Re: It's time to replace tires on fifth wheel. What do you recommend?
I want to change to 15" LR "D". Any recommendations that have worked well for you? Marathons get mixed reviews, but I've had excellent luck with them.
Sounds like you're in the same boat I was. The new trailer came with not quite enough tire on wheels that are too narrow for bigger tires. ST205/75R15C on 5.5" wheels.
After I blew out 3 of the stock Marathons, I decided to upgrade tires. At the time nobody made an ST205/75R15D. So I upgraded wheels as well as tires and went to Cooper ST225/75R15D on 6" wide wheels.
After too many miles on the Coopers, they started coming apart so I replaced then with ST225/75R15E Denman Express ST radial. No more tire problems.
Wheels are available from www.southwestwheel.com for less than $50 per wheel. My Denmans cost almost $100 each.
If you don't want to upgrade wheels yet, Denman now makes an ST205/75R15D radial. Max PSI is 65, but if your wheels won't handle more than 60, then those tires with 60 PSI will carry a lot more weight than the stock tires
@ 50 PSI. http://www.denmantire.com/catalog/Trailer.pdf
I'm looking at the Green Ball ST 225/75/R15/E 1B, speed rated for up to 106 mph. I guess I'll have to look at the Denmans too. Any body know the speed rating on the Denmans????
Almost anything but Carlille's.
2002 F-350 SRW Lariat,4X4, PSD with too many goodies to list. 182k and a very strong 7.3. SOLD
2008 F-250, SC Lariat, 4X4,Shortbed, Pueblo Gold/black, V-10, 4.10, auto, Delivered on 9/7/07, great looking rig. South Texas bumpers front/rear, Air Raid Intake System, Diablosport Predator, Husky's, JJ's, Ford alarm/remote start, Marathon seat covers, Sirius, PIAA, Access cover, Weatherguard tool box, Rhino liner, Michelins, Duraflap mud flaps, Escort 9500i.
2007 Lincoln LT (wifer's grocery getter)
1996 Ford Bronco EB; almost stock
2007 Kubota 900 RTV diesel with goodies. pappy's truck
Hello,
The 5'ver is a 29' Titanium (24E29) with 15" Goodyear Marathons load range "C" and aluminum alloy wheels.
Dave Holl
Like you, I've had good results with the Goodyear Marathons. My 32' Jayco has 225/75R15 Load Range "D". I run them at 65 PSI (max pressure).
4-5000 miles a year over that last 4 years without problem. I'd do them again. Not to say there isn't something better.
Here is most of what you need to know on getting your 7.3L started and how to operate it in the cold winter months. These posts use to readily available, but they've been hid in a subforum top of the 7.3 Power Stroke Engine and Drivetrain forum. Winter Operation (How I Do It) Hard/No Start? Check here first
After chewing up tires on a regular basis, I switched from 'D' 'any brand' to "E" rated Denman tires on my 5'ver. Nary a problem since. I've put a second set of Denman's, after 30k miles or so, on my trailer. Alaska and back on Denmans and no blowouts. My Bro-in-law went with us to Alaska and lost several tires before we got to Anchorage. He ordered a set of Denmans in Anchorage and hasn't lost a tire since. We both now travel with a "E" Denman spare and another Denman "E" unmounted spare... just in case.
Goin to Washington and Oregon in 2008 and going back to Alaska on my current set of Denmans in 2009. Hope to buy Gooch a beer and shoot the breeze when we get up there.
Ain't nothin' but Denmans going on my trailer, ever, unless they move production to China.
Florida Ed
2001 7.3 F-350 Dually Lariat CC LWB 4X2 Dark Green 4.10 4R100 5'ver Hauler (32' Montana 2 slides 10,500# - 2,000# tongue weight), 106 gal aux tank, 112K miles, nephews arguing over who will inherit it 'cause I'm gonna' drive it 'til I die. Bone stock.
2001 5.4 Gasser F-250 XLT Crewcab SWB 4X2 3.73 4R100 67K miles headed to 150K (wife's vehicle on the "junk-iron" theory of vehicle safety....most junk iron wins in a crash) stock as the day it was made
Before these: '00 F-250 CC PSD, '97 F-250 CC PSD, '94 Ford F-150, '91 Ford E-250, '81 Ford E-150, '66 Ford F-100 (cars not included)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: brother</div><div class="ubbcode-body">I thought all trailers that size came with 16" e rated tires,my 31bwfs Sunnybrooke did.</div></div>
Nope. Take a look at my sig. Mine came with 15" D rated if you can believe it. Pretty big issues with a lot of the heavier trailers out there. Carlisle stands to loose a LOT of $$ due to inadequate tires on heavy trailers.
I'm working with them as we speak for 7 replacements after 5,000 km.
2003 350 Lariat FX4 Short Box 6.0L *SOLD*
2008 FX4 F350 6.4L Dually Long Box, Black on Black PICTURES
2007 Keystone Raptor 3712TS PICTURES
Hey Newbie, I have the exact same trailer as you. I just had three blowouts on a trip a trip from Portland to Glamis and back. Two on the way down and one on the way back. Everytime was a violent blowout doing massive damage to my trailer. The fenders on both sides were blown off along with big pieces of the aluminum siding. Also the propane supply line for the fridge and the stove was blown off.
I have probably 5000 miles on the trailer.
kept having blowouts on the carlisles. switched to goodyear marathons and no trouble since. haulin a 24ft pace racecar trailer maxed out on weight @ 10,500lbs @ 75-80 mph consistently up n down the west coast sometimes nonstop for 8-10 hours!!! heat n weight are the tire killerz! blew out the carlisles on my boat trailer as well. switched to the goodyears again and no probs haulin max weight at speed!!!
06 F350 xlt sport fx4 srw lb cc 6.0 at afe pg7 cai & 4" turbo back exh accufab polished power elbow & home made ss mesh air fury copy readylift 2.5" leveling kit + 1"rear block on 17" atx teflon thugs 33" bfg at's jvc cd dvd sirius head unit with 4 infinity kappa speakers 4 channel infinity amp 10" jl console sub 500 watt jl amp microvision dvd & headrest monitors 4 the kiddies in back!
01 chevy monte carlo ex-nascar southwest tour car raced in the american stockcar challenge(2007 champion!!)
02 sanger V210 black scorpion 330hp 2 fat sacks proflight tower with 4 infinity 6x9's rf400 watt amp 12w7 jl sub rf 1001bd clarion amfmcdsirius head unit 4 clarion marine speakers 5 channel hifonics amp driving a 10" bazooka sub enclosure firing a jl 10w3
08 international 4300 dt466 allison century 612 wrecker alcoa's
04 ford F650 xlt supercab 4dr cat C7 allison century 21 ft steel carrier alcoa's
97 ford F450 xlt sd 7.3 5 spd century 412 wrecker
Reason: proper spelling
