Old 08-26-2006, 07:22 PM   #1 (permalink)
My Photos: (12)
More aggressive brake shoe lining for trailer?
Has anyone tried to increase their trailer brakes performance by have the shoes relined with more aggressive (higher friction) lining?
I know that my 5er is right on the rated gvw of the camper at 12K and the brakes don't seem to be very strong (will not lock up at all). I am lookin for an economical way to improve it -- all ideas appreciated.
2003 F250CC shorty Lariat 7.3 PSD, Jody Tipton Flash, Autometer boost and EGT gauges, Nordskog trans temp, fuel press, voltmeter. Banks exhaust, Precision TC, Transgo tugger, Hyd oil filter on trans return line, custom HD y-pipe boot clamps, Take 3 5er hitch, PML pans, Manual TC lock and indicator, No-Start switch (anti-theft). -- 89 F250 7.3 IDI 4X4 tuff truck--92 Jetta eco-diesel, 425,000 miles and still going strong--Honda CRF250, Suzuki DRZ400 SUPERMOTO.
dieseldrive is offline
Old 08-26-2006, 11:56 PM   #2 (permalink)
Re: More aggressive brake shoe lining for trailer?
<font color="green"> If they are electric, then don't expect much.
If swapping to vacuum-over-hydraulic brakes is not feasible, then I would start at the controller, and work back to the brake hubs, re-wiring and soldering every connection.
Use at least 12gauge wire.
Solder a 12 gauge ground-wire, from hubs to a good ground on truck frame.
Splice in ground leads from the main ground wire and secure them to trailer frame and truck frame.
Don't be surprised, after all this work, if your brakes are no better; it is just the nature of electric brakes.
You can have a brake-shoe rebuilder build a custom-lined set of shoes, but I don't think that will cure your brakes.
Hope this helps. </font>
1985 F-350
5.9 CUMMINS TURBO DIESEL
G360 GETRAG 5-sp
3:55 DANA 70
LongRider is offline
Old 08-27-2006, 10:46 AM   #3 (permalink)
KF6ZVT's Avatar
Years ago, a friend and I tried it once with a trailer we used to take hunting. We had the friction shop line the shoes with some stuff called "Velvet-touch". We put all new springs and magnets in. The brakes were only marginally better.
If you want really good brakes, you have to upgrade to electric/hydraulic disc brakes. I've seen these in action, they are awesome. An owner of a travel trailer was showing them off to a bunch of us in an RV park, he was NOT selling them just showing off. It was one of the smoothest working brake systems I've ever seen on a trailer. And they would, without hesitation, lock all four wheels on the trailer when needed. He pulled the the break-away switch with the trailer stopped, and could not move it an inch with his F350 in low gear and low range 4WD!!! His brakes were an after-market add-on, I don't remember where he got them, it's that old guy CRS thing again.
2001 F250 SC 4X4 Blue PSD Auto, Cody Gooseneck Hitch, Rancho Shocks and Steering Stabilzer, Tekonsha Prodigy Controller, Garmin Streetpilot 2610 GPS, Walker BTM, 285/75R/16E, Western Diesel Trans-Pyro-Boost, Pillar Mount, Painless fuse panel, In-tank and Pre-pump mods, Slotted Rear Rotors, Slotted and Cross Drilled Front Rotors, Fumoto Valve, Zoodad Mod, Transfer Flow 46 gal tank, Mag-Hytec Differential Cover, Electric Tailgate Lock, IAH Deleted, Coolant Filter, DP-Tuner 80 hp PCM, CCV Mod, 203 Thermostat, Ford AIS Air Filter
KF6ZVT is offline
Old 08-27-2006, 11:02 AM   #4 (permalink)
Hi dd,
First I would add a temporary seperate ground between the truck and trailer and see if that improves brake action. If it does then you need a better gound. The #1 cause of bad brakes or no brakes.
Next check the wiring connections to each magnet. After using new wire nuts or solderless connectors, I use RTV on the connectors to keep moisture out. Improvement?
Depending on how old your axles are, you may need to adjust the shoes. After the trailer sits for more than a month, besure to manualy apply the BC several times to break off the rust glaze on the drums while moving under 25mph. Shoe adjustment helped?
My new Dexter tandum duals are forward self-adjusting with oil bath bearings. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Next it's time to pull the hubs off and take a look. Download the Dexter service manual for your type of axle and go from there.
[img]/ubbthreads/images/graemlins/smokin.gif[/img]
T_Bone
02 F350, 4X6, Crew, DRW, LWB, PSD, 6spd, 3:73, Island Blue, Stock, AEB2, Phoenix Az
Buy UNION work UNION. It pays off in the long run
Define Union:
A labor Union is nothing more than united workers with a common goal for better working conditions.
We all are in some sort of labor Union, some are just larger than others with better working conditions!
T_Bone is offline
