I built a shop that is 12x16 with 8 foot walls and a total height of about 12 feet to the ridge at my old house, on floor joists so It could be moved. I want to move it my new house, Which is about 30 miles away, with major highway all but maybe the last 1/2 mile. I live in Wilmington NC Any one know what I need to do to tow this thing over here? thanks!
John
I would vote for having it done. Overwidth and (possibly)overheight permits will be needed as well as expertise in moving a building. At 12 feet wide you may need escort car or cars as well. When you get it on a tralier (unless you have a low trailer) you will be over 13'6" tall.
Dave / Believer45
__________________ THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
'95 F250 ext cab long bed, PSD, 5 speed manual, two wheel drive, 3.55 gears, LUK clutch conversion, 450 lb homemade REAR BUMPER, homemade open element AIR FILTER, aluminum bed cap. With me in the cab (285#) and full of fuel weighs 6,580 lbs (steer 3420 drive 3160)
Jack it up.
Put some wheels under it.
Put some kind of draw bar on it.
Get permit.
Go.
Now... If you don't know what you are doing, get some professional help. It really isn't much of a job *IF* you can keep it below 13'6" high. Unless the overhang makes you over 12'wide in N.C. you won't need escorts. One would probably be a good idea though IF you do it yourself.
97 F250 SC LB 4X4 PSD TDE0, E4OD,3.55's, 285/70/16"s ,Modified fuel tank vents, 375+k headed for 500k
The first thing I would do is call the DOT and ask what are the permit requirments and what roads you will need to travel on and the travel times you are allowed to move it. Besure to ask about moving at 3am on Sundays as that would be your lowest traffic time. Most of the time it's sun up to sun down and 10am to 2pm in major citys.
I would then go drive that route to see what it would be like at 30mph and with one side of the building hugging the center white line as some roadways are only 14ft of pavement.
If that all looks good then I agree, buy some used MH axles and make a small sub frame to attach to the building so your under 13ft-6". Don't forget to temperory cross brace the inside of the building before moving.
AZ didn't require pilot car for my load but if I was going to use my single pilot car, Co required a single pilot car, then I needed two pilot cars in AZ as two pilots cars was the minimum AZ requirment at that time for the roadway AZDOT wanted me to use.
Also you will need 13ft wide mirrors for a 12ft wide load. A piece of 1-1/2" thinwall square tube steel works good for the temp bracket. Mirrors doesn't count in considering overall load width.
T_Bone
02 F350, 4X6, Crew, DRW, LWB, PSD, 6spd, 3:73, Island Blue, Stock, AEB2, Phoenix Az
Buy UNION work UNION. It pays off in the long run Define Union: A labor Union is nothing more than united workers with a common goal for better working conditions.
We all are in some sort of labor Union, some are just larger than others with better working conditions!
Permit at North Carolina Dept. of Trans.
Div. of Highways, Permit Unit.
1425 Rock Quarry Rd.m Suite 109-110
Raleigh, N.C. 27610
Phone919)733-7154 Fax: (919)733-7828 or 7921
1-800-574-6683
Mon. - Fri. 8 to 5 EST.
You will be able to run Sunrise to sunset Mon. - Fri. Call & get a provision sheet from them. It will tell you what you have to do in order to move it.
that is awsome! where did you find it at? I tried searching the web, but I never take the time to use the phone book. then again, I have never needed info like this. I know a guy who moves mobile homes, so maybe I will give him a visit. Thanks for the help.!
