I've got a Jordon Ultima brake controller which works well except that it doesn't shut off when you are done braking. Sometimes when you take your foot off the pedal the brake controller stays on.
The problem is the brake cable adjuster device that attaches to the brake pedal. It is long and a bit heavy and it continues to pull on the brake cable after the brake has been released because the adjuster end droops down. It doesn't help that my brake pedal doesn't fully return to the top of its stroke by about 1/8". I find myself driving down the road looking down at the brake controller and seeing it sending 0.5 to 1 amp to the brakes. If I pull up on the brake pedal with my toe it shuts off.
Anyone else have this problem ? Any ideas on making it better ?
'99 F250 Superduty CC with 05 Cummins (325/600), BHAF, Donaldson M090544, ZF6 and timing advanced 2.2 degrees.
I got it to go away by angling the bracket that holds the heavy "cable adjuster device". I angled it so the adjuster was pointing up higher (almost vertical). That kept the weight of the adjuster from pulling on the cable.
It took some initial tweaking to get it right, but it has been good ever since.
<font color="green">99.5 F-350, CC, SB, SRW, Lariat, ESOF 4X4, 4R100, 3.73 LS, Off-Road, TT, Heated TTMs, 4W ABS, Cab Clearance Lights (to make the wife MAD!), Arma Bed Liner, Bug Deflector, Ford Splash Guards (Don't call 'em Mud Flaps), Triple Gauge Pod, Autolamp/DRL system, 285/75/16 Bridgestone Dueler REVOs</font><font color="red"> Fire Engine Red,</font> <font color="purple">Born on Date: 4/27/99</font> F-D Member Since: 5/99
I had the same problem. Played with the angle of the mounting bracket for the cable adjuster and was able to cure the problem.
2000 F350 SRW, SC, Auto,2 WD,Zoodad, Sonnax Valve & Tricummulator Springs, NAPA coolant filter, CCV Reroute,Home made Tymar, TAG 1 and 2, Magnefine Trans Filter, Gauges (Pyro ((Pre Turbo)), Boost, Trans, Water Temp and Oil Press),Dahl 100,TC lock-up and light, 18 K Mod (with TAS), Heater bypass valve, IAH Delete, 203 Thermostat, Jordan Controller, Timbrens, and Walker BTM.
I had the same issues and finally gave up and ordered a Prodigy. It was either too loose or too tight and I got too you know what to fuss with it anymore. I like the principal behind it but...
June 1996 F250HD XLT/SC, LWB, 4x4, 4:10LS, E4OD, White outside, Gray inside, Camper/Tow pack, Factory Aluminum wheels, Factory rear slider, decal free.
Factory AIC, Aux dash switches, Full add-a-leaf, Mile Marker SS Hubs, Upgraded E4OD Tranny, Tymar intake, BD downpipe, Exhaust brake, 203* stat, BriteBox, California Regulator mod, Truck Interiors Winterfront, Ported bug guard, Energy Suspension bushings rolling on 265x75 Bridgestone Revo's.
I have a Jordan 2020 and had the same problen. To fix it:
On the part that connects to the cable there is a small nut. Take the nut off and add a washer like a fender washer. Between the fender washer and the bracket that attaches to the brake pedal install a garden hose washer. This will hold the spring loaded part against the bracket on the brake pedal. When you release the foot brake the hose washer and fender washer will cause the cable to be pushed toward the controller and will turn off every time.
So you will take the spring loaded thing, remove the nut, install a garden hose washer and then the fender washer. The garden hose washer will slip over the entire spring loaded thing so you have to hold it next to the fender washer and install the assy as per the factory insturctions.
Hope this makes sense.
Jim
2001 F350 SC DRW 4.10, Everything except leather. 2001 35' Kountry Star 5th. Fulltiming RV'er. BTS Tranny, BTS 60 HP towing chip, exhaust brake, full gauge set, 4" turbo back exhaust/w5" tip, Mag-Tec diff cover, Amzoil 75/140, rear axle temp gauge, Bilstein's, Reese 20K, Jordan 2020
