Whats the difference of pulling a 5ver over a bumper pull?
A bunch. With ordinary hitches, 5ers pull great with no sway, while TTs can kill you and yours because of sway.
The fix is to pay the big bucks for the right hitch for the TT. Then it will tow as good as a 5er and no sway.
5ers cost more than comparable TTs if you don't include the cost of the hitch. But a Hensley Arrow hitch for a TT costs about $2k more than a good 4-way-tilt 5er hitch, such as the Reese 16k Classic. So usually a 5er with good hitch will cost about the same as a TT with a Hensley Arrow hitch, or maybe a bit more.
Personally, I prefer my 5er. I would consider a TT only if I could hook it up with a Hensley Arrow hitch.
www.nosway.com
My price range is less than 12,000.
So a new 5er is a budget buster. And even a new TT is probably not available - including athe Hensley Arrow hitch - for that price.
So you're looking at a used TT plus a Hensley Arrow hitch for 12k. That's possible, but you'll probably spend a lot of time shoping to find a good clean unit that meets your needs at that price.
From what you see in my signature what would be a good matchup as far as length or lbs?
Your biggest problem is the low GVWR of your pickup.
Figure a 5er as having 17 percent of it's GVWR as hitch weight. Figure a TT at 11 percent. So a trailer with a GVWR of 10,000 pounds will have a hitch weight of around 1,700 pounds if it's a 5er, or 1,100 pounds if it's a TT. Both trailers will probably cause you to exceed the GVWR of the tow vehicle, but the 5er would be 600 pounds worse.
Your GVWR is 8,800 pounds, and your GCWR is 20,000 pounds.
Load the truck up with a typical camping trip worth of buddies and coolers full of cool and a bed full of campfire wood, etc., and go to a certified automated truck (CAT) scale. Fill up with diesel, then weigh the wet and loaded truck - with driver and passengers in the truck. Subtract that weight from 20,000 pounds and that's the maximum GVWR of any trailer you should look at.
For example, if your wet and loaded truck weighs 9,000 pounds, then you should look at TTs with a GVWR of 10,000 to 11,000 pounds, or less. That's a nice "lite" TT about 28 feet long with one slide, or maybe 30 feet long with no slide.
But if your wet and loaded truck grosses 9,000 pounds, and you have an additional 1,100 pounds of hitch weight from the TT, then your GVW will be 10,100 pounds, or 1,300 pounds overloaded. So yes, you'll need the Firestone RideRite airbags. Or a better plan might be to take a second vehicle to haul all the folks and firewood and coolers full of cool, and let the PSD with only a skinny driver tow TT. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img] That way your tow vehicle will probably barely be overloaded.
