Old 05-23-2006, 08:33 AM   #1 (permalink)
This May Be A DUMB Towing Question
I have a 12'X 6' BRI-MAR dual axle dump trailer that has a 10,000 lbs. GTW. Last Spring I hauled 6,000 lbs. of stone from WV back to MD for a total 9,335 lbs. GTW. The whole return trip the trailer was jerking the truck every time it went over a bump. It would only happen when the trailer bounced as a result of hitting a bump. No bumps and it was smooth. So I bought a Schuck cushioned tralier hitch, thinking that would cure the problem. Well, 2 weeks ago I hauled 3 loads of stone for my Son and I still have the jerking although not a bad with the cushioned hitch. I did not exceed the GTW at any time. I load with the majority of the weight over the trailer axles and forward for tongue weight so the tail does not wag the dog. I know this constant jerking has to be hard on the drivetrain. Is there something I'm missing here? Do I need to load the trailer a different way? Any suggestions would be appreciated.
DSMMH
2004 EXCURSION LIMITED, Mineral Gray, 4X4, 6.0L PSD, The Works Except Tube Boards, JUICE w/Attitude Updated, MBRP 4" Turbo Back Exhaust with Test Pipe, PML Tranny Pan, JOBE Air Intake, ZOODAD Mod, "6.0L PSD Juiced" Custom Hood and Rear Door Badges, Hawk LTS Brake Pads, Royal Purple Synthetic Fluids, Bilstien Shocks, Tekonsha Prodigy Brake Controller, Commando Remote Starter/Alarm, OPTIMA Red Top Batteries, Rear Spoiler and 30MM Rear Sway Bar Upgrade.
BUBLHED is offline
Old 05-23-2006, 09:15 AM   #2 (permalink)
Re: This May Be A DUMB Towing Question
Take a look at the suspension on the trailer. I have a feeling that is where your trouble lies.
Paul B
2001 Excursion Limited PSD,2wd,Auto. Toreador Red,10/2000,4.5 Racor,unTAGed,203*,DP-Tuner,AIS Filter,Riley Coolant Filter,6.0 cooler,Cat ELC,Son/Tri,Underdash Lunar Gauges,Hadley Air Horn,On Board Air,Fumoto,2006 31' Flagstaff TT 6.5K,Prodigy
2000 Honda CRV EX
PIC'S
pabrannan is offline
Old 05-23-2006, 09:42 AM   #3 (permalink)
My Photos: (27)
I'd experiment around with that theory. I get the same thing, but not as bad as yours, with my gooseneck travel trailer. On the other hand, when I pull my gooseneck horse trailer, or flatbed, they pull so smooth I don't know they're back there. IMO wheel bases, weight distribution, etc, all enter into it and some combinations are worse than others.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 05-23-2006, 09:52 AM   #4 (permalink)
sounds like maybe to much tongue weight.. when u hit a bump its lets the hitch come up so much that when it comes back down it pulls the hitch down and compresses the suspension making it bounce back up giving u that jerking bouncing.
2001 F350 SuperCrew Long Bed Dually.
7.3L turbo Diesel, automatic transmission, goose neck hitch, fifth wheel hitch, stainless steel back rack, 315/75-16 BFG A/T's, AUX back up lights, euro-lite driving lights, upgraded fog lights, dp-tuner, auto-meter ultra-lites, 5in stacks no muffler, whelen towmans light bar, DIY tymar intake, DIY coolant filter, 2M ham rig, DIY AIC,
( egauges )
My truck pic's
cdacaraudio is offline
Old 05-23-2006, 03:52 PM   #5 (permalink)
I'm thinking you might be right about tongue weight. I pulled this trailer with my old 95 K2500 Suburban 6.5L TD and it did OK except I did not pull the weight I did with the X. With the Suburban I only had about 6,000 to 8,000 lbs GTW because it worked way too hard with around 10,000 lbs. When I hauled the stone I did notice more sag at the trailer hitch then normal. I'll pay more attention to the tongue weight and see what happens.
Thanks to all for the info!
DSMMH
BUBLHED is offline
Old 05-25-2006, 09:26 AM   #6 (permalink)
KML
I agree, check the tongue weight first. It can cause many of those issues,
2001 F250 CC, Lariat 4x4, exhaust, chip, PS2K propane, Line-x, etc.
KML is offline
Old 06-01-2006, 04:30 PM   #7 (permalink)
I have a 38 ft flat bed that I haul my tractor and equipment on. I know if that I don't get that tractor just right over the axles instead of a little more forward it will jerk a crick in your neck. Like stated above, I think you have too much tongue weight.
03 F250 SD PSD Lariat 7.3, FX4 Crew Cab Short Box, 3.73 Gears, Auto Tranny, Jody Tipton 80 HP Econo Tune, Turbo Back 4" Exhaust W/5" Tip, Home Made Tymar, Isspro Gauges, T/C Lock Up Switch, 203 Degree Thermostat, Coolant Filter, Upgraded Headlight Wiring Harness, Diode Mod for Dims, Bilstein Shocks, Kenwood Head Unit, Sirius Radio, Valentine 1
Down South is offline
