OK i will be installing this tomorrow in the 05 dually , i have read the instructions and i can do this, those that have done this before can you varify the measurment of 46 inches from the edge of the bed and center as the correct pilot hole for the hole saw(longbed), they have two specs 1 for the shortbed and 1 for the long bed, i dont want to make the wrong choice. i have the long bed truck
Todd
2006 KR Dually CC 4X4 ,True Blue
2005 KR Dually CC 4X4 ,Dark Copper
2005 Eddie Bauer Excursion 4X4 ,White
they give you 2 options on the longbed... 46 or 49 inches. 49 puts you closer to the cab of the truck on tight turns, but it helps put some weight on your steer axles. 46 keeps you from (possibly) having to flip up the tailgate before hooking up fully.
it just depends on what you want, and whether your trailer's overhang will allow you to back up fully with the tailgate down... i opted for the 49" location, as i wanted more weight distributed...
ps. get a good hole saw bit... mine took a dump halfway through, and i had to finish up with a sawzall... [img]/ubbthreads/images/graemlins/mad.gif[/img]
2003 Ford F350 Crew Cab Long Bed 4x4, 6" Edge all spring lift with Adjustable Panrod Bar and Dual Steering Stabilizers, 37" BFG Mud Terrains, 4.56 Richmond Gears, DPPI Turbo Back Dual Exhaust, Autometer C2 Gauges on A Pillar, aFe Proguard 7 Intake, Reese Titan V Hitch, B&W Turnover Hitch, BrakeSmart controller, ORU Air Overload System My truck pictures
I install these hitches at my part time (2nd) job and have been for about 10 years now. If you follow the directions you will have no trouble. I allways use the 49 inch measurement on long bed pickups to get more weight on the steer axel.
1992 F350 7.3L Crewcab Red over Black 5 speed 4x4 SRW Hypermax Turbo.LT 235/75/16 tires 137,000 miles
Install was pretty easy, i went the 49 inch route, i wont tow the trailer till next week, thanks for the help, also can i plug the trailer socket to the bumper or do i need to make an extension to the hitch
Todd
I'm going to install a trailer plug in the side of the bed of my truck. I'm tired of letting the trailer wire drape over my tailgate and having to worry about it hanging up on something on tight turns.
03 F250 SD PSD Lariat 7.3, FX4 Crew Cab Short Box, 3.73 Gears, Auto Tranny, Jody Tipton 80 HP Econo Tune, Turbo Back 4" Exhaust W/5" Tip, Home Made Tymar, Isspro Gauges, T/C Lock Up Switch, 203 Degree Thermostat, Coolant Filter, Upgraded Headlight Wiring Harness, Diode Mod for Dims, Bilstein Shocks, Kenwood Head Unit, Sirius Radio, Valentine 1
