I'd say if nothing else, it's got to be hard on that thing. That boat has got to weight 8-10k. That looks like a Lightening in the pic and I was under the impression the towing capacity was derated quite a bit from the standard f150.
2005 F250 6.0 PSD CC torqueshift,XLT,FX4,white, rubber floors, tow command,spray-in bed liner, Weathergaurd rv tool box, Weathergaurd PakRat tool box, Michelen HD floor mats, Rack-it lumber rack, Fumoto valve, XM, Pop-Up G/N hitch, 62,000 miles already!
unless if the trailer is over 10000 lbs., then you need a non-commercial class A (15000 lbs for 5th wheel), or if the combined weight is over 26000 lbs., unless registered as a motorhome.
but the Lighting models had a reduced towing capacity compared to the regular F150's, I think it was only 5000lbs.
that combo probably weighs close to 10000 with the trailer, so I'm guessing that's probably not good from the trucks standpoint.
Maybe its from Hollywood and its made out of paper to look like a real boat. ya tell that to the DOT . lol
O5 F-250 SuperDuty CC SWR 4x4 Lariat
8' box 6.0 PSD Tow Comand new 04/05
2001 40' Alfa Toyhouse
Pulls better stock than my 01 with a programmer
New engine at 42k . Hope my luck with this 6.0 is changed .
Can't read the license plate from this vantage point.
Most states, and I'm sure it varies from state to state, if the actual gross combined vehicle weight (of the truck, the trailer, the boat and everything stowed in them including beer & fuel) is less than the weight limit printed on the license plate you paid for, you're legal.
Yes, in many states you could buy an 80,000-pound license for a Yugo and be legal towing a 77,000-pound trailer. (161,000 pounds in Michigan)
The only American authority I'm aware of enforcing the maximum gross weight published by the vehicle manufacturer is the Federal Aviation Administration. Most terrestrial Departments of Motor Vehicles only care if you've paid to play.
Douglas Campbell [drcampbell ot engineer dat kahm]
November 5, 2008: The fat lady sang. Back to actually working for a living.
1986 Isuzu P'up, 177,673.8 miles. Hella headlights, (highly recommended) DOT C-2 back end. (also recommended) R-12 air conditioner converted to R-406a. 4.1:1 rear axle converted to 3.4:1.
9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation, due to body & frame rust.
Yeah, that was what I was focusing on, taking up that many parking spaces in the middle of the parking lot. [img]/ubbthreads/images/graemlins/mad.gif[/img]
I don't think here in Texas that we can buy tags for the amount that we plan to tow, rather, the tags are based on the GVW rating of the vehicle. i.e., my F250 is rated as a 3/4 ton truck, so the tags only cost $77. (iirc).
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2003 VW Jetta TDI auto, 90k miles, all stock, no mods, 41 mpg most days. A rocket in disguise...
Repairs: alternator, brake switch (x2), power window wire harness, #4 glow plug, glow plug wire harness -TRADED as of 11/24/2008
Newest purchase - 2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available yet)
I am 99% sure the towing capacity of a lightning is 5000 or 5500. That being said, I had a friend who towed his race car to the track with his lightning...I thought that was questionable but wow thats a different story.
2001 F350 Dually, Crew Cab, 6x6, Lariat, 7.3 PSD
Auto, 4.10's, Camper Package
4.5" DR Edge Lift (soon to go on) Dual front shocks, 33" BFG AT's, 2" rear dually spacers, factory fresh trans
4" SS MBRP Cool Duals, Banks 1.0 Exhaust Housing, Banks Big Head, AIS Intake w/ Fender Cutout
DiPricol Optix Boost, Pyro, Full Sweep Trans Temp
