Old 03-06-2007, 11:15 AM   #1 (permalink)
Max towing RPM's
Hello all,
I just purchased a 5th wheel camper and am about to start towing. What is the maximum safe RPMs to run on a 7.3 IDI going up steep grades? What RPM do most of you run up hills? I have a ZF-5 with 4.10 gears and an ATS turbo.
1989 F350 crew cab 4X4, rebuilt 7.3, ATS turbo w/wastegate, ZF-5, 4.10 gears.
93idi is offline
Old 03-06-2007, 12:07 PM   #2 (permalink)
Re: Max towing RPM's
You wont hurt the engine as long as the EGT's stay in check(I see you put a turbo on it). Actually you can floor board that engine and it will run all day long no problem. The trans will suffer before the engine. To directly answer your question. Your engine has a govenor on it, the gov will kick in before RPM's get too high.
Just eating rainbows and butterflies
01 F350 dually 4x4 CC auto.
311 hp 610 torque a while back.
My Pickup
Some Photos and Sound Clips
Diesel Power & Performance Derby Ks.
#46
Kanman is offline
Old 03-06-2007, 02:41 PM   #3 (permalink)
My Photos: (13)
Keep the tach out of the red and you should be good.
Ag__Teacher is offline
Old 03-07-2007, 10:22 AM   #4 (permalink)
Like Kanman said, the engines are governed and you can run up against the governor all day long.
Just make sure that the turbo is spooled up good before hitting the grade, if you tend to lose a lot of speed you should downshift to 4th BEFORE you hit the grade.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 03-07-2007, 11:14 AM   #5 (permalink)
Does anyone know what the governed speed is? Also is there a "sweet spot" that would be optimal to run?
93idi is offline
Old 03-07-2007, 11:46 AM   #6 (permalink)
Every truck that I've driven has had a slightly different sweet spot. You'll more than likely have to figure out your truck's sweet spot on your own with time behind the wheel.
2005 Arizona Beige F350 XLT FX4 6.0 CC shortbed, 3.73 ls rear, 18" wheels, Tow Command. Additions: Vent Visors, bug guard, Fumoto Valve, Timbrens. Traded for...
Current Truck -- 2008 Black F350 XLT 4x4, 6.8 V10, CC Long Bed, 4.10 rear, 18" wheels, IBC. Additions: Chrome Step Bars, Chrome door handles, Silver barbed-wire pin stripe, B&W Turnover GN ball
barrelhorses is offline
Old 03-08-2007, 12:26 AM   #7 (permalink)
My Photos: (17)
Even though my truck has the E4OD, the 7.3 will turn 3000 rpm all day and pull to redline. The coolant temps like it better also, as long as the fan clutch and rad are in good condition. As soon as I let it drop below 2600rpm the coolant temps rise FAST. Watch the pyro temps and shift as necessary to keep the rpm/pyro/coolant temps balanced. Listen for the fan clutch to come on, even at 3000rpm, you will be able to hear it. If not, point truck back down hill and get it replaced($149.00 [img]/ubbthreads/images/graemlins/eek.gif[/img])!!! [img]/ubbthreads/images/graemlins/smokin.gif[/img]OkieGringo
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 03-11-2007, 11:08 AM   #8 (permalink)
Like others have said, you can run the RPM's up as fast as they will turn because the engine is governed by the computer module. My experience is that, with my foot pressed hard against the firewall, I rarely get above 2900 RPM on any hill/mountain, because the shift points for my truck (4:10 rear end) are such that when the truck downshifts, the new RPM point is just under 3,000 RPM. Even in the very few times I've had to punch it hard to get on an expressway, the engine shifts just before 3,000 RPM.
The DANGER comes from using the transmission lever to downshift when coming down a hill/mountain and over-spinning the engine. You can get the RPM's way up above redline that way and damage the engine.... according to the manual. I've never known anyone that had damaged an engine that way, but I'm sure some have done so.
As an aside, I drove a new 2005 6.0Liter Ford and it spun up over 4,000 RPM getting on the expressway. But the RPM's on the 6.0 is still governed by the computer module.
Florida Ed
2001 7.3 F-350 Dually Lariat CC LWB 4X2 Dark Green 4.10 4R100 5'ver Hauler (32' Montana 2 slides 10,500# - 2,000# tongue weight), 106 gal aux tank, 112K miles, nephews arguing over who will inherit it 'cause I'm gonna' drive it 'til I die. Bone stock.
2001 5.4 Gasser F-250 XLT Crewcab SWB 4X2 3.73 4R100 67K miles headed to 150K (wife's vehicle on the "junk-iron" theory of vehicle safety....most junk iron wins in a crash) stock as the day it was made
Before these: '00 F-250 CC PSD, '97 F-250 CC PSD, '94 Ford F-150, '91 Ford E-250, '81 Ford E-150, '66 Ford F-100 (cars not included)
FloridaEd is offline
