Looking at a 40' 5th wheel, how is the 6.4 going to do? - Page 3 - Diesel Forum - TheDieselStop.com
Old 07-27-2009, 08:31 PM   #31 (permalink)
Originally Posted by djen223 View Post
I would also say i am under gcvwr. as the original poster was asking if he could pull a 40ft trailer. my truck gvwr is 11400 and the towing capacity for a 5thwheel applications is 15400. making 26800 your gross combined weight max. my fuzion gross is 16k and ive had it up to 15 which at the cat scales had my gross combined weight at 24,000 well within the safe zone. and as stated above your trailer brakes are what stops your big trailer. just like a set of big rig triples going down the road.
forgot to add that this setup does not exced my gvwr either.
15,400 towing assumes vehicle is running without payload. So it's more like 15,400 + 8500 = 23.9k
6.4 with 3.73s should be able to handle that weight, as others have said it's the rear axle and tires that cops will try and get you on. Stay within those, stick to a sensible speed and you'll be fine. I've pulled 13k (14.5k max per manuf specs) up 6% grades in 105 degree heat and had no complaint from my 3/4ton. Don't see why the 6.4 should be much different at handling similar weight while the F350 is meant for heavy towing. Use tow haul mode and get your integrated brake controller set up correctly and you'll be fine.
Carl Lassiter is offline
Old 07-27-2009, 08:53 PM   #32 (permalink)
SmokeyWren's Avatar
My Photos: (44)
No.
You're mixing your apples and your oranges.
Your Ford towing capacity is a made-up number that is supposed to be the GCWR of your truck minus the wet and loaded weight of your truck before you tie onto the trailer.
The GCWR of your truck is 23,000 pounds. If you subtract your so-called towing capacity from 23,000 that leaves only 7,600 pounds for the weight of your wet and loaded truck. And your wet and loaded truck, including driver, passengers, toolbox crammed with tools and fluids, 5er hitch installed, and anything else in the truck such as pets, coolers, a floor Jack that I always haul when I'm towing, will weight a lot more than 7,600 pounds. For a CrewCab 4x4 diesel longbed with a spray-in bedliner and normal tools and extra fluids in the toolbox, 8,600 is a lot more realistic number.
Ford gave you the gross combined weight max as 23,000 pounds. Why do you think you can flash some numbers around and somehow wind up with more than 23,000 pounds?
... at the cat scales had my gross combined weight at 24,000 well within the safe zone.
Safe zone? Says who? Ford says the max GCW is 23,000 for max safe combined weight. So the "safe zone" is anything less than 23,000.
I hope you're right. What does the CAT scale say when the truck and trailer are both loaded for bear, with a full tank of diesel and driver and all passengers and tools and other stuff in the truck?
SmokeyWren is online now
Old 07-28-2009, 09:58 AM   #33 (permalink)
djen223's Avatar
My Photos: (5)
here is my cat ticket. im on the gnats behind on the truck gwr if im reading it right. my gwr is 11400 on the door. as far as towing capacity it sure is misleading on the ford guide to what you can tow compared to what your saying. and i have 4.3 ring gear.
loaded for bear, is me and my wife ,my 3 kids are grown and gone, the tools are in the garage of the trailer.
cheers Dave
__________________________________________________
2008 f350xlt extcab long bed 6.4 / 4.30 ring gear
2008 fuzion 362 toyhauler
97-f250 4x4 xtcab,410,BTS-e4od,/wopstage1's/285-75-16. 4" lift,bully dog downpipe,gutted ebpv,4" exh.,165,000miles,born 11/97,,ts 6pos chip.
djen223 is offline
Old 07-28-2009, 08:45 PM   #34 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Hold it! Waitaminute!
I missed it before now, but if you have a 4.30 ring gear and pinion in a 6.4 SRW, then you don't have the original ring gear that came in your truck.
2008 SuperCab long bed 6.4L 4x4 SRW has a GVWR of 11,400, but 3.55 or 3.73 gears were standard or optional during the 2008 model year. There was no option for 4.30 gears in the diesel-powered SRW.
4.30 gears were optional in the DRW as part of the TowBoss pkg. But the GVWR was 13,000, not 11,400, and the GCWR was 26,000, not 23,000. Assuming stock-size tires. You do have stock-size tires, right?
Old 07-28-2009, 11:12 PM   #35 (permalink)
djen223's Avatar
My Photos: (5)
that is correct, I had 4wheel parts warehouse install 4.3 gears, my truck came stock with 3.55's which are hanging on the wall in my garage, i am running stock continental tires of 275/70/18. I bought the truck before i bought the trailer. before I ran a 25 ft 5th wheel with a trailer behind it, I am more comfortable with the toy hauler but agree now that my weights are border line and a dually would be a better choice.
cheers Dave
djen223 is offline
Old 07-28-2009, 11:52 PM   #36 (permalink)
11,400#'s should be a short box truck, not a long box though.
jasonmt is offline
Old 07-29-2009, 08:28 AM   #37 (permalink)
djen223's Avatar
My Photos: (5)
my long box says 11400 on the door.
cheers Dave
djen223 is offline
Old 07-29-2009, 08:51 AM   #38 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Per the 2008 brochure, the F-350 SRW SuperCab shorty has a GVWR of 11,200. The long bed has 11,400. They both have about the same payload because the shorty weighs about 200 pounds less than the real truck.
Old 07-29-2009, 10:29 AM   #39 (permalink)
My Photos: (6)
Question
I'm confused Mr. SmokeyWren, guru of truck numbers...... did you get those backwards?
fordson1 is offline
Old 07-29-2009, 10:55 AM   #40 (permalink)
RatherBNtheWoods's Avatar
No.
