I just bought an old travel trailer with some odd ball tires on it. The only markings I can find are "Mobiliner 15" HTS 6 ply rating."
I think the 6 ply rating is the equivalent to an Load Range C tire. As far as the size goes, I stood it next to the 205/75/15 STs that are on my cargo trailer and they are substantially taller, but no wider.
Anybody know what these things are and what I should replace them with? The travel trailer is titled at 4k but I have yet to drag it over a scale to see for sure.
I believe it is a bias tire that is likey a 7 or 7.50 x 15, which would be a taller tire.
You can go with a 225x75r15 radial - which would still be shorter or a newer 7.00x15 (that is what I have on my 16' utility at 6K.
These tires are a little more robust and can handle curbs, tight turns, and abrasions better than the radial - and they should be about $70 instead of $100.
In anycase - the Mobiliner is an old brand I believe out of Ohio. It is a retread or lined tire. Definately junk them...
99.5 F-250 CC LB 4x4 7.3 Red, Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, Bilstien Shocks, Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, BFG AT/KO 285/75x16, Magnaflow 3.5" DP - 4" Exhaust, 2003 Cup Holder, X-Springs, Rear 4" F350 Blocks, ATS Housing, Edge Evolution (Rev. 19), Banks Big Head, DS Boost Relief, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, Sonnax/Tricum
I'd get them off before I pulled anything heavy. The sidewall on Mobileliners used to say "for mobile home use only". They were made very light weight and will blow or separate in a heart beat. Yea, been there, done that. I quit running them and I was getting them free.
Joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
There is no danger of me not replacing them as they are probably in the neighborhood of 20 years old or more. I drug the thing home with them on there strictly because I had no other choice and it wasn't very far. This thing sat up in a campground resort type area since sometime in the mid 80's. I was surprised to find the bearings and brakes in pristine condition, although the grease was getting a little thin.........
My local dealer carries Loadstar STs. Any opinions pro or con?
Take a look at these. Deep tread, strong sidewalls that don't squat like other radials. $85-ST225/75R15D, free shipping and fast. Usually 2 days. ST225/75R15D
