Considering switching trailers 2004 Nomad north trail 3040 34' 6600 dry, 9400 GWR
t0 2006 Flagstaff super lite 31'6" 5300 dry 7300 GWR.
The flagstaff has torsion spring suspension vs. the nomad's conventional leaf spring. I've never seen a setup like on the flagstaff and was wondering if it is as trustworthy.
I was told that it acts similarly to a garage door spring and gives all 4 tires independent movement. I also assume that it's only used on lighter trailers.
Anyone familiar with this?
Old Brown--'85 F250 C-6 2WD Reg. cab 2.5 dual exhaust magnaflow muffler, ram-air just like ziggs FOR SALE
That Damn Truck--84 F250 ext. cab XLT C6 2WD 6.9 from DPS, Banks and PSD turbos plumbed in series (ready for tweaking), new paint, lots of money and time and I'm still not done.
75 F250 hiboy 4X4. yard goat 360 CI C6 custom steel flatbed, doghouse removed replaced with flat sheet metal, all wiring removed, no key necessary. "The Beast" OSHA approved, though.
If we're both talking about the same thing, I have it on my horse trailer and it's the greatest thing since sex. Totally trouble and maintainance free. The system hadn't been out too long when I got my tlr. ('90-'91) and soon became real popular. The brand name was something like Henshen, but now I see Dexter, etc, offers the same system.
Not really, but if you do a search, I'm sure you can find pics. If you go to the Dexter axle site, then select Torflex, (that's their name for theirs) there's a good pic of the system.
Torsion spring suspensions have been aroung for years, my '70 Scotty trailer has them. And I believe Airstream used them.
They're generally suited only for light trailers, since the torsion spring is very highly stressed. They're not quite like garage door springs, the trailer versions are heavier and consequently have less "wrap".
'94 F250 supercab 4x4, original owner, 4.10LS, shimmed FPR, Tymar air intake, DP Tuners 80 Econo burn, VDO gauges (boost,pyro, outside temp), Ford digital AIC, DPPI downpipe, gutted EBPV, add-a-leafs front and rear, Monroe Reflex shocks, Milemarker 449SS hubs, towing 25' Mallard travel trailer
With the Torflex and Henshen type there's no spring involved. You get your torsion action from a strut or arm coming out of an encased rubber bushing in about a 4" section of thick walled square tubing. It's the rubber bushing flexing with a twisting action under load that gives you your "spring" action. They also come in heavy axle weight ratings, mine was supposed to be 7000lbs. but is 6000lbs.--factory screw-up. You can get them for as heavy as 14,000lbs. rating, maybe more nowdays. However the original poster never posted back, maybe this type isn't even what he has in mind.
They work fine but the only problem with them is like you said they work independent. I had them on one of my goosenecks and my truck was to tall and the trailer didn't sit level so a lot of the weight of the trailer was sitting on the rear axle where as with a typical leaf spring set up, when one axle goes up it pushes down on the other axle so the weight stays even on both axels. The torsion is fine as long as the trailer sits level and you dont go much off the pavement with the trailer.
Early 99 Ford F-350 4X4 Extended Cab Dually, 4 in lift, 6spd, dual 5in stacks,ts 6 stage, zoodad, ccv, tymar,
240,000 miles and counting
1993 Ford F-350, 4X4, Fuel Injected 460, MUD TRUCK, 40in super swampers, Dana 60 Front, Dana 70 Rear, 10in home made lift.
1982 Mustang 302 HO
I appreciate the info, and I looked up the dexter axle site for their system. It's definitely a cool concept, and if they've been around as long as y'all say, I guess there's no concern.
I just hadn't seen them before.
You'll get a much nicer ride out of them, especially for an rv
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 235k miles and thousands of $$$$ in maintenance and repairs.
I have them on my boat trailer which is about 5K including boat. They work great, but like others have said you need to hitch so trailer is level. (equal pressure on 4 wheels)This is also important in braking. If you have brakes on only 1 axle and the trailer is 'light' on that axle you could likely skid in a panic stop.
