Old 06-03-2005, 10:26 AM   #1 (permalink)
My Photos: (9)
King Pin
My 5th wheel has an adjustable king pin and I want to raise the pin one set of bolt holes. If you have done this, is there any cautions or info I should consider other than it is very heavy?
Aaron.
2005 - F-350, PSD, LWB, FX4, KR, Oxford White/Arizona Beige -- Bausch & Loam Sunglasses
My Photos -
SOLD - 2001, F-350, PSD Lariet, Oxford White, CC, LWB, DRW; [color = red]Maghytec Transmission Pan and Differiential Cover[/color]; Autometer Bezel; [color = blue] SPA Boost/EGT, Transmission and Differiential gauges[/color]; Ford Bug Shield; WeatherTech Rain Guard; Pioneer 6 disc changer; Ford Rubber mats; Cobra 29WXNWST CB Radio; Cobra CA 77 Power microphone; Husky Molded Flaps and floor mats. [color = green]Banks Power Pack[/color]. J&J Stainless Steel Running Boards. J&J Victory tail gate. Bilstein shocks. [color = red] 2003 heated TT Mirrors - with rear window defogger switch. [color = red ] C-Betr Mirrors. NMC2. .[color:"red"]SoCAPS Member[/color] [color = green] SoCaps Founding Member [/color]
Aaron Ruble is offline
Old 06-03-2005, 11:11 AM   #2 (permalink)
Re: King Pin
It is easy to do. Be carful that you dont let it fall out because yes it is heavy. I adjusted mine without problem. I lowered the pin to get enough clearance between camper and bed rail (you need at least 6 inches). You could block up under it, let it rest on the fifth wheel hitch, or just get someone to help hold it as the last bolt is removed. Sometimes the friction between it and where it mounts is enough to keep it from falling, you might even need a hammer and block of wood to get it to move once bolts are out. Be sure and torque the bolts (about 65-80 ft/lbs.)then check them again after towing awhile.
2002 F350 4x4 CC DRW Lariat 7.3 auto 4.10 LS diff.(bought 5-05 @ 76,000 miles) Pyro, Boost, and Trans gauges. AIH delete. Tru-Cool Max trans cooler. Magnafine filter. Royal Purple MAX synthetic ATF. 55 gallon aux bed tank. 2LO Mod.
2002 Holiday Rambler 30-SKS Alumascape fifth wheel
24 foot gooseneck livestock trailer
1940 McCormick Deering restored Farmall H, used weekly (the grand-daddy of International)
Used goats for rent
twobit is offline
Old 06-03-2005, 11:51 AM   #3 (permalink)
Re: King Pin
Heres what I did: Loosen, but don't remove, all 4 bolts. Remove the front 2, put a pin or >smaller< bolt in the holes, remove the back 2, raise the back to the next higher position, re-install the bolts. Raise the front to the next higher position, re-install the bolts. Re-tighten all 4 bolts, REAL tight. (I put 200 ft lbs of torque to mine)
Done Deal. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
JOE
2K, F-350, XLT, XCAB, 2WD, DRW, 6 Spd, 3.73LS, 4 Pod pillar mnt, EGT, Boost, Trans/Engine temp, Fuel press. guages, Quadzilla 50/75/120,ES AIS w/fender mod, Shimmed FPR, Dahl pre-pump filter, HX Mod, Racor (Mod'd) CCV, Premo oil Refiner, W/Wheel with both TAGs, Banks W/gate actuator, DT466 CPS, 6.0 Intercooler, Banks I/C tubes & DPP boots, 25psi BPRV, Full 4" exhst, AeroTurbine w/exhaust guide, MagnaFlow, Intake Heater Delete, Heater core bypass, 203* Thermo, Coolant Fltr., "Hutch" Tank & Fuel system Mods,fill pipe fix, Mag-Hytec Dif cvr, Fumoto, Bilstiens, SafeTplus Steering Dampner, Centramatic's, Ride Rites, SilverStars, Clear APC Head/Tail/Corner & all Marker lights, 2 850cca Optima's, Ultra Boards, Burlwood Dash, XM radio, Billit Grill (Black). TTMs/C-beters. Pull a 32 ft Montana FW. 102K
BIG JOE is offline
Old 06-03-2005, 03:16 PM   #4 (permalink)
Re: King Pin
i'm just thinking out loud as i have never dealt with a 5th wheel (other than big trucks) before. but is there a way to hookup to camper and use your landing gear to put a little pressure on it and then remove the bolts and then use landing gear to raise it to desired height and then replace bolts in the other holes.
i'm asking basically so i'll know if i'm ever in this situation myself.
thanks
thomas
<font color="orange"> __________________________________________________ _____________________________</font>
aka Power-Strokin' (234 posts)
<font color="orange">'02 F250 XLT CC PSD 4WD</font> <font color="navy">3.73ls VDH2 oxford white/silver metallic, DP-Tuner 4 pos.(40, 70, 100, 125), FTVB, AIS, WD Turbo Brake III, 4" Magna-Flow turbo-back exhaust, wicked wheel, 3 guage A-pillar pod w/ Di-pricol white-face guages, ITP fuel system, after market leather seats (two tone), Super-Liner, "chromed" emblems, CCV mod., BFG AT 295/75-16 on 16 x 10 Ultra Type 50/51 wheels, Rancho RSX, Amsoil bumper-to-bumper, PopUp GN hitch, GOS harness & SilverStars </font>
'04 F250CC Lariat PSD FX4 white/silver, Putco stainless toolbox, stock!!!
<font color="red"> Immokalee Regional Raceway </font> <font color="green"> '57 Cushman Eagle </font>
AllStarPSD is offline
Old 06-03-2005, 03:58 PM   #5 (permalink)
Re: King Pin
Thomas... Ya, I tried it that way once, it can be done. but yer purdy much stuck.... not much working room around the pin box, front,rear, side to side, head room, cuz yer dealing with the pick-up bed.
I lower/raise mine (others) down to a comfortable (for me) working heigth useing the landing jacks.... then, useing 2 clevis pins (as mentioned), go 'bout the business of doing what needs to be done.
BIG JOE is offline
Old 06-03-2005, 06:58 PM   #6 (permalink)
My Photos: (10)
Re: King Pin
Yes thomas if you are small enough to squeese in to the space after you hook up.
j_apetersen is offline
Old 06-06-2005, 11:56 AM   #7 (permalink)
My Photos: (9)
Re: King Pin
Thanks for the come back. I just did not want to do something that should never be tried. I'll go for removing two bolts and and use a pin to hold it until I can move it up. Concur with the 200 lbs torque -- that's what the manufacture said it should be. Concur with ya gotta check it at the rest stops. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
My Photos -
