Need 5/8"x3" Grade 8 carriage bolts for 5th wheel hitch???
Can anyone help me in finding a 5/8"x3" grade 8 carriage bolt for my 30k reese low-pro 5th wheel hitch? My local trailer place got the hitch for me but the bolts do not come with it from Reese.
Re: Need 5/8"x3" Grade 8 carriage bolts for 5th wheel hitch???
Look under "Fasteners" in your local Yellow Pages.
Early 99 F250 PSD (XLE4) XLT, Extended Cab, Short Bed, 4X2, BTS Trans/TC, 3.73 Limited Slip, Transfer Flow 48 Gal. Mid-Ship Tank
Western WA - Member since August 2001
I'm going to ask a dumb question, but can you get carriage bolts in grade 8? I've never seen them past grade 5, which is what I've always used in hitch installations -- certainly 8's are stronger, I'm not argueing that point but I've naver seen such an animal.
I'm betting there's no such thing as a Grade 8 carriage bolt.
I've never seen a grade 8 carriage bolt. Which, being said, is next to meaningless for I haven't seen ALL bolts that are made. The instructions do say
"6. Bolt the base assembly in place with the four grade 5 or higher 5/8” carriage bolts, locking nuts, and flat washers. The nuts and washers should be below the 1/2” plate. (5/8” carriagebolts, locking nuts, flat washers are not supplied)"
so I would go with the grade 5's. I'm not even sure the grades 8's are much stronger than the 5's. Hardness grades(3,5,8) are not equivalent or indicative of tensile strength. They are harder, but??
It's like Maple wood is harder than Oak, but it's not as strong.
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear, Built May05. 4" turbo back, 100gal aux fuel tank. A real pig from a stop, but give me 10' and she'll lite'em up.
Call Resse and tell them your hitch didn't come with a hardware kit.
They will send you one .
The rail kits come with all the hardware to install. Your local trailer place is not being truthfull.
O5 F-250 SuperDuty CC SWR 4x4 Lariat
8' box 6.0 PSD Tow Comand new 04/05
2001 40' Alfa Toyhouse
Pulls better stock than my 01 with a programmer
New engine at 42k . Hope my luck with this 6.0 is changed .
I have never seen a grade 8 carriage bolt either but a regular bolt with a flat washer should work in the same place, however I have always used grade 5 hardware to attach trailer hitches, it is either what came with it or what was specified. If you do need grade 8 bolts the place I get them is at the local auto parts, they have them in all sizes up to humongous in the back room. The hardware store is only good for grade 5 and only relatively small sizes.
Next we'll be hearing how Grade 8 is no good for hitches because they're "brittle" and they don't flex enough.
Or how hitch companies purposely use Grade 5 so that they break away in an emergency and the trailer doesn't drag the truck with it over a cliff...
[img]/ubbthreads/images/graemlins/shrug.gif[/img]
Anyhow, unless there is some clearance issue, or the fastners really do locate on a square hole, I would just get button-head socket capscrews. They are available in several grades. In reality unless you need that head shape regular Grade 8 bolts will do.
Carriage bolts are for wooden carriages! [img]/ubbthreads/images/graemlins/tongue.gif[/img]
-steve
S.A McChesney
'72 BMW 2002tii Fprod Race Car --- '82 Bitter SC 5-spd
'01 Volvo V70 T5 5spd, The Official SCCA Volvo Historic Racing Series Pace Car
'95 EB 351 Bronco --- '69 Lotus Europa --- '87 Merkur XR4ti --- '85 Bitter SC 3.9</font> '02 F350 Lariat CC Dually Longbed PSD 4x4 6spd
Tekonsha Prodigy -- Icom 2100H -- Retrax -- B&W Turnover 5er Kingpin -- Letter to Santa "US Gear" . . .
32' invert 5er Britton/Transport Sys 12K GVWR Toybox,Honda 3kw Gen,Fridge,Micro,5kw Inverter,ColemanPolarCub
__________________________________________________ _______________________
They DO actually locate in a square hole, and the carriage head is nice because you can install them by yourself. I've installed several 5th hitches and they all came with grade 5 hardware. I've never doubted the integrity of the installation. P.S. -- FWIW -- our local John Deere store carries #5 carriage bolts (I don't know who actually makes them) that have a very nice anodized gold finish. I use them whenever appearance is a consideration, also they don't tarnish like regular cad-plated hardware does.