Also something cool about torsion axles is I had a brake caliper bolt fall out (on a NEW trailer, first time out...) locked up the wheel, flatspotted the tire, destroyed the caloper. I removed the wheel to finish the short trip home. Try driving with 3 wheels in a leaf spring trailer!!! (without a chain..)
Pat
...A "Faceplant" is my most consistant wakeboarding "move"
'06 F-350 4X SRW LB Crew Lariat to pull an '04 Malibu VLX and a 10k dump trailer.
Make Welfare as hard to get as a Building Permit....
I would guess they could be set up on a heavy pivot arm mechanism and give the same type of independent float as the more traditional setup. Kind of like I have seen of big equip trailers where there is one huge set of springs and the pivot is attached where the axle normally would be fastened. Would end up making it an off pavement capable independent torsion system! [img]/ubbthreads/images/graemlins/cool.gif[/img]
GOD BLESS OUR TROOPS!! - GOD BLESS AMERICA!!
I have the Dexter setup on my 28 foot enclosed car hauler. The trailer is a 1999 and I have pulled it all over the US... the axle setup works great. Also, for loads, the trailer is typicaly about 10,000 lbs and I have had zero issues with the suspension.
Torsion bar concept has been around for years and years, this is using rubber instead of spring steel, but the same concept.
2004 Expedition
2003 F250 C/C V10, Banks Power Pack, Transcommand, 4.30LS, MagHytec Diff Cover, B&M Deep Trans Pan, 16K Super Glide Hitch
2006 Thor Vortex 36' 5er Toy Hauler
I've been shopping around for a new boat trailer. The
major choice now is leaf vs. spring suspension. Can the
Torsion take a "set" after a while and the whole axle
has to be replaced? That's one line I was given by a
builder. It didn't sound right but, I have no clue. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1997 F250 HD PSD 4x4 OR Auto 3.55LS CC SRW SWB 265x75x16 Michelin LTX DP 211K mi.; Ford AIC; Fuel milege; 20.3 mpg @ 70 mph. 12.5 mpg pulling my boat,12.5K, along two lane rural roads. A number of mods ordered from DaleI. Nice round replacement DP. FS2500 by-pass oil filter installed. Fumoto drain valve. Tymar Intake installed! HX mod from Tymar installed. TFI fillneck kits installed. Auto-Rx cleaner in engine & transmission done. Switched from Rotella dino to Rotella synthetic. Amsoil 5W-30 Series 3000 installed!
FS-2500 Bypass filter installed.
Velvet rides installed. Joe Servo IDM mod installed. Rear air lift springs.
I will never go back to leaf spring axles. I have towed a 12,000 lb boat on a triple axle torsion spring trailer since 2002. I now have 46,000 miles on the trailer and have never had a flat tire. The original tires are Goodyear Marathons load range E and they look like new.
My trailer is a Myco which is a very precision trialer and Myco told me they have recorded over 80,000 miles on a set of tires.
Other then brakes and bearings this has been the best set up I have ever seen.
I trailer all over the East coast with friends with leaf spring axles and they are always having flats.
With my set up you don't carry a jack. You just drive the good tires up on a 4 x 4 and remove the bad one if you have to, or run up over a curve.
Torsion axles are the best thing to happen to the trailer industry in my opinion.
2002 F350 7.3 PSD DRW Crew Cab Long Bed 4 x 4 AutoMeter C2 Guages on Wood Grain "A" Pillar, AFE Stage 1 Intake, Turbo Back 4 Inch Stainless Exhaust, DP Tuner W/ Stock, 40HP Tow & 80HP Economy, Glasstite Bed Cover, 50Gal Aux Fuel Cell, Custom Stereo, Titan Class 5 Receiver, Air Bags, Tru Cool 4590 Transmission Cooler
Can you explain to me why leaf spring axles are going to give you more flat tires than torsion axles. I definitely do not understand that one.
I'm wondering the same thing. Most of my wear is pulling into and out
of my driveway. The sharp turn while backing puts the rear axle
tires through contortions. You can see the extreme wear on the tire
edges. I don't see how going to a torsion axle would improve that.
I love the idea of being able to remove the blown tire and keep
on towing. That would be great! I now carry extra jacks and
chains while praying I never need them. [img]/ubbthreads/images/graemlins/phoney.gif[/img]
