Old 12-26-2005, 12:50 PM   #1 (permalink)
My Photos: (5)
Is this mileage typical for towing?
I have a 4,000lb dump trailer, cargo only weighed 1,000 lbs, so 5,000 total. All around town mileage is 13mpg. this was with the 33 inch tires. My usual around town is 15.5 with the 33s. When i filled the 6x12 dump with wood, i got 12mpg. What do you think? WILL a chip from JODY really help towing mileage? The truck is in the sig. Thanks
2002 F-250, PSD 6-speed, CC, short bed, 4X4, Toreador Red w/ Silver accent, A.R.E mx cap, Weld Super Single II and 33s in the summer, x-springs, F-350 blocks and badges, AIC, proflaps, ITP intank mod, AirDog with 3 micron filter, isspro guages and TTM, husky liners, alarm, xm stereo,stull 5399-p grille, centramatics, ccv mod, AIS Air Filter, Southbend CON O, Detroit Truetrac LSD, coolant filter, 203 stat with billet housing, blackcloud intake heater plug/boost fitting, reese titan hitch, fabcraft PTO cover/temp sender port, prodigy brake controller, ITP Boost Annihalator, oilguard bypass filter, Mag-Hytec rear dif, bilsteins, hellwig rear stabilizer bar, DP Tuner F5 - no start, stock, 40t, 60t, 80e and 80t, ATS housing, non-ebpv pedistal and exhaust flange, magnaflow 3.5dp exhaust, ITP reg return, turbomaster wastegate controller, and ceramic coated bellowed up pipes, currently 80,100 miles. truck Pictures
clydesdale is offline
Old 12-26-2005, 05:54 PM   #2 (permalink)
overfly's Avatar
My Photos: (16)
Re: Is this mileage typical for towing?
I'd like to get that kind of mileage. I tow an 8k lb. travel trailer and only get between 9 - 10 mpg on the freeway. I think a lot of that is the fact that it's 11' tall and completely flat in front, so it's like towing a wall with the wind blowing against it...
2006 F350 - Amarillo Package,loaded with all the toys, 4" MBRP cat back exhaust, Autometer EGT gauge, Viper 791XV auto start/cool down timer/alarm, Pioneer AVIC-D3 navigation/XM Radio/Sirius, 2.5" Tuff Country Leveling kit, KC Hilights front & rear, Dieselsite.com coolant filter, SkyJacker dual steering stabilizer, Firestone Ride Rite airbags w/onboard compressor, Kleinn Train Horns, Bilsteins all the way around, Recon LED's in the back, Programmed with the SuperChips 1805 Tuner always set on Tow Safe for a little extra get up and go.
30' Cardinal 30TS 5th wheel. The weekend home away from home.
"The early bird may get the worm, but the second mouse gets the cheese."
overfly is offline
Old 12-26-2005, 09:42 PM   #3 (permalink)
thats about what i get pulling our dump trailer full of logs for fire wood.......... id same that mileage is pretty darn good for intown...... I only get like 13 towing that load on the highway..... But thats with winter fuel, i don't know if you got winter fuel or not i didn't look at where your from.
2003 F-250 ext cab 7.3 Powerstroke
Sport Package
Stock for now [img]/ubbthreads/images/graemlins/wink.gif[/img]
Derag2 is offline
Old 12-27-2005, 05:08 PM   #4 (permalink)
NCHornet's Avatar
sounds good to me. I tow a 8500lb travel trailer and get between 9-10mpg, although as said above it is like pushing a wall thru the air. Yours sounds about right. I am sure the 40 tow or 80 econo tune will help a little if you can keep your foot out of it. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Kevin L. Mnt Airy, NC.
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
White Stroker
NCHornet is offline
Old 12-29-2005, 11:19 AM   #5 (permalink)
Sounds about right to me. I get about 13 towing my boat. I just finished a 1800 mile round trip with my fifth wheel, which weighs in about 11,000 pounds. I figured up my mileage to be around 10mpg.
