Old 10-24-2007, 02:18 AM   #1 (permalink)
is my truck too tall for a fifth wheel???
I HAVE A 2000 F350 WITH 8" LIFT AND 37" TIRES, WITH AFTERMARKET SKYJACKER SPRINGS (I KNOW I NEED AIR BAGS). ALSO HAVE: HYPERMAX CHIP W/ 5" EXHAUST W/ STOCK 3.73 GEARS; AND ALL GAUGES.
JUST BOUGHT A 40' FIFTH WHEEL KEYSTONE FUZION. IT ALREADY COMES WITH THE AXLE FLIPPED.
FIRST: IS THE TRUCK TOO TALL TO HAUL THIS? ANYONE HAULING ANYTHING SIMILAR?
SECOND: WILL THE TRUCK HAVE ENOUGH POWER TO PULL THIS? DO I NEED PROPANE? WHEN LOADED IT WEIGHS 16,500 LBS. WAS GOING TO USE A GOOSENECK HITCH
THIRD: TRANNY PROBLEMS ANYONE?
THANKS!
mxridersx4 is offline
Old 10-24-2007, 11:07 AM   #2 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Re: is my truck too tall for a fifth wheel???
If you went with a flat bed you might be able to get the neck low enough?
MarkEkberg is online now
Old 10-24-2007, 11:46 AM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (33)
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">is my truck too tall for a fifth wheel??? </div></div>
Probably, without more mods to your truck.
As Mark suggested, you could replace the pickup bed with a flat bed and that should do the trick for clearance between the trailer overhang and the sides of the bed.
When you get the trailer hooked up, you want the floor of the trailer to be level, front to rear. If it's not level, then it's too dangerous to be towing on the highway. So get the trailer level and be safe. That might mean you have to modify the 5er hitch to get it short enough to result in the trailer being level front to rear, even with a flatbed body.
SmokeyWren is offline
Old 10-24-2007, 02:29 PM   #4 (permalink)
I'd have to say thats not a good truck / trailer combination.
The trailer is too heavy for the F-350, and the F-350 is too tall for the trailer.
And the truck will deffinitely benefit from a new trans cooler. That's going to be the weakest link on your truck.
OMCUSNR is offline
Old 10-24-2007, 02:57 PM   #5 (permalink)
I tow a 40' weekend warrior with my truck, 10" lift w/38" tires I do have my truck re-geared w/4.88. Ive been towing mine for 2 years and it does fine. With that said I just ordered an 08 f-450.
08 F-450, RED/MEDIUM FLINT, CC, LB, LARIET, 4X4, NAV, REAR DVD, BACK UP CAMERA, CAPTAINS CHAIRS, B&W GOOSE NECK HITCH, FIFTH WHEEL COMPANION, WOLF LINER, 90 GALLON TRANSFER TANK, TRAIN HORNS, REAR AIR BAGS.
00 FROD RANGER 4X4
94 FORD RANGER
85 JEEP CJ-7
05 F-F350 SRW, FX4, CC, LB, Lariet, 4X4, SOLD
99.5 F-350 SRW, CC, LB, LARIET, 4X4, V-10, SOLD
93 FORD RANGER 3.0 4X4 SOLD
2007 SLC 3905 weekend warrior fifth wheel.
mschwing82 is offline
