Motorcycle Mounting On Front of F250 - Diesel Forum - TheDieselStop.com
Old 04-21-2006, 12:58 PM   #1 (permalink)
My Photos: (12)
I want to mount a motorcycle on the front of an '05 F250. I have seen some ramps for sale like the moto hauler but I want to use two receiver tubes, one from each frame rail where the tow hooks are. I would also prefer an electric lift but being a cheapskate, don't want to empty the bank.
Anyone have any ideas on this? I do own a welder.... [img]/ubbthreads/images/graemlins/shrug.gif[/img]
It's a 2005 F250 6.0 with camper front springs.
Jim
hypoxia is offline
Old 04-21-2006, 02:09 PM   #2 (permalink)
Re: Motorcycle Mounting On Front of F250
You can buy the reciever tubes at any trailer store. That's all I can offer.
2006 GMC K3500 CC DRW 4x4
1994 F-350 DRW PS w/ zf5
1996 Town Car
mgraveman is offline
Old 04-21-2006, 04:45 PM   #3 (permalink)
My Photos: (60)
How big a motorcycle? My Father-in-Law had a framework that bolted to a flat plate on the front end of both frame rails on his Winnebago motor home. It held a Yamaha 185 off road bike and a Yamaha 250 scooter years ago (one at a time, not both at once).
The only real concern is adding a few hundred poinds that far out in front of the front suspension.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
Old 04-21-2006, 05:50 PM   #4 (permalink)
My Photos: (12)
It's a 425 pound BMW F650GS.
Jim
hypoxia is offline
Old 04-22-2006, 02:34 AM   #5 (permalink)
425lbs + 85-100lbs for the carrier or rail system. You won't want to load/unload that bike without a helper. It is likely that one or both headlights will be partially obstructed.
toalpi is offline
Old 04-22-2006, 08:47 AM   #6 (permalink)
My Photos: (12)
You're right about that. Getting the beast on and off is the biggest challenge. [img]/ubbthreads/images/graemlins/confused.gif[/img] It needs to be lifted about 24". Most motorcycle lifts are too short. The headlight issue will be solved by not driving at night and/or fog lights. I plan on using Leed Engineering receivers on each frame rail. Front Receivers Or I could get ambitious and fire up the mill and welder and make them. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
I used to haul another motorcycle, 250cc, on the front of a motorhome. It was lighter and I was stronger. I could pick up one end at a time and put the tires in the pockets of the holder.
Jim
hypoxia is offline
Old 04-22-2006, 11:13 AM   #7 (permalink)
My Photos: (60)
Setup my Father-in-Law had included a ramp that you used to run the bike up under its own power onto the channel it rode in, two tiedown points and storage for the ramp. His was made out of 4 or 5 inch channel, you would need 6" or more to get the tires on your BMW in. You can make the ramp as long as the truck is wide so you would easily be able to get the bike up and down, just like running it onto and off of a motorcycle trailer.
Dave / Believer45
Old 04-23-2006, 05:40 PM   #8 (permalink)
Maybe you could modify one of these designs to work with your front hitch receivers http://www.motorcycleramps.com/motorcycle_carrier.htm
or build your own with a detachable ramp. Your right, the motorized lifts ain't cheep. Should work pretty well as long as you don't exceed the front axle rating. You'll probably need to install a set of front air bags to level your truck when the bike is being hauled. As long as visability, lighting and air flow to the radiator aren't problems, it should't be much different then having a plow out there.
2006 F-350 DRW, 4X4, 6.0L PSD, 4.10 LS, Tow Command, Reese 20K, Firestone Ride-Rites, Auto Meter 3 guage A-pillar mount, American Tank 45 gal. aux. tank/toolbox, Rhino-Liner, Pro-Flaps, C-Betr mirrors.
2008 Cardinal 37RL 5th wheel
truck pics
2004 Cardinal 5th Wheel pics
Fordman6 is offline
Old 04-24-2006, 01:23 AM   #9 (permalink)
Kanman's Avatar
Thats an awful big bike to mount on the front of a pickup truck. Before I spent a dime on this deal. Jack the bike up in front of the truck to the height you figure the thing will need to ride at. Bet you a box of doughnuts it obstructs your view a lot more than would be safe.
Kanman is offline
Old 04-25-2006, 05:02 PM   #10 (permalink)
Post a picture if you ever do it. I don't think I'd be too keen on having 600lbs of radiator and headlight blocking road bike on the fron of my rig for any length of time, but sometime you have to be creative to play with your toys.
Don't rear end anyone [img]/ubbthreads/images/graemlins/blush.gif[/img]
'06 F350 CC Red 4X4 Lariat auto
rickeg is offline
Old 04-25-2006, 05:37 PM   #11 (permalink)
My Photos: (12)
The setup beleiver45 used may do the job. I have hauled a 250 motorcycle in front of a motorhome on a Ford E350 chassis. That worked out nicely. I ran the bike up a ramp onto a trailer that was taller than I need on the truck and it was suprisingly easy.
When I figure out how to post a photo here I will do so. [img]/ubbthreads/images/graemlins/confused.gif[/img]
Jim
hypoxia is offline
Old 04-25-2006, 06:41 PM   #12 (permalink)
If you ever figure something out I'd like to see it. I need to find a place to put a Suzuki LTZ250 sport quad. About 360 pounds. [img]/ubbthreads/images/graemlins/smile.gif[/img]
2005 V10, AT, Fx4 Dark Stone Metalic, Crewcab F350, 4.10LS, shortbed, towcomand, Extang tonno **SOLD**
2007 Dodge 3500 Quadcab, 4x2, 6.7L Cummins, a/t, longbed, 4x2
Silence is golden. Duct tape is silver.
V10 man is offline
Old 04-25-2006, 06:49 PM   #13 (permalink)
My Photos: (12)
I think I figured out how to post a photo. Here's what I did with my motorhome some time back.
http://photos.thedieselstop.com/show...amp;thecat=500
Jim
hypoxia is offline
Old 04-25-2006, 11:18 PM   #14 (permalink)
If you have room in the bed for a folding engine hoist, you could use that to pick up the bike and load on the carrier. As one of those is actually heavy and takes a lot of room, you might use the concept to make something better suited for your needs. Nice bike by the way.
boatpuller is offline
Old 04-25-2006, 11:53 PM   #15 (permalink)
That idea seems like trouble waiting to happen! I have enough troubles worrying about my trans overheating without a big a## Bike blocking the air flow!! Just my 2 cents worth!! [img]/ubbthreads/images/graemlins/smokin.gif[/img]
'02 Chevy Silverado HD2500 LT 4x4,CC,Shorty,Dmax,Allison, Edge Juice w/Attitude, AFE Stage II w/Pro 7 filter, 4" MBRP Cool Duals, BrakeSmart Controller, 16K Reese 5th Wheel Hitch
'08 F350 6.4L PSD King Ranch 4X4,CC,LB,AUTO
ovrtrn is offline
