I just took a B&W gooseneck hitch out of my Super Duty shortbox, and installed it in my Super Duty longbox - anybody know of any way to cover the 4" hole in the box of the old pickup?
1994 7.3 I.D.I. Navistar 444 CI
ATS Factory TURBO E4OD Red On white Crew Cab DRW 4:10 w/ AUBURN LIMITED SLIP
3" ATS Exhaust and turbo housing, Banks Trans Command, calibrated pump, K&N filter, Gruss style coolant filter, 203K+MI not a lick of trouble with the motor. now on 16th trans. 10 under factory 100K mile warranty
Alpine CVA-7878 XM radio 6cd changer 3 8" phoenix gold subs 75x4 Sony mobile ES gold 4ch amp, Sony 500W 1ch amp MB quart components in Q forms kick panels. 1 farad cap.
Pro car parts jewel cut headlamps and turn signals
APC clear cab markers, suvlights.com harness silverstar bulbs and L.E.D.'s in the fenders. IT's paid for and its MINE!
Family Toys and tools,
00'F350 psd CC Drw 2wd Bright Amber Western Hauler
SOLD 01' Peterbilt 330 4Dr. Texas trucks conversion cAt 350hp
02' Psd Excursion Limited ultimate Estate Green helliwig swaybar 101K miles
1996 fetherlite 4 horse GN, 2003 sooner 6 horse GN with midtack
Right. I use the "Hide-a-Balls" so I have cut out about a 8"X10" rectangular piece of the bed, but I always save it. Then when selling the truck, I gas-weld it back in, hit it with a spray can and you have to look twice to see there ever was a gooseneck there.
I am betting a trailer supply store will have one or be able to get one.
Big washer on top and bottom, maybe a smaller one in the center
of the big washer do you dont have to use as big a bolt... Put a set on
top and bottom and bolt them together...
