Old 10-20-2007, 07:41 PM   #1 (permalink)
My new dually has huge tires! Advice?
Gentlemen,
I recently bought a 2001 PSD dually 4x4, right now it has BFG All Terrain Radials in a 285-75-16 size. They look absolutely cool, but I'm relatively sure they are too big for a dually. I've noticed the truck dosen't have spacers, and the tires literally touch in the rear at the bottom where they flare out when contacting the road. I believe I'm correct in assuming I'll have to go down to a smaller size, but how much smaller? Do you think I can get away with a 265-75-16E? Or is it all the way back down to the stock 235-75-16E? Thanks - Tom
2001 F-350 DRW, 4x4 PSD , 185K miles, 6-speed, Banks Power Pack, Banks Brake, Ford High Idle Controller
USAFFLYER is offline
Old 10-20-2007, 10:47 PM   #2 (permalink)
88beast's Avatar
Re: My new dually has huge tires! Advice?
i have 255/75r16 on my srw in sig they are steering tires and i know even without spacers they would ft on a drw truck i think ur 265 will be fine
ever think itd be cheaper to buy spacers?
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
http://youtube.com/watch?v=ILAQuHNAGE0
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
88beast is online now
Old 10-21-2007, 12:05 AM   #3 (permalink)
Thanks for the info. any other dually guys want to pipe in?
Old 10-21-2007, 12:13 AM   #4 (permalink)
My Photos: (6)
255's are the biggest you can go without spacers on the rear. With your 285's you will need spacers or in time you will have a blow out!
I have 295's with a 2inch spacer...love the look and will probably go bigger down the road. You have 2 options, spacers or new tires. Spacers will be cheaper and will allow you to keep the look youve got and like.
If you get a spacer get one that is hub centric and wheel centric so the spacer sits on the hub and the outer wheels sit on the spacers lip and not the studs (safer!)
Good luck
2001 F350 Dually, Crew Cab, 6x6, Lariat, 7.3 PSD
Auto, 4.10's, Camper Package
4.5" DR Edge Lift (soon to go on) Dual front shocks, 33" BFG AT's, 2" rear dually spacers, factory fresh trans
4" SS MBRP Cool Duals, Banks 1.0 Exhaust Housing, Banks Big Head, AIS Intake w/ Fender Cutout
DiPricol Optix Boost, Pyro, Full Sweep Trans Temp
My F350 DRW Pics
TalontedTSi is offline
Old 10-21-2007, 12:16 AM   #5 (permalink)
Mine has 255/85/16, very strang size but biggest with no spacers.
99(4/99)F350 PSD 4X4 crew cab long bed dually lariat isspro triple pod air bags with compressor
99(6/99)F250 PSD 4X4 X-cab short bed xlt 5in str8 piped air bags autometer ultra light triple pod junk yard pcm running 22 psi 250k miles bought 8/15/01 w/40k miles first diesel
00(12/99)Excursion PSD 4X4 limited
65 Mustang 289 V8 4brl 69 GTO 400 4spd 99 Neon R/T
04 and 09 PJ 15k dump trailer 04 H&H 9K tilt bed 98 Haulmark 7x14 enclosed
86GLHS is offline
Old 10-21-2007, 12:35 AM   #6 (permalink)
88beast's Avatar
ever think trying 285/55r16? another idea there
Old 10-21-2007, 08:34 PM   #7 (permalink)
O.K. great advice guys, thanks for taking the time to help me out. - Tom
Old 10-21-2007, 08:57 PM   #8 (permalink)
SmokeyWren's Avatar
My Photos: (33)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 88beast</div><div class="ubbcode-body">ever think trying 285/55r16? </div></div>
Nobody makes that size in an LT tire.
If they did, it would be about 2" wider and 3" less diameter and 84 more revs/mile than stock LT235/85R16E tires. Low-rider tires, maybe, but not for a pickup that's good for hauling or towing.
SmokeyWren is offline
Old 10-21-2007, 09:32 PM   #9 (permalink)
88beast's Avatar
didnt no never looked just a suggestion or somin smaller and a little less wide
Old 10-21-2007, 11:15 PM   #10 (permalink)
285 is the width, so a 285/75 is theoretically the same width a 285/55, so no gain.
1996 F250 7.3 4x4 EC LB XLT: Tymar Intake, 3x4 DP, 4" exhaust, Delvac 1 its whole life, Shimmed, Gutted EBPV, Tymar bypass system, Baby Swamps but no chip... 213k
parkers30 is offline
Old 10-23-2007, 11:40 AM   #11 (permalink)
If your tires are already touching they are probably already ruined. When they touch they wear away the sidewalls on both tires, it makes a concave round groove in the sidewall. (I had this experience on an old F-350 wrecker that had oversized tires plus overloaded which made the sidewalls kiss).
Pull both sides off and check them before committing to buying spacers.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 10-23-2007, 10:03 PM   #12 (permalink)
I have 265's on mine with no spacers and no rub. I think that is about the max without spacers. If I were to go any bigger I think they would rub.
1999 F350 Extended Cab DRW
MPB670 is offline
Old 12-26-2007, 12:21 PM   #13 (permalink)
USAFFLYER ,
I've been thinking about putting some 285's on my dually with the factory 17" wheels. Do you have any pics so I can see what it looks like?
Thanks!
2005 F350 Crew Cab Long Bed 4x4 Dually 6.0 PSD Lariat with Tow Boss/4.30
atkinsr is offline
Old 12-26-2007, 01:23 PM   #14 (permalink)
I have 285's on mine now, and they do rub. But the 265's fit perfect- no rubbing , ever. The 285's look a lot better.
2000 f-350 crew cab drw 4x4, DP tuner, BDP 230cc singles, dieselsite misc. parts, monsterbox tranny, 4.10 gears, very tight limited slip in rear, and now.....Swamps gen3 big oil, modded H2E . Fastest time so far--1/8 mile 8.56 @ 82 mph --8200 pounds.
I dont want it all, ....just more!
http://www.myspace.com/atvedt
smorris is offline
Old 12-26-2007, 04:30 PM   #15 (permalink)
u2slow's Avatar
My Photos: (16)
The 255/85R16 is about as tall as the 285/75R16 - just narrower. Perhaps you only need to change the back tires instead of all 6.
1.5" spacers were $165 each last time I checked around locally.
95 F350 Crew 5spd/4.10, SuperChips tuner, solid flywheel, T444E waterpump, 205° stat, Locked F&R, 9.00R16 Michelin XLs
97 E350 SRW cutaway, E4OD/D70/4.10, 19.5s on the rear, deep trans pan, batteries inside, 1800W inverter, manual glowplugs
84 C30 Suburban, 6.2/4-spd, 3.21s
Other rigs I goof around with regularly:
93 F350 4x4, 7.3 IDI turbo, 5spd, 4.10s
90 F250 4x4, 7.3 IDI, 5spd, 3.55s
, D60 swap, straight pipe, turned up fuel screw
u2slow is offline
