Closed Thread
Old 01-08-2008, 06:28 PM   #1 (permalink)
Looking for some HEAVY DUTY tires and wheels
I'm looking for the highest weight rated tires and wheels I can find to fit my truck. I currently have a set of Toyo 295/70R17s on Allied wheels. The tires have enough load capability... at 3970 lbs. But the wheels are only rated at 3420 lbs. My truck when fully loaded with camper and snowmobile trailer is about 7900 on the rear axle. I looked at the 19.5" kits from Rickson but they can't make any aluminum wheels for 4-6 months due to a problem with their aluminum supplier. So I'm looking for other alternatives. I'd like to have tires/wheels rated for 4500 lbs or so if possible. Prefer a polished aluminum round or oval hole wheel.
Thoughts and advice are appreciated. (Not looking for a lecture about being over the axle rating).
thanks
2002 F350 XLT Supercab 8' Bed, Single Rear Wheel, 6 Speed Trans, Firestone Ride Rites, Superhitch, Tork Lift Camper Tie-Downs, Custom Built Aluminum Headache Rack, Pro-Tech Tool Box, 295/70R17 Toyos on Allieds, Bilsteins, Tuff Country 3.5" Kit, Gauges, Banks PowerPack, AFE intake w/ ProGuard 7
Wiley75 is offline
Old 01-08-2008, 06:45 PM   #2 (permalink)
Believer45's Avatar
My Photos: (17)
Re: Looking for some HEAVY DUTY tires and wheels
How much lift do you have? If you can fit the tires under your truck you can get the adapters to put 8- or 10- hole semi-truck wheels on and use lo profile semi truck tires.
<span style="color: green">CLICK HERE </span> and scroll down a bit to the adapters.
<span style="color: blue">CLICK HERE </span> to see specs on a Goodyear G124. In 245/75R22.5 it is 37.3" tall with a weight rating of 4410 lbs per tire single.
If you can fit a tire 40.8" tall you can use something like the <span style="color: red">G362 DRIVE </span>. They are rated for 6175 lbs per tire single.
Any semi-truck wheels you get will be rated accordingly and be stronger than you need.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed manual, two wheel drive, 3.55 gears, LUK clutch conversion, 450 lb homemade REAR BUMPER, homemade open element AIR FILTER, aluminum bed cap. With me in the cab (285#) and full of fuel weighs 6,580 lbs (steer 3420 drive 3160)
Believer45 is offline
Old 01-08-2008, 07:48 PM   #3 (permalink)
Albin's Avatar
My Photos: (24)
http://www.ricksontruck.com/
'06 F-350 SRW 6.0 PSD
Albin is online now
Old 01-08-2008, 08:24 PM   #4 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Believer45</div><div class="ubbcode-body">How much lift do you have? If you can fit the tires under your truck you can get the adapters to put 8- or 10- hole semi-truck wheels on and use lo profile semi truck tires.
Dave / Believer45 </div></div>
I've only got a 3.5" level kit. I don't want to go much taller than 33.5" or 34" so it doesn't rub and more importantly so I can stop when I hit the brakes! thanks
Wiley75 is offline
Old 01-08-2008, 08:25 PM   #5 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Albin</div><div class="ubbcode-body">http://www.ricksontruck.com/ </div></div>
Yeah, they can't make aluminum wheels for 4-6 months due to a supplier problem. That's the news as of today. They have powder coated steel ones but those look dumb in my opinion.
thanks
Wiley75 is offline
Old 01-08-2008, 08:43 PM   #6 (permalink)
88beast's Avatar
try to consider a smaller sized semi trailer tire you could look at a semi sized moving van trailer
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
http://youtube.com/watch?v=ILAQuHNAGE0
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
88beast is online now
Old 01-08-2008, 08:55 PM   #7 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Wiley75</div><div class="ubbcode-body">I'm looking for the highest weight rated tires and wheels I can find to fit my truck. I currently have a set of Toyo 295/70R17s on Allied wheels. The tires have enough load capability... at 3970 lbs. But the wheels are only rated at 3420 lbs. My truck when fully loaded with camper and snowmobile trailer is about 7900 on the rear axle. I looked at the 19.5" kits from Rickson but they can't make any aluminum wheels for 4-6 months due to a problem with their aluminum supplier. So I'm looking for other alternatives. I'd like to have tires/wheels rated for 4500 lbs or so if possible. Prefer a polished aluminum round or oval hole wheel.
thanks </div></div>Get a dually?
haul_n_horses2 is offline
Old 01-08-2008, 09:22 PM   #8 (permalink)
u2slow's Avatar
My Photos: (16)
How about the Vision 81's? Even Les Schwab carries them.
I found my 245/70R19.5s (Triangle TR689A traction) in a 4805# rating.
I would have preferred the steel wheels, but the 1+ month wait and higher price turned my off.
95 F350 Crew 5spd/4.10, SuperChips tuner, solid flywheel, T444E waterpump, 205° stat, Locked F&R, 9.00R16 Michelin XLs
97 E350 SRW cutaway, E4OD/D70/4.10, 19.5s on the rear, deep trans pan, batteries inside, 1800W inverter, manual glowplugs
84 C30 Suburban, 6.2/4-spd, 3.21s
Other rigs I goof around with regularly:
93 F350 4x4, 7.3 IDI turbo, 5spd, 4.10s
90 F250 4x4, 7.3 IDI, 5spd, 3.55s
, D60 swap, straight pipe, turned up fuel screw
u2slow is offline
Old 01-14-2008, 05:19 PM   #9 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">Get a dually? </div></div>
That's what I did yesterday. 08 Dodge 4x4 Cummins. Can't believe I'm joining the dark side and buying a Dodge! Yuck! It was $15K cheaper than a "comparable" 08 F350 Dually, invoice to invoice. Oh well, I'm still a Ford fan at heart. I wore my Ford Racing shirt to the Dodge dealer when I bought it. Ha ha
Wiley75 is offline
Old 01-16-2008, 08:02 AM   #10 (permalink)
I love my Ford, but I sure don't blame you. I would drive the heck out of a Dodge dually with a Cummins.
2004 F-350 Lariat SRW <><
315 BFGs, Edge Platinum, ARP Studs, & B&W Goose
1998 Cherokee RockCrawler
NCfarmboy is offline
Old 01-16-2008, 03:58 PM   #11 (permalink)
u2slow's Avatar
My Photos: (16)
You needed stronger tires so you replaced the truck?!
u2slow is offline
Old 01-16-2008, 04:59 PM   #12 (permalink)
My Photos: (17)
He needed a higher GVWR and new that stronger tires was not the solution. As for the OP, with a large camper in the bed the dually will have much more stability as well as increased GVWR.
Old 01-16-2008, 09:52 PM   #13 (permalink)
Enjoy the new truck .
When I bought I looked at Ford, GM & Dodge. At that time I paid about $8K less than a comparable Ford or GM. There are some things I prefer with Ford (locking hubs, nicer rear seats) but I don't like them $8K worth .
So far (12K miles) the Cummins and G56 6 speed have performed flawlessly.
'06 Ram 3500 4X4 QC CTD 6sp LB
'01 F350 PSD 4X4 6sp Crew Cab (sold)
'68 F250 C/S 4X2 C6/428PI
Stidham 24' enclosed car hauler
Bunch of big old cars
In theory, practice and theory are the same.
In practice, they are not.
Packard8 is offline
Old 01-16-2008, 11:58 PM   #14 (permalink)
Believer45's Avatar
My Photos: (17)
This one has run its course.
Locked before it becomes a brand war.
Dave / Believer45
Closed Thread