2005 250 SRW, 6.0, FX4, SB, Lariat, 3.73, 60 gallon tool box/fuel tank combo, ride-rite air helper springs w/compressor and 1/2 gallon tank, Fumoto valve, MBRP 4" Single Exhaust, Goodyear Wrangler ATS 275/65R18E, 40k miles.
2005 Keystone Montana 5th wheel, 3685FL, 11,020 UVW, 2340 pin weight, length 36ft-10"
2004 Triton Tr 186, 150 Xr6
Pictures
kundesc is offline
Old 12-29-2005, 11:49 AM   #6 (permalink)
I'm getting right at 15 highway with a 7500# car hauler.
n9emz is offline
Old 12-29-2005, 12:00 PM   #7 (permalink)
Towing the 5er with Jody's econo-tune(80) nets me 10.9 mpg. Up from 8.5-9.2 when stock with way more power.
EDMGUY
2000 F-250PSD,White,Crew Cab,Shorty,4X4,6 Speed,Luk Clutch,3.73Ls,DP-Tuner F-5 with 16prgms,Tymar Intake,Non-Wastegated Van Turbo w/ATS housing & Stock Wheel,4in Exhaust From Turbo,Zoodad,CCV Mod,ITP SS HPX Line,AIH Delete,ITP Regulated Over-Boost Eliminator,Autometer x3,Fabtech 4inch Lift,Bilstein 5100's,Eagle Alloys 16x8 w/Pro-Comp All-Terrain 35's,Powerslots w/Hawk Pads,Valley 16k Slider 5th-Wheel Hitch,$30 Custom Grille,100,000miles
325hp/721tq 4/06 on Dunbar's Rollers
Towed Item :2004 Cedar Creek 36'BB2S Bunkhouse Fifth-Wheel (12,500lbs)
<font color="blue">My Truck & Fiver :</font>
Click Here
Spare Time Activities:MHFR
<font color="red">Can You Keep Up?</font>
edmguy69 is offline
Old 12-29-2005, 02:16 PM   #8 (permalink)
I dont have any performance mods yet. but i am definitely going with exhaust and guages before the summer heat hits. Towing this much weight anything will help. I would like to get a mild program for extra umph. I am just gun shy with what ive read on here.
Pictures
kundesc is offline
Old 12-29-2005, 03:02 PM   #9 (permalink)
From my experince that mileage is good. Are you sure it was not 12 round trip (maybe half empty/half full??)
Anyway, every truck I have had has went down in mileage considerably when towing. My "lite" load, is the 2 ATV's, and a small 12ft flat deck trailer. All together I doubt its 2500 pounds, but I only get 12 to 13 on highway with it, and only 6 mpg with the camper, approx 18k there.
08 f450 KR 4X4, no roof, no tv, everything else
05 KZ New Vision 41ft toy hauler
03 harley roadking classic
03 honda rubicon
05 bombardier DS650
http://i5.tinypic.com/4ue76eq.jpg
6SPDMANUAL is offline
Old 12-29-2005, 03:58 PM   #10 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
Your mileage with a 6-speed manual tranny (unloaded or loaded) should be better in my opinion. Maybe it is the lift and/or tires increasing your aerodynamic resistance/rolling resistance. My '02 got nearly 12 mpg weighing in at &gt;26,000 lbs towing in the hills of Southern Ohio/Northern Kentucky and I have a dually 4:10 with a slush box and no chip. Of course that was not city driving but that horse trailer has a huge frontal area.
haul_n_horses2 is offline
Old 12-30-2005, 01:24 PM   #11 (permalink)
Does your trailer have a wire grid loading ramp? I can tow my 2200lb trailer with a 3400lb car on it and get better fuel mileage than I can pulling a 6x8 trailer with a motorcycle on it witht the wire mesh ramp on it. Those wire grid ramps don't do much for mileage!
...danny
2001 'X' 7.3l PSD 4x4 Limited
Oxford White / Medium Parchment
K&N Air filter, Husky Floor Liners
20' H&H Speedloader MX Tiltbed Trailer
Bilstein shocks(BE5-6208 front, BE56209 rear) $259.80 to my door.
