Old 03-11-2008, 02:45 AM   #1 (permalink)
Long bed or Shortbed for towing 5er?
I am looking to buy a used PSD, preferably with a crew cab. Any opinions on a long or short be for towing a 5er would be appreciated. I know that there can be clearance issues with the short bed. Other than that is there much difference?
Since I'm buying used I would like to buy a truck with 50k-80k, for a better chance of less abuse. I have leaned toward the 99-03 7.3's due to the reputation. I am finding that the cost of these older trucks with the mileage that i'm looking for is comparable to the cost of the newer trucks with a 6.0psd and same mileage. I have heard and read quite a few horror stories on the dependability of the 6.0. How do you all feel about their dependability.
I will be traveling around the country towing a 5er between work assignments and daily driving otherwise. Thank you for any insight and opinions.
Stephens is offline
Old 03-11-2008, 06:21 AM   #2 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
The longer wheelbase gives you a much more comfortable ride over choppy concrete highways with expansion joints. Also, the pin can be mounted a little further in front of the rear axle with the long bed allowing fractionally more weight on the front axle. What size 5'er are you considering? The 7.3 is pretty reliable compared to the 6. A lot of 6s are showing up in the dealer lots right now as they are just coming off engine warranty. The early 6 will need some work even if they have low miles. Later 6s are pretty reliable if you kill the EGR and replace the head bolts with head studs.
haul_n_horses2 is offline
Old 03-11-2008, 04:18 PM   #3 (permalink)
Hensley Ron's Avatar
You didn't mention whether or not you already owned the fiver. If you're shopping for new, several manufacturers are designing them with improved clearance so that you can tow them with a short bed and no slider.
If you already have the fiver and it's the standard "square nose" design, my rule of thumb is: if you can avoid a slider, do it. Go with the long bed. The long bed will also give you more space. A short bed with a slider doesn't give you much cargo space.
Keep in mind, this is coming from a guy who sells sliders, but I tell this to all my customers. A fixed hitch is always the better option.
Ron Estrada
Hensley Mfg., Inc.
Home of the Hensley Arrow and TrailerSaver
800-410-6580
Hensley Ron is offline
Old 03-13-2008, 10:00 AM   #4 (permalink)
lincster's Avatar
My Photos: (22)
Long bed all the way!!!
Better ride, less bouncing.
Don't have to worry about hitting the cab, no matter what 5er you get.
You get the bigger fuel tank with a long bed.
I will only have crew cab, long bed duallys for towing in the future.
2006 F350 4X4 Dually, Tow Boss, Crew Cab, Lariat... man does this thing tow, Inyati Spray In Bedliner, Autometer Z Series Gauges towing a 2006 LE3905 Weekend Warrior
lincster is offline
Old 03-13-2008, 10:24 AM   #5 (permalink)
JimmyDee's Avatar
My Photos: (24)
I have a short bed and I've been towing with a short bed since 1999. My pin box sticks out about 12". It is not the really long one. I have a Reese slider which is a big help but I have only used it about 1/2 doz time in the 9 years I've been towing. I really don't think I would purchase a long bed unless I could find a reason I needed it.
Go either way and you should be fine. I have never hit the cab the one time I came close to it, I moved the slider. The slider cost me about $190 extra for the hitch and is there more for piece of mind than functionality.
Jim
2001, F250 4x4, CC, Auto; Mobil 1 in transfer case&Trans.; Frantz Bypass Filter; "Hutch" fuel mods; Sonnax/Tricum mod; 4" Exhaust, 30" MagnaFlow; Attitude in A-Pillar and tranny gauge in Dash; AIS; EASE Diagnostics; Reese Slider Hitch; Fr Rotors, Cryo Treated&Slotted by ART.
JimmyDee is online now
Old 03-13-2008, 09:58 PM   #6 (permalink)
Long bed 7.3L.
No worry about hitting the cab and better ride.
Ken
KE5DFR
2002 F-350 PSD CC Dually/ with 4.10 axle, and SCMT
Toting a 1979 Silver Streak, 28.5', Jordan 2020 controller and a Reese Dual Cam HP.
TXiceman is offline
Old 03-14-2008, 02:50 AM   #7 (permalink)
Long bed 7.3= better ride, handling, no clearance problems, reliability. A dually is more stable when towing.
02 F350 Lariat CrewCab Toreador Red/ Silver DRW AT 4X4 4.10 gears, BTS custom chip, and tranny. built BTS and Ford Tough! 752,243 miles
SOLD: 02 F350 Lariat CC Toreador Red, DRW AT 4.10 gears, BTS custom chip, and Tranny 214,550 miles,Built BTS, and Ford Tough!
Sold 94 XLT SC DI DRW 5Speed 314,000
04 Grand Marquis LS sure wish it had a BTS!
Lifetime Member "BTS BUBBA" Association
"Ain't no feelin like BTS mobilin"
SLAPS Member
62 Corvair 95 Bus
HighwayPrisoner is offline
Old 03-14-2008, 11:10 AM   #8 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Shorty has a smaller fuel tank, and a more "choppy" ride because of the shorter wheelbase. But is has a smaller turning radius, and it's 16" shorter overall, so it's better in tight quarters, and will fit in some garages where the long bed won't fit. The big difference is availability. Ford sells about 10 times as many CrewCab shorties as long beds, because of the Yuppie contingent buying SuperDuty pickups for use as commuter cars with weekend towing, so the long beds are hard to find.
Clearance issue is no problem now, because you can buy an automagic 5er hitch that eliminates that problem. It's called a PullRite SuperGlide hitch. Not cheap, but if you have a shorty pickup and need to tow a big trailer, it's worth it. PullRite has a SAFER, STRONGER, BETTER designed hitch for you
And the smaller fuel tank is no longer a problem. You can replace it with a 46-gallon tank that's even bigger than the standard long-bed tank. Ford pickup replacement tanks
So the best of both worlds is a CrewCab shorty with a SuperGlide hitch and a TransferFlow replacement fuel tank. Yeah, that costs you a few thousand bucks, but you're worth it. That doesn't fix the relatively more choppy ride, but you won't know what you're missing if you never drive a longbed.
I had a shorty and traded it for a long bed because of an extreme fear of driving into a dead-end trail with no place to turn around after a mile or so. Jacknifing a 5er on a shorty pickup without a slider hitch is no go without crunching the cab with the front of the trailer. And backing a 5er a mile or so down a crooked mountain trail is very hard work. And back then I'd never heard of the SuperGlide. So I now have a long bed. But I like the bigger fuel tank, and I don't mind the bigger turning radius. My 22.2' long pickup fits fine in my 24' garage stall.
SmokeyWren is offline
Old 03-14-2008, 03:49 PM   #9 (permalink)
jhamlin164's Avatar
Long Bed...........Just Do It!
The longer wheelbase really does make for a much more comfortable ride! The added storage space is always a plus for those of us who pull "Fivers". A fixed hitch just makes for less problems than their sliding hitch counterparts.
2006 F-350, King Ranch, 6.0L PSD CC, DRW, 4X4
Kenwood Head Unit / Navigation system
Audiovox LCD DVD player
Rancho RSX 9000 shocks
Line-X Bedliner
JL Audio ZR-570CSi speaker system
JL Audio StealthBox Sub
2 JL Audio Amps
2 Odyssey PC 1500DT batteries
Amsoil By-Pass system
Future Mods:
ARP Head Studs
Banks Powerpack System
Mag Hytec Tranny pan
Autometer Phantom II gauges
Gear Vendors Aux Tranny
http://i7.tinypic.com/4hu7q78.jpg
jhamlin164 is offline
Old 03-14-2008, 04:14 PM   #10 (permalink)
My Photos: (17)
Hmm. Maybe you Southern boys need to come up to Michigan. Just about all you can find are long beds. I wouldn't have a short one but my DRW make me park way out in the boonies anyway.
Old 03-14-2008, 08:06 PM   #11 (permalink)
Hook'em Horns!'s Avatar
I like it out in the boonies, Lots of room for diagonal parking across multiple spaces and a nice walk to stretch the legs!
2005 Chev Duramax/Allison 3500LS DRW Crew Cab
B&W 30K-Turnover GN, Putnam XDR 15K, A/T Revos
2006 Chev 6.0L/4L80e 3500WT DRW Ex-Cab 9'Flat-GN
A/T Revos
DON'T STEAL! The Government Hates Competition
Hook'em Horns! is offline
Old 03-14-2008, 08:41 PM   #12 (permalink)
SmokeyWren's Avatar
My Photos: (33)
Well, of course I was talking about SRW pickups. Dooleys are a different matter. Almost all DRWs are long beds. Ford does make the shorty Dooley, but they sell very few of them. Dealers don't stock them, so if you want a shorty Dooley you have to special-order it.
Old 03-22-2008, 02:14 PM   #13 (permalink)
CAMPINGTOM's Avatar
I have a crew cab short bed and a slider hitch. I will get a long bed next time. Dealing with the manual sliding hitch is a pain. Even though I have an extended pin box, I have to use the slider most of the time.
2005 F-250 6.0 King Ranch
1 Injector, 2 EGR valves, EGR cooler, Oil cooler, HPOP replaced
4" Cat Back MBRP with muffler delete.
CAMPINGTOM is offline
Old 03-22-2008, 03:13 PM   #14 (permalink)
MDarrough's Avatar
My Photos: (18)
My last two SDs were long beds, so I definitely wanted a shorty this time.
I have no problem towing the 5er. When I stop at the gate to enter the park, I slide the hitch back. When I stop on the way out to say bye, I slide it back up. No biggie.
I also make sure not to get myself in a position that I would have to turn sharp enough to hit the cab while on the way there and back. I tested it in an empty parking lot, and can get pretty tight with the hitch forward. I just made a mental note of how far I can go.
Granted the long bed IS better for towing a 5er, but I sure am enjoying the manuverablity when I'm not towing.
Mark
'08 F-350 CC 4X4 Lariat, SRW, Dark Blue Pearl w/Silver trim, every option but Nav and moonroof.
Ordered 10/16 - Born 11/14 - delivered 11/26
pic
Pulling a 2008 Jayco Eagle 5er - pic
SOLD - '01 F-350 - pic
MDarrough is offline
Old 03-23-2008, 09:14 AM   #15 (permalink)
96STROKE's Avatar
My Photos: (6)
Everyone has already posted the benifits of the long bed, better ride, bigger fuel tank, no need for a slider hitch, room for a tool box/aux fuel tank, ect... but I thought I post anyway.
For towing a 5th, I personally would not concider a short bed, but thats just me. Yes a long bed crew cab is long and some times a pain in a small parking lot, but for towing I think its the only option and worth parking out at the far end of the parking lot. In fact, I bought a $1000 car to drive that gets 40 mpg to do all my running around and drive to work every day to let the truck sit in the garage til I need to tow with it. It sits even more now that diesel is well over $4/gallon vs. $3.19 for gas.
Around here, I see half and half, long vs. short beds towing. It can be done easily enough with the right set up if thats what you want.
Good luck with your search
'01 F350 Lariat PSD 4X4 CC SWR LB auto
Superchip 60hp, 4" cat back, A-pillar w/auto meter gages, Firestone Air bags, Bilsteins, Radio Speed Volume Mod, XM Roady
Photos
96STROKE is offline
