Old 03-19-2006, 08:29 PM   #1 (permalink)
how well well it tow?
we just looked at a new jayco 28ft. travel trailer today , non 5th. we used to tow a 24 willderness, mabye 4500lbs. it towed it great, but with the stock 265s, since then i went to 315 toyo 315 mt. i notice a bit of power loss, do you guys think ill be ok towinn the bigger trailer? the 28 jayco will weigh around 8000 loaded. i keeped my stock rims, mabye i should put some 265s on them when i tow? hoppfully the 315s will work. thanks.
2002 f350 crew cab short box 3inch tuff country level kit 315 toyo mudd terrains on 8 inch nitto rims afe stage11 intake with pre filter window tint leer canopy auto meter quages . 4 inch mbrp exhaust. superchips 1805 tuner. towinn our 2004 27 ts komfort tt.
http://community.webshots.com/user/rws444psd
rws444psd is offline
Old 03-19-2006, 08:57 PM   #2 (permalink)
Texascadillac42's Avatar
My Photos: (10)
Re: how well well it tow?
The tires will make a difference, a very noticable difference. Id run the 265s when towing if at all possible. Itll make things alot better.
99 F350 XLT 4x4, Crew Cab, 6spd, DRW 255k and still going strong. DR Edge 2" leveling kit. 5" exhaust. Prodigy TBC. Hideaway Gooseneck Hitch. Rickson LTS 19.5 aluminum rims with 245 70R19.5 Michelin XDE M/S. Cummins 12V powered, with a few mods, SBC DD clutch
2005 F250 XLT, Supercab, V10, 6spd, 4wd, SWB, 4.10 LS
Texascadillac42 is offline
Old 03-19-2006, 09:41 PM   #3 (permalink)
thanks, think ill look in the for sale sec. for some 265s.
Old 03-20-2006, 09:37 AM   #4 (permalink)
SmokeyWren's Avatar
My Photos: (33)
The Jayco Jay Flight 28 FKS and the Jayco Eagle 282 FKS both have a GVWR of 8,500.
http://www.jayco.com/html/catalog/fl...amp;mod_id=540
So I'll bet you'll have a trailer GVW of closer to 8,500 if you're like most RVers. [img]/ubbthreads/images/graemlins/wink.gif[/img]
With a hitch weight of around 900 pounds, you should go with LT235/85R16E. They will probably cost less than comparable 265s, and they are a bit narrower but the same diameter as the 265s. And you'll get better fuel mileage with the 235s than with the 265s.
Depends on your definition of "work". If almost all of your towing is on the plains, then you'll get there with the tall tires. But if you cross the Rockies very often, or travel in any sort of hill country, or in what they call mountains back East, then you'll wish you had the shorter tires for towing. The main difference is how often your automatic tranny will downshift. With the tall tires at less than about 70 MPH, it will downshift for every little bump in the road. With the stock-size tires you can cruise at about 60 MPH without constant downshifting.
SmokeyWren is online now
Old 03-20-2006, 05:57 PM   #5 (permalink)
thanks you guys, ill look for some smaller tires to tow with, we got quiet a bit of mountain passes here in wash state,
