10. That is why people that get the 3.55 ratio and then put the large tires on them have some trouble towing at max weight.
I have a 4.10 rear end and use one size shorter tires (still same width) raising my ratio to apox 4.18 to 4.20. I adjusted my tire size to move RPM band (2600 to 2800) that generated the best towing performance to match the road speed I wanted to run.
96 Ford Powerstroke, Centarus Converson CC, 4.10, Long bed DRW, 4 pos TWildman chip, SD HPOP, 6.0 Intercooler, 3.0 downpipe and Bully Dog 4.0 exhaust, AFE intake system, pyro (pre turbo),trans gage (located in test port), Custom Fabion Motosports Torque Converter, pump mods, Tugger trans kit, Torqueshift tranny cooler, Firestone air bags, Rancho RX 9000 adjustable shocks, and baby SWAMPS!!
Pulling a 2000 American Star, 34RLCK bedroom and living room slides, w/d stack ,12,640 lbs.
Total weight 19,300. New addition 20ft VIP Bowrider boat towed behind 5th wheel, total length 74 ft, 24,000 lbs!
Old_Machinist is offline
Old 08-27-2007, 01:39 PM   #11 (permalink)
Weight prolly won't be a problem, but remember that if this is like the typical Grumman bread truck it will have a LOT of frontal area. I think your friend will be cruising at 55 MPH or so with that sea anchor sitting on top of a big GN trailer.
No big deal since it's just a one time trip.
'06 Ram 3500 4X4 QC CTD 6sp LB
'01 F350 PSD 4X4 6sp Crew Cab (sold)
'68 F250 C/S 4X2 C6/428PI
Stidham 24' enclosed car hauler
Bunch of big old cars
In theory, practice and theory are the same.
In practice, they are not.
Packard8 is offline
Old 08-27-2007, 08:11 PM   #12 (permalink)
My Photos: (60)
Is your firend's truck an F250, F350 srw or F350 dually?
The GCWR is the same but with the 30' gooseneck trailer and the load you may overload the GVWR (8800 lbs on an F250, 9900 lbs on an F350 srw - on my 95, assuming 97 specs are the same) without a dually.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
Old 08-28-2007, 04:36 PM   #13 (permalink)
My Photos: (18)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Lee Haenschen</div><div class="ubbcode-body">A friend of mine had a 1997 4 door long bed PSD with a in the bed ball hitch. </div></div>
1997 4 door long beds were only F350.
2001 F-250 Crew Cab, short bed, 4x4, 4R100 with VB tuned by Travis's Automatic Trans, Lariat, Snugtop shell, Line-X bedliner, 265/75/R16 GY Silent Armor. DIY open element air filter. DIY 4 inch exhaust, from stock DP back to 45 degree turn down. Quadzilla Recon XZT moniter- EGT, Trans temp, Boost. DP tuner Stock, 40T, 40T high altitude, 80E, Curt MFG Q5 20K slider hitch, P3 brake controller, ATS housing. Blue Bullet
Sold-- Bright RED 1996 F350 XLT, 4X4, CC, 4.10 gears ,E40D, SRW, Rebuilt E40D at 190K with a 3yr/36K mile warrenty, by Travis's Auto Tranny 719-574-8104. Big Red
Proud Member of the NRA, helping to protect our American Rights!
New Toy: Can-Am Outlander MAX XT 650 -- AWESOME
5th wheel 2000 Dutchman 24RL with 12' slide
TCH777 is offline
Old 08-28-2007, 11:28 PM   #14 (permalink)
My Photos: (60)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: TCH777</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Lee Haenschen</div><div class="ubbcode-body">A friend of mine had a 1997 4 door long bed PSD with a in the bed ball hitch. </div></div>
</div></div>
Figured it would be something like that. Did Ford make an F350 crew cab long bed SRW? If not, disregard my entire post. If so, disregard the first bit.
Either way, I stand corrected.
Dave / Believer45
Old 08-29-2007, 11:14 AM   #15 (permalink)
SmokeyWren's Avatar
My Photos: (44)
'97 F-250 HD CrewCab came only with a short bed.
'97 F-350 CrewCab SRW and DRW came only with a long bed.
'99-up is different. [img]/forums/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
