Old 05-17-2006, 12:21 AM   #16 (permalink)
Re: My horse trailer rebuild.......
<font color="green">
Do you ever partake of the Monday night Sheperdsville horse auction??
If anything, it is entertaining. </font>
Nope, but I know the auctioneer a little, and he's told me some about it. Mabey someday I'll go.
I'm alot closer to the Tri-county sale barn in Henry county, which has the same auctioneer.
-Phillip
I've been to Shepherdsville a time or three. We've bought some decent horses there and we have sold some "not so good" horses there as well. The hip numbers don't seem to matter much. The Ryan boys just go in the sale ring whenever they want to. It's been a couple of years, so maybe it's changed some.
2005 Arizona Beige F350 XLT FX4 6.0 CC shortbed, 3.73 ls rear, 18" wheels, Tow Command. Additions: Vent Visors, bug guard, Fumoto Valve, Timbrens. Traded for...
Current Truck -- 2008 Black F350 XLT 4x4, 6.8 V10, CC Long Bed, 4.10 rear, 18" wheels, IBC. Additions: Chrome Step Bars, Chrome door handles, Silver barbed-wire pin stripe, B&W Turnover GN ball
barrelhorses is online now
Old 05-17-2006, 10:20 AM   #17 (permalink)
I haven't looked behind the rubber wall lining on my CM, but it appears to be mounted on an aluminum frame of some kind directly inside the extruded aluminum exterior walls. I assume you used the plywood to give some rigidity and protection to your outside sheet aluminum walls, and to mount your rubber lining. 3/4" laminated board, treated, must up your weight, too! Not to expand your project [you've done a great job and way more than I ever could!], but you might look for extruded aluminum panels for your o/s walls if you go back and ditch the plywood.
2000 F250 4x2 Supercab XLT; Detroit Truetrac ltd slip diff. w/PML aluminum cover; FTVB; BTM; PF pads in the front. DP Tuner stock/60tow/80econ. 203 'stat, Cat ELC coolant, Gauges, Ford AIS, Bilsteins, Michelin LTX M/S, B&W gooseneck in a Line-X sprayed bed; UWS low profile tool box. Towing a 2004 CM Winstar 4 horse trailer loaded with quarterhorses, whenever possible ....
Wife's New Ride: 1999 Mercedes Benz E300 Turbo Diesel Sedan
Riggodeaux is offline
Old 05-17-2006, 06:22 PM   #18 (permalink)
-Phillip
<font color="green">You wouldn't by any chance be talking about "SLIGO", where they trade anything, including fighting roosters, goats, Jersey calves, wives, you name it, would you?? </font>
1985 F-350
5.9 CUMMINS TURBO DIESEL
G360 GETRAG 5-sp
3:55 DANA 70
LongRider is offline
Old 05-17-2006, 07:36 PM   #19 (permalink)
Send a message via ICQ to GreyHorse
I would do something to try to preserve the floor.... like soaking it with Diesel or Linseed oil a couple times and then again once a year. Diesel really stinks for a couple weeks but then the smell subsides, Linseed oil has worked really well for me, kind of hardens the wood as it oxidizes. Both help keep the wood dry.
2000 F-350 CC, SWB, 6 speed, SRW, 4X4
1985 Mercedes 300D
1999 International 4900 DT466e 250/660 Allison MD3060
GreyHorse is offline
Old 05-17-2006, 10:07 PM   #20 (permalink)
My Photos: (63)
-Phillip
You got it. [img]/ubbthreads/images/graemlins/grin.gif[/img]
-Phillip
My truck pictures
1995 CC DRW XLT, Converted to 4x4 with D60 front, Alcoa Classics, ZF5, Big bumpers, gooseneck hitch, Cobra 148, SuperDuty electric fuel pump, Aeromotive fuel pressure regulator, Davco/Detroit Diesel fuel filter assembly with twin 10 micron Cummins OTR style filters, Stanadyne Fuel heater, Tymar intake, Isspro EV Pyro and boost gauges, Autometer pod, Ford AIC, Techonsha Hydraulic brake control, TS 6position chip, JD coolant eye, 4" DP with 5" Auto-Jet muffler and exhaust out the back, SWAMPED.
1993 Shoop Gooseneck, Steel/Aluminum, 4 Horse Head-to-Head
2001 Land Rover Discovery SE
KentuckyDiesel is offline
Old 05-17-2006, 10:09 PM   #21 (permalink)
My Photos: (63)
I will probably make my favorite used oil/diesel mix.
-phillip
My truck pictures
Old 05-18-2006, 11:52 AM   #22 (permalink)
haul_n_horses2's Avatar
My Photos: (17)
I have decided that my next trailer will have line-x sprayed to cover the floor and up the walls 3'.
[/ QUOTE ]Checkout the W.E.R.M. (We Eliminate Rubber Mats) flooring. It is a very nice poured flooring that is used in a lot of custom trailers. It was tested with a device designed to mimic a horse pawing continuously in the same place for 10 years and it did not wear through it. And any defects can be repaired with a trowel. Very little slipping and sliding on that surface and easily cleaned up with a pressure washer. I bed with shaving for absorption of the urine and manure even with the flooring.
haul_n_horses2 is offline
Old 05-18-2006, 05:18 PM   #23 (permalink)
Sapps's Avatar
You all listen this this guy right here, he knows his horse trailers!!! [img]/ubbthreads/images/graemlins/wink.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]
95 Ford F250 - 7.3 Racer/Puller
07 Dodge 3500 - 5.9 Daily Driver Tow Rig
Sold:
2002 Ford F350 7.3
2006 Ford F250 6.0
Sapps is offline
Old 05-19-2006, 12:36 PM   #24 (permalink)
Beautiful trailer, beautiful truck, and nice grass!!
2004 F-350 Lariat SRW <><
315 BFGs, Edge Platinum, ARP Studs, & B&W Goose
1998 Cherokee RockCrawler
NCfarmboy is offline
