Old 03-06-2005, 10:34 AM   #1 (permalink)
My Photos: (10)
Increasing load carrying capacity - options?
Hi guys,
I just bought another Ford to add to the stable, not a diesel this time however. Its a 1990 F250 4x4, 240,000 miles, new auto tranny, 5.8L that I bought to use on my commercial fishing site in Alaska. The sole use of the truck will be to haul fish (up to 4500lbs at a time) a few miles across the beach and then a few more on pavement to the cannery. I'm going to go with either 285's or 33x12.5's to get the floatation needed to cross the sand. My debate is on the extras to add before I send the truck from CA to AK.
I figure I'll need to add a body lift of 2-3" to clear the tires when loaded. I'm also wondering how much the stock suspension has sagged in 240,000 miles. Should I go with an add a leaf package to both restore orginal "sag" and add a litte capacity or go with the add on air bags between the leaf springs and frame? Any thoughts on this application? The truck will get only 500-700 miles a year as it will be stored the other 11 months.
Thanks,
Lance
'89 F350 Crew Cab, SRW, 7.3 with Hypermax turbo, 5 sp, 3.55 rear, 265/75/16's, 2" body lift, Bilsteins, LUK clutch, 142,000 miles, 2nd owner
la350 is offline
Old 03-06-2005, 10:50 AM   #2 (permalink)
My Photos: (21)
Re: Increasing load carrying capacity - options?
Air bags will help you handle the load, and you'll also wanna get the highest load rated tires you can get. With 33's your choices will be limited.
After that, going only a few miles, hauling what your hauling, in your neck of the woods... I'd load her up and drive it like I stole it.
O
6.0 PSD TSB's
02/03 built F350 6L, DRW, 05 Grille , 4" DPPI Exhaust, UltraLites on the A Pillar and Overhead Console, Firestone Bags & Compressor, Hadley Bully Airhorns , 50 Gallon Transfer Flow, Racho 9000's, Leveled 2.5/0, In-Dash PC , XM Commander.
Photos
ozhoo is offline
Old 03-06-2005, 11:05 AM   #3 (permalink)
O
O - what about a ten ply Interco tire? Any issues with these, does the ply have anything to do with the load range? I know swamper SSR's come with 10 ply rating in a 33.10.5/12.5/14.5 sizes.
BREAD1 is offline
Old 03-06-2005, 12:19 PM   #4 (permalink)
Will air bags fit with the larger tires? If you get different springs keep us posted as I am looking for new leaf springs for my 86 F-350 to haul my camper.
Sold! 1986 F-350 XLT, Crewcab 4x4, converted to Dually, AT, Axle 39, 3.55 ratio, 7500lbs empty, aluminium wheels, K&N filter, rebuilt IP, and injectors, tach, trans oil temp gauge, chrome headers 2-1/2" exhaust to glasspacks to Magnaflow to 4" single, new headgaskets, new radiator, Mitsubishi starter, Big alternator, Big batteries, Racor R26S water seperator, Folding gooseneck hitch. 97 Taurus electric arm chair front seats, PW, PDL, using Power Service additive.
New Truck. 2005 Dodge 2wd dually, 6 speed, gets 15 mpg with 4000 lb camper and pulls any hill easily!
chumstone is offline
Old 03-06-2005, 06:23 PM   #5 (permalink)
Take a look at these - www.timbren.com - available from www.truckspring.com or www.awdirect.com. Probably a little less than air bags, but no bags to blow, leak, or replace, put them in and forget about them. No clearance issues with larger tires. You can put them on both ends of the vehicle. That is what I have had in the last couple of vehicles and like the heck out of them.
2002 F350 Lariat PSD Auto SC SRW 4x4, 2005 Lexus RX 330, 2007 Jayco Designer 31RLTS2.
smotu is offline
Old 03-07-2005, 11:24 AM   #6 (permalink)
My vote would be for the timbrens. I also love them, and you don't have to worry about air leaking. Air bags should not be a clearance concern though, because they mount in the same area. Add-a-leafs will stiffen the ride even when empty, which may be undesirable, or may be of no concern.
The easiest installation would definitely be timbrens. I did all four corners of my truck in about an hour.
99.5 F550 4x4 XLT--BD Power tranny, auxillary tranny cooler, inline tranny filter, 203* thermostat, 75# fuel reg mod, 4" AFE SS exhaust, DIY air intake, Edge Evolution, and Timbren Load Boosters
MonkeyWrench is offline
Old 03-07-2005, 04:12 PM   #7 (permalink)
I'm having a pair of them put on very soon. Better than air bags that leak and you have to work with them all the time. Fill them up when towing and let them down when not. [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/vomit.gif[/img]
Member: CO PowerStroke Club/Good Sam/Camping World-
2004 F250 Lariat 6.0 SD LB SC Wedgewood Blue Build date May 2003 with latest flash 05/26/05, 4" cat back with afe proguard 7 air filter, 50 gal. transferflo with tool box & Trax Command, LineX, "Brite Box", Pyro,Boost, &Tranny Gages "piller mount", C'Betr Mirror's, Cab Fresh Cabin Filter, Fumoto Drain Valve. Superchip Programmer, Timbrens, BrakeSmart, Garmin NUVI GPS.. Other: 2005 35ft. Gulf Stream Prairie Schooner
lheebie is offline
Old 03-07-2005, 10:48 PM   #8 (permalink)
What was said. I would consider adding duals. Who cares if they stick out beyond fenders if only used off road? Why not get a dump wagon and tractor for such a short haul?
larry_minn is offline
Old 03-08-2005, 04:03 PM   #9 (permalink)
My Photos: (13)
I would look at the Interco SSR Super Swampers, I have the 37's on my truck and they are a 10ply tire and rated at 3900lbs with 65psi of air, they have the sizes you need and would float if you aired them to a correct psi. I would also go with the Timbrens, alot less to worry about and with you being gone for 11 months and having to worry about the salt corroding the lines, you would be alot more worry free, and I am sure you are not worried about how the truck rides and as long as you have a ton of fish (no pun intended) it really shouldn't matter. Scotty
Semper Fi
Scott Beretz
2006 Dodge Megacab 4x4, Cummins, 6 Speed, Airbags, Quadzilla Commander, XZillaraider 2, 285/75R17 Toyo OC AT's
Pulls a: 3814SS Keystone Raptor Toyhauler w/Quads
beretzs is offline