AllAboutJeeps is offline
Old 01-01-2006, 09:56 AM   #12 (permalink)
On our most recent, Xmas trip, hauling two horses in my signature CM 4 horse aluminum Winstar, I put the rig on a CAT scale. Result: 15,050 gross combined weight, wet, not counting the lovely spouse and me [another 350 or so]. Bad news was the 8800 limit: adding the wife and I to the load puts us right at the limit [need to cull out the junk in the toolbox....]. Good news is that we got right at 15 mpg, with maybe 90% of tank(s) of fuel towing this full load, much of it at or near 65-70 mph on the interstate. Weird, but it seems I got better mileage with this heavier load than I had in a summer trip with our previous, smaller trailer [same model, but the 2 horse]. Only 'changes' that could have effected this were the addition of the BTM [which has a marginally louder, deeper exhaust note than stock, IMHO] and switch to Castrol oil from Rotella. Note than mine is a 2wd, without lifts or biggie tires; I run Michelin M/S in 235/86-16. It appears that 15 mpg towing this much weight is about as good as it gets.
2000 F250 4x2 Supercab XLT; Detroit Truetrac ltd slip diff. w/PML aluminum cover; FTVB; BTM; PF pads in the front. DP Tuner stock/60tow/80econ. 203 'stat, Cat ELC coolant, Gauges, Ford AIS, Bilsteins, Michelin LTX M/S, B&W gooseneck in a Line-X sprayed bed; UWS low profile tool box. Towing a 2004 CM Winstar 4 horse trailer loaded with quarterhorses, whenever possible ....
Wife's New Ride: 1999 Mercedes Benz E300 Turbo Diesel Sedan
Riggodeaux is offline
Old 01-01-2006, 09:51 PM   #13 (permalink)
Alright. I see everybodies (or almost everybodies) signature with mods or chips. Guess I should add one too eh? What are some good ones for improving gas mileage? Without any mods or chips.. What kind of MPG should I expect towing a 15,500 lb trailer at around 65mph with a new F-350 Diesel 4x4 crew cab with the tow boss? Any Ideas? Just curious.
<font color="red">2005 F-250 4x4 Crew Cab PSD "SOLD"</font>
2006 F-250 4x4, Crew Cab, Diesel, Lariat, Short Bed, 3.73,. Captain Chairs, Tow command, Upfitters, Moonroof, Alarm system with remote start, Rhino Liner, bug shield, mud flaps, and Ziebarted! <font color="blue"> Sold!</font>
ljack10270 is offline
Old 01-02-2006, 01:20 PM   #14 (permalink)
With the Superchips Microtuner, set in 40hp Tow Safe Mode, I get 10-11.5 towing my 27ft TT.
Pat
06 F350 4x4 XLT, CC, LB, True Blue, 3.73LS, dash mount Pyro (ESOF knob), with stick, 23K miles, Toyo Open Country MT 275/70/18/E.
97 F350 4x4 XLT, CC, 136k.....SOLD to new owner
GOPDiesel is offline
Old 01-02-2006, 04:17 PM   #15 (permalink)
Just be very careful about any mods you do. FoMoCo will deny warranty coverage in a hurry if you have any mods which they feel contribute to the problem. Be ready to pay for repairs out of pocket if this is the case.
With your set up, and that's a lot of trailer, I would expect you to see 8-10 towing. Hmm, 'bout the same I used to get with the F150 gasser towing a 5000# TT. Don't miss that at all.
Aaron
2004 F250SD 4x4, XLT Sport, FX4, Crew Cab
6.0L PSD, Torqshift, 3:73ls
Dark Shadow Grey, Power Cloth Captain's Chairs
Reverse Sensors, Heated Switched TT Mirrors,
Adjustable Pedals, Covermaster CMX Series Topper,
Bedrug Bedliner, Prodigy Brake Controller
Hensley Arrow Hitch, Ride-Rite Air Bags, Dashmat
X-Monitor Digital Gauges, Tach 1200 High Idle Mod Harpooned
Born on 1/21/04,
My Photo's
DSB buyback 2/16/04, RIP 2003 F250SD, 6.0 PSD
ABrown134 is offline