The long bed weighs 200 lbs more so it's GVW is 200 lbs more...11200 -11400.
Makes the payload the same.
Our Raptor RV
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear, Built May05. 4" turbo back, 55 gal aux fuel tank. A real pig from a stop, give me 15' and she'll slowly come to life, then watch out!
165K miles, 12 injectors, EGR cooler, Fuel pump, 8 glow plugs, GPCM, FICM rebuilt FoMoCo engine at 150K under 7/200 warranty.
RatherBNtheWoods is offline
Old 07-29-2009, 04:34 PM   #41 (permalink)
I was thinking Crewcab and not Reading Supercab...
jasonmt is offline
Old 12-17-2009, 04:13 PM   #42 (permalink)
gentlemen, I am new to the forum but I would like to set some questions straight that you have brought up, I own a 2009 keystone raptor 3812TS. it was shipped from the factory and the weight was 13,086, dry. i had the unit scaled with 3 harley davidson street glides, full tank of fuel and 936 pounds of cargo. full propane, batteries, and no fresh water or waste water. The trailer Weighs 16,001#. Now I dont know what state your'e in BUT, I am a F.M.C.A inspector. I own a Dodge ram 3500 quad cab dually deisel, the max tow rating on a fifth wheel is 16,000# the truck is maxed out on weight but it is not illiegal, I had to combo rate the truck to class 8= 26,000#. the toungue weight of my raptor is 2800#. not anywhere near the payload capacity of the truck. ANY 350, 3500 1 ton truck is plenty of tow vehicle for the job up to 16,000#. a 2007 ford F-350 has a GVWR of up to 13,000#. a Dodge ram 3500 has a GVWR of 12,200# a Chevy 3500 has a GVWR of 13,000#.
Raptorman3812TS is offline
Old 12-17-2009, 05:21 PM   #43 (permalink)
SmokeyWren's Avatar
My Photos: (44)
So which question did you set straight?
"Tow rating" is almost meaningless. It is a guide, and assumes the tow vehicle will be buck naked except for a skinny driver. But nobody tows with a naked truck, and most drivers are not skinny. For the cop on the beat, the term "overloaded" should be either the GCWR or the GVWR was exceeded. On an F-350 DRW, there is plenty of GVWR, so the limiter is the GCWR. If the GCWR is 23,500 pounds but your wet and loaded rig grosses 26,000, then you're overloaded.
But state law overrides common sense, and some states allow drivers, especially commercial drivers, to buy excess weight capacity. So if your state sells you a cheat sheet that allows 26,000 gross weight when the manufacturer's GCWR is 23,500, then you're still overloaded, but not illegal.
Old 12-17-2009, 08:15 PM   #44 (permalink)
SmokeyWren: Ditto.
I don’t want to sound like the Canadian weight police, just some information so folks won’t buy not enough truck or too much trailer. I got bit by this after I bought my truck. My F350 SRW has a GVWR of 11,400 pounds, which means on the scale my truck can’t weigh more then 11,400 pounds loaded (Which includes pin or hitch weight!). And a GCWR of 23,000 pounds, which means my trailer and truck on the scale can’t weigh more then 23,000 pounds. Here is where I got bit, in Ontario, Canada a vehicle over the gross weight of 6,600 pounds has to be registered with a GVWR, you can’t register over the door sticker GVWR, but you can register at a lower GVWR weight (below 10,000 pounds) for a cheaper yearly fee and you get away without having to get an annual inspection and keeping a log book. When I ordered my truck I knew my trailer weight was over a F250’s capacity so for $700 more I ordered a F350 SRW, It wasn’t till I had to renew my trucks registration three months later, that I found out that the dealer only registered it under 10,000 pound to pay less and didn’t even pay for a year. What’s also funny is that the people I know with F250’s don’t have to registered weight and I’m sure that their truck weighs over 6,600 pounds?
The Original Poster was talking about a F350 SRW. My truck has a GVWR of 11,400 (a 1,000+ over a F250), the pin weight of my 12,000 pound trailer is 2,700 pounds, my truck weighs 8,880 loaded without the trailer, so 11,400 - 2,700 - 8,880 = -180 pounds, this means I had to pack different to take 180 pounds off my pin weight. As for the GCWR, my trailer and truck together weigh 20,240 pounds, so I’m 2,760 pounds under the GCWR. The Ford Tow Guide states that a 5th wheel trailer can’t weigh more then 15,200 pounds. The Ford Superduty probably weighs a 1,000 pound more then any truck brand in its class, they are heavy trucks that take away from the trucks load capacity.
-2008 F-350 CC 4X4 Lariat, SRW, 3.73.
Any color, as long as it's "Black".
Ordered 12/31 - Born 02/11 - Picked up 03/29.
-1972 First Ford - 1956 Fairlane - Mint
Rolled it at 100+mph (Teenager, Duh, no one hurt)
Totaled Oct/73 (Over 35 Years ago and still remember that lesson).
-First New Ford - 79 Bronco - Ordered Mar/79
150K Miles - I disassembled 2000 and I sent it to three different scrap yards.
-1982 - My Sister married a GM Sales Manager (He Retired 2007, "Hello" Ford Super Duty, enough said, LOL).
-2003 - ZRX1200 (Some say "Mid Life", LOL).
-2008 - Jayco 313RKS 5th (The kids won't move out of the house).
MPD56 is offline
Old 12-17-2009, 08:25 PM   #45 (permalink)
40' trailer with a SRW truck. No way. DRW bud.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 2.5" axle drop bracket, F350 springs up front, and F350 rear axle blocks. 260k miles. RETIRED.
NEW (to me) 2005 F350 FX4 Crewcab shortbed, SRW, Lariat, auto, V10. 5600 lbs front end.
NickKent is offline
