Old 03-02-2008, 02:39 PM   #1 (permalink)
Supporting Member
detroitfd's Avatar
Levelling rear while towing
Hey guys-
When towing my 7k# travel trailer, the excursion rides pretty comfortably, but sags a bit in the rear. I sort of remember reading about some using different springs or something of that nature, and others using air bags. Obviously the air bags would be adjustable, so that's a huge plus, but I'm sure cost more as well.
How much is a c omplete air bag kit? With a little poking around, it looks like you buy the bags and control kit seperately, and that's about $4-500 and up. Are there better deals to be had, perhaps buying entire kit?
If other methods such as springs, how do you guys like em? How much are these options?
Thanks in advance for your opinions guys, just beginning to check into this for the towing season coming up.
Jerry
My PSD X
2000 Excursion 7.3L PSD 4X4
DP-Tuner F5 : no start, stock, 40T, 80T, 80E - AutoMeter A pillar w/ 3 Phantom gauges - DIY Tymar intake w/ serviceable S&B filter - Zoodad mod - B&M HD Trans rebuild w/ TransGo Shift kit & Amsoil Fluid- BD Triple Disc Billet Torque Converter - Exhaust : 4" Turbo Back (w/ 4" down pipe) Stainless Steel Magnaflow - ATS housing and 4" intake sleeve - Turbo Master Wastegate Controller - Dieselsite HX Oil Crossover - Morse Ceramic brake pads - Monroe Reflex Shocks - Energy Suspension Bushings - IC foil wrap delete - Fumoto Oil Valve - 08' Aluminum Rear Differential Cover - White Night reverse light system - Garmin StreetPilot c340 GPS - 6.o tranny cooler - Dieselsite Coolant Filter - Amsoil Single Bypass Oil Filter w/ Rotella 5W40 synthetic oil - APC white gauge face - Dual in-dash DVD w/ Infinity Reference speakers & Blaupunkt 200A powered sub
TOWING:
2004 Dutchmen 31BH travel trailer
detroitfd is offline
Old 03-02-2008, 03:21 PM   #2 (permalink)
overfly's Avatar
My Photos: (16)
I use Firestone air bags with an onboard compressor. Had them on for 2+ years and never any issues. They can be adjusted for different loads, terrain, etc., which makes them very convenient. I got them here for about $500 for the bags, gauges, compressor. I'm very happy with them and the install took about 3 hours.
2006 F350 - Amarillo Package,loaded with all the toys, 4" MBRP cat back exhaust, Autometer EGT gauge, Viper 791XV auto start/cool down timer/alarm, Pioneer AVIC-D3 navigation/XM Radio/Sirius, 2.5" Tuff Country Leveling kit, KC Hilights front & rear, Dieselsite.com coolant filter, SkyJacker dual steering stabilizer, Firestone Ride Rite airbags w/onboard compressor, Kleinn Train Horns, Bilsteins all the way around, Recon LED's in the back, Programmed with the SuperChips 1805 Tuner always set on Tow Safe for a little extra get up and go.
30' Cardinal 30TS 5th wheel. The weekend home away from home.
"The early bird may get the worm, but the second mouse gets the cheese."
overfly is offline
Old 03-02-2008, 04:59 PM   #3 (permalink)
Originally Posted by detroitfd View Post
Hey guys-
Are you using a weight dristibuting hitch? If you are, it may need adjusting. If set up right, the whole rig should be level, especially at that weight.
OMC
OMCUSNR is offline
Old 03-02-2008, 05:13 PM   #4 (permalink)
Supporting Member
detroitfd's Avatar
OMC
Yes, I'm using the Equal-I-Zer hitch system. The issue is that it's adjusted all the way up right now. There are two adjustments on it : The L brackets on the trailer frame and the # of washers on the hitch near the ball. Both are adjusted fully. It's not horrible sag, but noticeable.
Funny thing you mentioned that. I didn't know you could use the hitch shank both up or down, so in Spring I'll recheck it and see if that helps.
Plus, now looking into steering wandering correction before the bags perhaps anyway. So many choices.
Thanks for pointing that ut, maybe it'll work.
Jerry
My PSD X
TOWING:
Old 03-02-2008, 07:33 PM   #5 (permalink)
Hook'em Horns!'s Avatar
Hey guys-
If price is an issue, just a manual Firestone Ride-Rite [2251] at Underbid.com air spring kit can be had for less than $230. Utilize a small plug-in compressor for adjustment and you're there.
2005 Chev Duramax/Allison 3500LS DRW Crew Cab
B&W 30K-Turnover GN, Putnam XDR 15K, A/T Revos
2006 Chev 6.0L/4L80e 3500WT DRW Ex-Cab 9'Flat-GN
A/T Revos
DON'T STEAL! The Government Hates Competition
Hook'em Horns! is offline
Old 03-02-2008, 08:31 PM   #6 (permalink)
Perhaps you do not have enough tension on the tension bars? It should be very hard to leever them into place. If it is fairly easy, then you do not have enough tension. Move the brackets higher on the trailer frame.
If they are adjusted right, then it makes the job easier if you crank up the trailer/truck once the ball is locked, then lever the torsion bars in place. Now lower the crank and the tension will come onto the bars. Do the reverse to unhitch.
Do you have the manual for the hitch? It has clear adjustment and useage instructions.
If your steering wander is while hitched up, it is probably related to too much downforce on the pin or insufficient tension on the equalizer.
John
99 F350 PSD CC DRW, BD Tranny, Fan driven tranny cooler, exhaust brake, tranny temp gauge
Titanium 29/34 Fifthwheel
HiJack 21k 4way hitch
hiljoball is offline
Old 03-02-2008, 10:40 PM   #7 (permalink)
Supporting Member
detroitfd's Avatar
I did follow the instructions, but they didn't seem spot on for my truck. Basically my L brackets on the trailer are already adjusted all the way up. But if I flip the receiver with the ball on it, it'll give me more adjustment up then I have now. I'll try it in the Spring and see if it helps.
Thanks.
Jerry
My PSD X
TOWING:
