Issue with new Prodigy and/or trailer brakes - Diesel Forum - TheDieselStop.com
Old 08-23-2009, 02:56 PM   #1 (permalink)
Just put my new Prodigey in this week. Veyr happy with it on my 4 horse trailer. Hooked up to the 2 horse and it displayed NC-no trailer connected. Took the plug apart and had my wife work the manual lever. I had power to the plug, through the plug, and at all 4 magnets. Any idea why it'd say NC? I don't know if the thing is "smart" enough to sense a bad magnet and just won't work at all or what might be going on. Just looking for some input before I start throwing money at it till it works.
Aaron SEIA
My Truck:
97 F350 4 door dually, E4OD, DIY intake
only exhaust is stock DP
flatbed
gutless wonder, I want my 94 back!!!
AaronSEIA is offline
Old 08-23-2009, 03:09 PM   #2 (permalink)
Got Diesel?'s Avatar
Aaron SEIA
Well, if one trailer works and the other doesn't you have eliminated the truck as the problem. I would check your ground on the trailer side. Some believe that it will ground through the ball I have found this to be incorrect.
Check each ground on the brakes (pull on the wire to make sure you have a good connection) Then run a jumper from a good ground location on the trailer to a good ground on the truck.
2011 F350 6.7 cc, sb, lariat -8611lp Blizzard Plow
2000' F-350 Reg cab 4x4 Plow truck- 8611lp Blizzard plow, FTVB, DP Tuner
2001 F-550 Reg cab 6x6 dump truck with 11ft contractors bed- 8611 Blizzard plow
2005 F-350 ex, lb, 4x4 V-10 Blizzard 8611lp plow
1999 f-250 Reg cab 5.4 western 9' pro plow
2003 Mercury Marauder
1989 Mustang Coupe- Drag car 10.96@ 126
Got Diesel? is offline
Old 08-24-2009, 11:14 AM   #3 (permalink)
Check your grounds as suggested. When I connected my Tekonsha P3 the first time it said 'NC' and then "Open Ground'. I jiggled the plug side of the trailer connection and it didn't help change the display but all the trailer lights were working. As soon as I towed it about a mile the brakes were working fine. I think the ball mount was rusty and making poor contact. I love all the great functions on this controller especially the boost settings and back-up override.
03 F250 SD Crew, Fx4, Lariat-160K
02 F150 XLT Super Cab-135K
07 Toyota Highlander-35K
2Tight is offline
Old 08-30-2009, 07:56 AM   #4 (permalink)
I manage a trailer mfg company, and the way I wire trailers is every light, brake etc is grounded through the plug, which in turn grounds to the Breakaway kit. We also have 2 ground wires drilled into the frame of the trailer, one at the axles and the other at the breakaway kit.
durantdiesel is offline
Old 09-12-2009, 08:46 AM   #5 (permalink)
TPford's Avatar
Not too sure if you have fixed your problem but I had come accross the same problem with my prodigy. I started with the simplest solution and cleaned the contacts on both the 7-pin plug connection on the back of the truck AND the trailer plug. A little paitents and som fine grit sandpaper....No more connection problem.
I have found that it doesn't take long for corrosion to appear in the plug of my travel trailer here in Southeast Louisiana.
'02 F-350 CC LB 4x4 DRW 4.10
148,*** miles, stock motor, original trans
MODS - AIS Intake, 203* w/Billet Housing,
TPford is offline
Old 09-26-2009, 10:58 PM   #6 (permalink)
to clean the contacts on the seven pin plugs I use a finger nail board trimmed to a useable width. Have use this for many years
Fordpowerstroke350 is offline
